type of material; conveyor belt
1. Is it legal to use stainless steel in building the robot?
2. Is there a "common" conveyor belt that most teams use? 3. What is the maximum pneumatic RAM? Thank you. |
Re: type of material; conveyor belt
2. Use for what? Wheels, Transmissions, Arm belts 3. I belive that you can only use 120psi before the saftey valve activates reliving pressure, not 100% sure on that one |
Last year we made a robot with a conveyor belt to convey the balls into the goal. We used a rubber and cloth belt about a foot wide that was extremely ineffective as it was difficult to tension (and thus it kept sliding to one side), it was heavy (we lost about 1lb drilling holes in it), and it didn"t have enough friction (our pulleys couldn"t move it very well and it couldn"t pick up balls well). One type of belt we saw that looked good and I have seen used in places other than robots is lots of thin (about 3/4 inch wide) rubber/latex/something bands. They were like extruded trapezoids and thus they would fit into grooves in pulleys and would drift and since they were slightly elastic they could be tensioned nicely. They were also very high friction (sometimes used in cafeteria coveyors for trays because they grip well even when wet) so they would pull what they were used on and the pulleys would easily move them. I don"t know what these or called or where you can get them because I"ve never used them, but I think these would be the best things to use.
Clarification of question 2
A clarification on the "common" conveyer belt question: (#2)
We are thinking of using conveyer belting for driving (Like a tank). But since we are a rookie team we are not sure where to get the supplies or even what we need. Specifically what we wanted to know is: What conveyer belt do you recomend? What wheel are we supposed to use with the conveyer belt? How did you attach the conveyer belt to the wheel? Thank you for your help! |
The belt we used on Li'l MOE in the 2001 season is a double-sided timing belt, 1 inch thick. It had excelent traction on the carpets and we never had one snap... we didn't have to modify it at all to use it, and it was easy to tighten. However, we did have to make our own wheels to make them lighter and to keep the 'treds' from comming off.
#7
Can you help me out and tell me where in the rules or elsewhere this is stated? Thanks. |
#8
Re: Clarification of question 2
As for the wheels, in previous years teams have used conveyor belt material and attatched them to wheels...like these or these . We got material(we used neopreme) from McMasterCarr and attached it with screws (you could also use rivets). This year this is a little more tricky because FIRST will be stingy about metal on the playingfield...glue seems one of the only options in this respect.... |
#9
Re: Re: type of material; conveyor belt
On page 4 of the previously mentioned pneumatics manual:
http://www2.usfirst.org/2003comp/pne...anual_2003.pdf the description of the components clearly state the pressures used. It looks like we have an initial pressure switch to tell the Robot Controller when to shut off the compressor, and a system (after the air tank) regulator which must be set no higher than 60 lbs. There is another regulator you can use after the system regulator if part of your system needs even lower pressure. Last edited by Mark Pierce : 10-01-2003 at 13:04. |
#10
Thanks!!! I KNEW I read it somewhere, but I kept looking the the robot rules and it only states the 120 psi limit.
Thanks again! |
| the provided chassis material | Andrew Dahl | Kit & Additional Hardware | 5 | 09-01-2003 15:26 |
| material and fastener usage | archiver | 2000 | 1 | 24-06-2002 00:08 |
| Illegal material | PDonovan | Rules/Strategy | 13 | 16-05-2002 16:53 |
| WASH scouting fields | Mike Soukup | Scouting | 0 | 04-02-2002 02:39 |
| Best material for wheels. | Dr.Bot | Technical Discussion | 0 | 21-01-2002 23:32 |
