Go to Post Remember success in FIRST isn't measured by the trophies. It's measured by the inspiration. - camtunkpa [more]
Unread 24-04-2012, 17:06
Chris is me's Avatar
AKA: Pinecone
Re: Possible Strategy?
I do not believe it is bad sportsmanship to take penalties for a net gain. Especially because this isn't something like an intentional tip - this is just picking up balls.
That said, it's a pretty bad strategic decision. Three points is not enough to justify the risks. Miss one ball and it's not worth it. If you're desperate for something to do in that time, and you have already exhausted both the co-op and your alliance bridge, I'd start preparing for your first moves in the teleoperated period.
Unread 24-04-2012, 17:16
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
What about if you know your opponent can score both balls from their alliance bridge reliably? Then it's a net-potential-gain (In the sense that 9 points < 12 points, plus any you happen to score to lessen the swing.)
Just making up crazy situations.
In my opinion breaking rules does not automatically equate to bad sportsmanship.
Unread 24-04-2012, 17:21
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
I'm working on the math, and this is what I have (With auton points):
With out taking balls (Opponents score from alliance bridge in auto):
Opponents: +12 (2 on top)
You: +0 (no advantage)
Net gain: -12
With taking balls:
Opponents: +9 (Technical foul)
You: +12 (2 on top)
Net gain: 3
Taking balls (miss shot):
You: +6 (1 on top)
Net gain: -3
However, you then have an open balls on your side that you can put up in teleop, effectively making it a wash.
Taking balls (miss both shots):
Net gain: -9
However, you then have 2 open balls on your side that you can put up in teleop, making it a net gain of -3.
It seems to me that even if you miss the shots, you still end up on the better end of things than if you get their alliance balls than if you let them sit.
It may not be a game changing move, but it may be something worth considering.
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
Unread 24-04-2012, 17:45
AKA: Pinecone
You: +6 (1 on top)
Net gain: -3
It would be a wash if the time constraint wasn't too great. There's a ball on your side you have to score to make the move a wash, which takes several seconds away. So I would say it's a net negative move.
It's hard to quantify the other moves you could make as a third robot when your partners are scoring and moving to the bridges, but I'm tempted to say that getting in position to block the return would probably be the greatest benefit. If you win the Co-Op bridge, you have at least an 18 point lead you'll want to stretch as long as you can.
It just seems like more trouble than it's worth for only three possible extra points. Denying six points in teleop to the opponents is also somewhat nice though, but I think it's too close to be worth it.
Unread 24-04-2012, 17:51
LeelandS's Avatar
AKA: Leeland
I'd agree that it's definitely a steep move. Were I coaching, I wouldn't even consider doing this unless the opponent had a consistent autonomous that put in 2, then went to the alliance bridge, and put in 2 more. Other than that, it is a pretty risky move and it's easy for it to backfire. So were I to use this tactic, it would be VERY sparingly and only under special circumstances.
Unread 24-04-2012, 19:38
GaryVoshol's Avatar
Cogito ergo arbitro
I am sure that if this strategy comes to pass, there will soon be an escalating series of consequences just like there was for grasping/grappling the bridge to balance. Eventually [T15] and/or [T17] comes into play.
(since 2004)
Unread 24-04-2012, 21:31
3098 callahan 3098 callahan is offline
FRC #3098
3098 callahan is an unknown quantity at this point
Originally Posted by Sean Raia View Post
I think this sounds like a great idea, but you wont see it happen.
Including the breaking of a rule into part of your alliances strategy doesnt show very good sportsmanship.
Yea its also bad sportsmanship to flip over other robots. But it has been done I think in order for teams to win they will try anything they can even if its bad sportsmanship.
Unread 24-04-2012, 21:38
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
There's a huge difference between attempting to damage or incapacitate another team's robot and committing a foul because you believe it will benefit the score. The latter is widely practiced in several sports and is generally not considered unsportsmanlike, just as I would not consider this strategy unsportsmanlike or un-GP. I still don't think it's worth the risk, though.
Does anyone else remember when TBA signatures actually worked?
