Go to Post Man, FIRST is amazing :D - galewind [more]
  #31   Spotlight this post!
Unread 23-04-2012, 15:07
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Inbounders!
When I am reffing I try and make it a point to try and know how many balls have been scored and how many have been returned to the field.
It's not hard to know when it's time to start watching the inbounders more closely.
  #32   Spotlight this post!
Unread 23-04-2012, 15:12
Clayton Yocom's Avatar
Clayton Yocom Clayton Yocom is offline
Programming Mentor
FRC #0027 (RUSH)
Clayton Yocom will become famous soon enoughClayton Yocom will become famous soon enough
Send a message via AIM to Clayton Yocom Send a message via MSN to Clayton Yocom Send a message via Yahoo to Clayton Yocom
If this is true than its a non-issue, which, apparently, FIRST agrees. I can see inbounders being extremely important on Einstien if the strategies are anything similar to the psuedo-hoarding strat.
  #33   Spotlight this post!
Unread 23-04-2012, 15:16
IndySam's Avatar
Re: Inbounders!
Also I have never had to call a foul (in three regionals) against teams employing this strategy. Teams that understand the rules enough to do this also understand that they need to get rid of the balls.
The only time I have called a foul for more than six were on teams that either didn't understand the rules or simply weren't paying attention.
  #34   Spotlight this post!
Unread 23-04-2012, 15:48
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: Inbounders!
Wow, you're lucky. I have reffed two events and coached 3. In two reffed events, I have called something like 3-4 instances of G31 (~10 balls total). I suspect most refs keep track the same way IndySam and I do.
In the 3 coached events, I have clearly seen* well over 10 separate instances--probably close to 25 balls--not called (and others that were called). On webcasts especially, I have seen teams loose matches due to non-calls multiple times. It's a constant issue I've heard numerous other drive team members, spectators and volunteers comment on.
Some of these cases were simply teams not understanding the rules that didn't affect much, but others very clearly provided a strategic advantage (whether or not they understood the rules). This makes FIRST's rationale very difficult for me to swallow.
*I cannot see opposing inbounders well enough when I'm coaching to spot G31s (with all the baskets, diamond plate, drivers, robots, etc in the way). Please don't take this as a slight against teams we've "blocked the slot" on. My mental count certainly never got over 6.
  #35   Spotlight this post!
Unread 23-04-2012, 16:54
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: Inbounders!
Team 1219 and I had a little bit of fun in Q-25 at GTR west. They would park infront of the barrier between the coopertition bridge and our bridge. They seemed to know that I could bounce it over both bridges and the barrier, and would drive infront of whatever I seemed to be aiming for, so I must say a lot of fake throws(on my part) and fake moves (on their part) were happening. To make it better, their drivers were directly across from the inbound slot. I remember after their first block, I looked up at them, their coach smiled at me, and I smiled right back. Kudos to them for making my job that much more annoying.
I must say that was my most enjoyable match to inbound
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
  #36   Spotlight this post!
Unread 23-04-2012, 21:26
mhat_ios's Avatar
mhat_ios mhat_ios is offline
AKA: Michael Hatsios
FRC #0610 (The Coyotes)
Team Role: Human Player
mhat_ios has much to be proud ofmhat_ios has much to be proud ofmhat_ios has much to be proud ofmhat_ios has much to be proud ofmhat_ios has much to be proud ofmhat_ios has much to be proud ofmhat_ios has much to be proud ofmhat_ios has much to be proud of
Re: Inbounders!
Originally Posted by Alan Anderson View Post
Unless you're talking about throwing over the alliance station wall during the last 30 seconds, which it doesn't sound like you meant.
Originally Posted by Clayton Yocom View Post
That is what he meant.
He means getting it over the bump in the middle. I also understand what he means about a full upper body movement. I do something similar, and I do very well, as the balls actually go faster, and bounce higher.
Funny point about hoarding- in Arizona semi - finals, the human players did not take any balls out of the corrall, and got 45 PENALTY POINTS!!!!
2013 Champions of the World
2013 Galileo Division- Division Champions
2013 Waterloo Regional- Finalists
2013 BAE Systems Regional- Champions
2012 Arizona Regional- Champions
2012 GTR East Regional- Finalists
2011 Galileo Division – Division Finalists
2011 GTR West Regional- Finalist
2011 Waterloo Regional- Finalist
  #37   Spotlight this post!
Unread 23-04-2012, 21:29
mhat_ios's Avatar
Re: Inbounders!
That is pretty classic. I have had something like that, but they usually give up after 10 seconds, when i dont throw a ball.
  #38   Spotlight this post!
Unread 23-04-2012, 21:40
zekeF's Avatar
zekeF zekeF is offline
FRC #1718 (The Fighting Pi)
zekeF has a spectacular aura aboutzekeF has a spectacular aura about
Re: Inbounders!
ive had a robot park dirrectly infront of the inbound slot for the entire match but i got lucky and they left a big enough oppening for the ball to be thrown through
  #39   Spotlight this post!
Unread 23-04-2012, 21:56
Gregor's Avatar
Re: Inbounders!
Man that's annoying. Luckily when that happened only 3 balls were scored on us, so...30 seconds
<Since 2011
  #40   Spotlight this post!
Unread 24-04-2012, 07:25
Programming Mentor
FRC #0027 (RUSH)
What an interesting number...
  #41   Spotlight this post!
Unread 24-04-2012, 09:44
Re: Inbounders!
No, that's the barrier. Amadinerjohn was talking about the fender (unless he just used the wrong word, which is certainly possible, and which would make my question totally irrelevant).
  #42   Spotlight this post!
Unread 24-04-2012, 11:16
mhat_ios's Avatar
Re: Inbounders!
It's no big deal, but just think logically about throwing the ball over the fender. It is impossible, as there is no way to get over the one on the far side, and you are right beside the one that the other alliance is scoring on. It seems pretty obvious that he just mixed up the words. The way he wrote it made it seem like he meant the barrier.
  #43   Spotlight this post!
Unread 24-04-2012, 12:11
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Inbounders!
I did mean barrier. That was a huge typo on my behalf and I'm embarrassed about it.
  #44   Spotlight this post!
Unread 24-04-2012, 16:39
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
Re: Inbounders!
Check GTR West finals 1, I'm pretty sure a human player scores a ball into the low basket (off 2056) passing through the slot. We also are fortunate enough to have a full practice field and I have hit the rim a few times through the feeder slot.
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
