Go to Post Heidi's best picture ever - and she didn't even have to Photoshop this one! - dlavery [more]
  #46   Spotlight this post!
Unread 14-04-2012, 03:53
Re: Crazy robot idea for this year 2
Originally Posted by Hawiian Cadder View Post
I actually thought about this a bit more after posting, I think the best soulution would be a 37 inch diameter fan pointed up and toward the key. With all the power in the KOP motors you could achieve about 3-4 times as much power as a large gym fan. This would almost certainly deflect any shots enough to miss.
The air wall was tried in 2006. Early testing indicated that it was useless against any robot shots--range, 60" shooting air at a target about 8' up. (More like 6.5' up if on the ramp.) For a dropping shot this year, you'd need to add some height to that. Hover the ball that year, yep. Add velocity, though, and in the goal every time.
Think about it this way: You need to generate enough drag force on the ball that gravity can take over, or that it will move in a different direction. There are a couple of possible estimates for the drag coefficient of a sphere, namely 0.5 (laminar flow) and 0.2 (turbulent flow). You have an area (pi*D^2)/4, a known air density (1.204 kg/m^3 for 20C), and you can estimate the drag force needed to deflect the ball.
Now, you plug into the equation Fd=Cd*A*density*(V^2)/2, and solve for the velocity needed. Now that you know how fast the air needs to move, you can figure out how big of a fan you'll need, or how much you need to apply a nozzle to get the air moving that fast, using one of several possible methods.
Power in the motors in the KOP has to translate to a fan, and thus to the air. That is where you run into trouble (in addition to keeping most of the air column generated together instead of going off into eddies in the surrounding air--you're probably best off using the turbulent flow analysis for that part of the equation).
  #47   Spotlight this post!
Unread 21-04-2012, 20:04
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Maybe a hovercraft might work and be legal.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
  #48   Spotlight this post!
Unread 22-04-2012, 00:41
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
they were legal in 2009, nobody used one, but the legality was confirmed in Q&A.
  #49   Spotlight this post!
Unread 23-04-2012, 16:29
Clayton Yocom's Avatar
Clayton Yocom Clayton Yocom is offline
Programming Mentor
FRC #0027 (RUSH)
Clayton Yocom will become famous soon enoughClayton Yocom will become famous soon enough
Send a message via AIM to Clayton Yocom Send a message via MSN to Clayton Yocom Send a message via Yahoo to Clayton Yocom
New offseason project, convert Jake, our 2009 'bot, into a hovercraft.
