Go to Post There are times when all of us - myself included - need a virtual *poink* to the back of the head and someone to say "wake up and stop behaving like a three-year-old." - dlavery [more]
Unread 21-04-2012, 11:58
kobitate94's Avatar
kobitate94 kobitate94 is offline
Webmaster
FRC #1683 (Techno Titans)
Team Role: Webmaster
kobitate94 is on a distinguished road
SmartDashboard Window size not saving
Hey everybody!
We recently switched Driver Station computers due to the fact that our old classmate kept causing SmartDashboard to crash. We are now using a plastic MacBook running Windows 7 through BootCamp.
The SmartDashboard launches fine, but the window size is too small on launch (1024x400 to be exact). We are able to change the window size just fine through File > Preferences but, when we reopen the dashboard, the window size resets to 1024x400. We know that the layout was saved because we added a second camera feed when we set up the new Driver Station, and it was still showing when we relaunched.
How can we fix this? Thanks in advance!
Unread 21-04-2012, 15:02
Sunstroke Sunstroke is offline
Programmer
AKA: Joe Grinstead
FRC #3504 (Girls of Steel)
Sunstroke is an unknown quantity at this point
Re: SmartDashboard Window size not saving
Originally Posted by kobitate94 View Post
Hey everybody!
There's currently no fix for that when you are running in "competition" mode (which means you don't see the frame around the window).
One option is to not run it in competition mode. To do that, go to Program Files\FRCDashboard\launcher.bat and remove the word competition (or "-competition", I don't remember if there is a hyphen).
Unread 21-04-2012, 15:26
agartner01 agartner01 is offline
Captain + Control Sys & Design
FRC #4174
agartner01 is an unknown quantity at this point
When your in "competition" mode, the size of the window is hard coded into the program. However, it's quite easy to change, all you have to do is change one line in the source (which is downloadable from firstforge.wpi.edu). I have successfully changed our dashboard to display at 1366x500. If you need any help, or just want me to compile you one with your resolution hard coded, PM me.
Unread 23-04-2012, 19:38
kobitate94's Avatar
Webmaster
Thanks for the help guys! I've passed this on to our lead programmer. Good luck for those going to worlds!
Unread 03-05-2012, 14:40
AKA: Brad
#0190 ( Gompei and the Herd)
Sorry about the annoyance, we'll try to fix it for 2013.
Brad
Brad Miller
Robotics Resource Center
Unread 03-05-2012, 22:27
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
The problem seems to be at DashboardFrame.java at line 119:
// Set the size / look
        if (competition) {
            setPreferredSize(NETBOOK_SIZE); //1024x400 - this is your problem
            setUndecorated(true);
            setLocation(0, 0);
            setResizable(false);
        } else {
            setMinimumSize(MINIMUM_SIZE); //300x200
            // Closing operation is handled manually
            setDefaultCloseOperation(JFrame.DO_NOTHING_ON_CLOSE);
            DashboardPrefs prefs = DashboardPrefs.getInstance();
            setPreferredSize(new Dimension(prefs.width.getValue(), prefs.height.getValue())); //This is the dimension stored in the save file
            setLocation(prefs.x.getValue(), prefs.y.getValue());
So the DashboardFrame will automatically be set to 1024x800 if you're in competition mode. The easiest (temporary) fix until the 2013 release would be to change
to
setPreferredSize(new Dimension(width, height));
with (width, height) being based upon the size of your screen.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 04-05-2012, 02:36
Programmer
AKA: Joe Grinstead
to
A better stopgap would be:
because that will now save your screen size, and use the saved screen size.
