Go to Post I'm not of the belief that this is the intent or purpose of Chief Delphi. It is a place for sharing knowledge and information, perspectives, and humor. In the process, it has created community. - JaneYoung [more]
Unread 24-04-2012, 11:12
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Possible Strategy?
So we all know that touching the opponents bridge during the match is a 9 point penalty, and we also know that balls scored in autonomous are worth 3 extra points.
What if you were to take the balls from the opponent's bridge in autonomous (-9 points) then score them in the top hoop (+12). You would have a 3 point gain, and the opposing team would not have the bridge balls until their inbounder inbounded them.
You could also use this strategy for getting balls off of your bridge to gain an additional 12 points, but if you have 3 robots on an alliance, all score both of their balls (+36 points) then one gets the middle bridge (assuming two are on it, +12) then one gets their alliance bridge (+12) then one gets the other alliance bridge (+3) you have scored 63 points in the first 15 seconds of the game.
While none of the side bridges have been scored in hybrid before, I think that some of the teams that we will be seeing at Championships will be able to pull it off. Get the right robots on an alliance, and you would have the best hybrid alliance in the game.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 24-04-2012, 11:20
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Re: Possible Strategy?
I think this sounds like a great idea, but you wont see it happen.
Including the breaking of a rule into part of your alliances strategy doesnt show very good sportsmanship.
Unread 24-04-2012, 11:31
ElJeffe3255's Avatar
ElJeffe3255 ElJeffe3255 is offline
AKA: El Jeffe
FRC #3255 (SuperNURDS)
ElJeffe3255 is an unknown quantity at this point
In addition, I believe you are penalized EACH time you touch the bridge. Since the bridge is bouncing around, you come in contact with it multiple times racking up a lot of penalty points. Didn't this happen in one of the events when a team was inadvertently trying to get on the wrong bridge? I'm thinking it was with 1717.
Unread 24-04-2012, 11:32
UAH Class of 2019
You do have a good point there, about the sportsmanship.
But what about your own alliance bridge? Why don't we see any robots get those balls? I don't think it would be too hard to do.
Unread 24-04-2012, 11:33
Sean Raia's Avatar
I have no doubt that will happen, i honestly thought it already had.
Unread 24-04-2012, 11:39
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
But the balls on your bridge are already yours will the co-op balls are anybodys in the match, the first to get them gets a small edge in the match to start and if you can score those in autonomous you have a larger edge. Another factor is time, the co-op bridge is a straight shot while the alliance bridge is awkwardly off to the side which requires extra turns and manuevers which eat up seconds. Some robots who go for the balls on the co-op bridge in hybrid barely have enough time to get them and then re-line up.
1058 PVC Pirates 2016 - xxxx
Unread 24-04-2012, 11:48
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
you're alliance could get up to 72 pts not 63... it's just that the penalty points are added to the opponents score, not taken from yours.
we've been trying our hand at the alliance bridge balls and it's alot harder than you think. we've had the 4 ball auto from the co-op bridge for some time and there aren't many other teams that can do it, so we've had no problems. but we're on Archimedes with 67 who can also do it, and i'm sure there's prolly a few others... and since we'd rather play with them then against them we've tried to get the alliance bridge auto working... i'm not sure if we have yet tho... i would guess not, but we have been working on some other auto modes as well. we'll just see how it plays out at champs.
Unread 24-04-2012, 11:55
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
I wouldn't say it's bad sportsmanship, it's just really smart playing. Penalties are part of the game, and if an alliance feels that they can earn more points by taking those penalties, then what's to be done? Yeah, it's not a 'nice' move, but the C in FRC stands for competition, and that means you play the best you can to win.
For example, at the 2011 IRI, our alliance (1126, 233, 2016) went up against the number 1 alliance (1114, 987, 67). They employed a tactic to counter us pushing tubes into our lanes to protect them, by taking the 3 point penalty to go into the lane and get them. Because the 3 point penatly paled in comparision to the 18 point unaided top row logo, the cost of the penalty was worth the extra tubes. Were we happy about it? Of course not. But that's because they mopped the floor with us doing that. It was a brilliant tactical move and fully justified in the scope of the game.
There are differences between smart play and cheap moves. I don't think stealing balls off the alliance bridge is a cheap move. If nothing else, the offending alliance is taking a 9 point hit for it. If they want to risk taking that, let them do it. It's not like they're taking the balls and getting away scot free.
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
Unread 24-04-2012, 12:21
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
987 has an alliance bridge hybrid and has used it...expect to see it even more later this week
Unread 24-04-2012, 12:23
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Consider the difficulties involved. First, you have to be able to shoot your two balls, then get to the bridge and tip it reliably. Then you have to gather the balls as they come down (something even the best gatherer's I've seen can't do 100%), then you have to line up and shoot at the basket, something that only 2 teams I've seen could do 100% in autonomous mode when when could perfectly line up their robot in the key. All in 15 seconds.
I think the risk of losing points is going to keep teams from trying this with their opponents bridge... but I can certainly see teams trying it with their own bridge - worst case the balls just end up on their side.
Unread 24-04-2012, 12:44
loyal loyal is offline
Jack of all trades master of none
AKA: Loyal
FRC #0716
loyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to all
I can tell you right now 4055 has done alliance bridge and co-op bridge in autonomous. Look it up. We did it a lot in Hartford and will do it again at the championships. Our new autonomous will be to reverse our conveyer and push the two balls we have directly into our alliance best shooter and hope to see a quick 12 points. We also have a stinger check us out.
Unread 24-04-2012, 12:56
Sean Raia's Avatar
As good of a strategy as it is... it IS against the rules. And youre not doing it by accident, you are intentionally aiming to do it. I define intentionally breaking the rules to get an advantage as bad sportsmanship... As smart as it may be strategicaly.
Unread 24-04-2012, 13:19
Mullen's Avatar
Mullen Mullen is offline
FRC #0573 (Mech Warriors)
Mullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of light
67 already has the ability to go for the Alliance bridge. They were playing around with it at MSC during the practice rounds incase they paired up with another robot that also went for the Co-op bridge. I don't think they used it in a real match, but they do have the option.
2002-2003 : 573 Mech Warriors: Student
2005-2007 : 1504 Desperate Penguins: Mentor
2012 - 2016 : 573 Mech Warriors: Mentor
Unread 24-04-2012, 13:35
Austin2046's Avatar
I figured they were probably working on it too, but i didn't know if they had it yet. hopefully we get paired with them one round (if not in elims ) and we can try to get a 60 point hybrid... that would be amazing...
Unread 24-04-2012, 16:09
LeelandS's Avatar
AKA: Leeland
I understand your reasoning behind that, and I agree it's not the most wholesome tactic, and I definitely understand a lot of people won't like it, but the rules are there to provide guidelines and consequences for the teams involved in a match. Now, breaking a rule to maliciously and ruthlessly undermine your opponents is one thing. If you're trying to flip them over on a bridge or damage then, THAT is bad sportsmanship because of the nature of the act. That's not a doubt.
But the consequences for stealing the opponent's balls are clearly defined, and you're not deliberatly trying to pulverize your opponent. It's a tactical advantage. If a team wants to take the penalty to do it, it's their choice. Yeah, it's not ideal, of course it's not an 'honorable play', because it does violate the rules. But to call it 'bad sportsmanship' I think think is incorrect. They're doing it in the name of the game, but not to an extreme point that makes you shake your head at the team.
I understand what you mean, they would be breaking the rules and that makes the play rather questionable in merit, but it is a plausible tactic and you can't question it's a smart play. I'm not saying I'd promote it or encourage it, but I wouldn't look down on a time who did this.
