Go to Post Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself. - Alan Anderson [more]
Unread 24-04-2012, 21:39
CyberEagle9416's Avatar
CyberEagle9416 CyberEagle9416 is offline
FRC #2073 (Eagle Force)
CyberEagle9416 is an unknown quantity at this point
Stacking robots
Does anyone have creative ideas on stacking robots?
I've seen fembots almost do it with another team.
Unread 24-04-2012, 21:45
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Re: Stacking robots
If the term "stacking" that was in the title and you mean stacking robots to get a triple balance, try searching CD-Media with the tags "frc1501." Also there is the search function. Try searching terms like "Stacking" or "Robot stacking."
Unread 24-04-2012, 21:53
Re: Stacking robots
this was to get more robots on the bridge
Unread 24-04-2012, 22:02
Andrew Lawrence
Posts: n/a
Re: Stacking robots
Like you said, 692 attempted it with 701. There have been plenty of stacks to get more bots on the bridge. Look at 1501 for more details on how they did it. They were like 701, but I couldn't see if they were as good shooters (I didn't watch their matches, so I can't say. Help here, anybody?).
If you're going to the CalGames offseason, or watching the webcast, you may be able to see a stack balance or two .
Unread 24-04-2012, 22:06
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Re: Stacking robots
701 and 2865 did it.
http://www.youtube.com/watch?v=5qPtIfwSN6c
Although, I don't see the benefit because it was only those two on the bridge and they could have fit if they balanced normally.
Unread 25-04-2012, 03:07
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Stacking robots
Here's the other matches we stacked in...
Spokane QF Match 1 - Failed attempt at a triple balance... We clearly needed more practice with 294. Also I think having the CG of the stacked robot that high works against you when balancing. Luckily, 294 scored enough to win that match.
http://www.youtube.com/watch?v=bglFrbbN8Ss
Spokane QF Match 2 - Stacked but just a double... It seemed a better use of time to have 294 score some more balls.. unfortunately we lost by 2 points.
http://www.youtube.com/watch?v=NnnBxDSLOtk
Spokane QF Match 3 - Stacked but just a double again. Enough for a win and advanced to the semis, where we focused on defense to stop fender shooters.
http://www.youtube.com/watch?v=Gb7eKLP50uo
Was it worth it to do the stacking approach? Kinda yes and no.. It didn't pay off enough to win elims like we had hoped, but it was definitely a cool thing to try and pull off. I believe it really helped us get the ID award at Spokane, which is a win in a different sort of way. I still wished we would have tried it on the Coop bridge. It would be a penalty on both alliances, but they'd offset each other. It would be a truly cooperative effort!
Unread 25-04-2012, 11:17
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: Stacking robots
Is it legal to have a robot begin on top of another? I know in 2007, there was a loophole that allowed alliances to score by simply stacking two dead robots on top of each other. Obviously, to get a triple balance in this years game, the bottom robot would have to be active. Is this a legal way to go for the triple?
-Plutarch
Unread 25-04-2012, 11:22
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Stacking robots
As of BMR, they were fender-based two-point shooters. I don't know exact shooting percentage; I do know they made more than they missed.
Their stacking triple balance is well documented.
I don't know if they've made updates or changes to make them reach the 3-goal or shoot from the key. With their six treaded wheels, they weren't easy to push around at the fender.
Hi!
Unread 25-04-2012, 13:26
Re: Stacking robots
Originally Posted by DampRobot View Post
Is it legal to have a robot begin on top of another? I know in 2007, there was a loophole that allowed alliances to score by simply stacking two dead robots on top of each other. [...] Is this a legal way to go for the triple?
Unless you've got a way to legally touch both the key [G01] and the bridge [G30-1] with the supporting robot and touch the key with the supported robot [G01], no. (And that would most likely involve sticking your favorite appendage outside the frame perimeter, also a [G01] call.) Net foul count, 1 T-foul (9 points) and 2 disabled robots for the match.
2007 was a special case. The loophole was confirmed to be there by the GDC during build season, but as soon as the strategy was used, it was declared illegal. Actually, IIRC, both robots were E-stopped the second they could E-stop them, but started active.
Unread 25-04-2012, 13:40
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Stacking robots
No.
We asked Aiden Brown at the North Carolina regional this specific question.
Although he couldn't seem to find an exact answer as to WHY it wouldn't be legal, (their robot would sit on our rear, and they would have an appendage touching the key to start with) he said it wouldn't be.
Unread 25-04-2012, 13:47
Taylor's Avatar
AKA: @taylorstem
Re: Stacking robots
This may have been what Mr. Browne couldn't remember:
Originally Posted by Rebound Rumble Game Manual
[G30-1]
A Robot may only be supported (fully or partially) by another Robot if one of the Robots is in contact with a Bridge.
Violation: Technical Foul for extended, strategic, or repeated loss of contact.
Robots supporting other Robots will invite scrutiny regarding the safety inherent in the design, per Rule [G07]. It behooves a team employing such a strategy to take precautionary action to mitigate any risk of Robots falling outside the Court.
(blue text is blue box)
Hi!
Unread 25-04-2012, 13:55
AKA: Matt B
FRC #1771 (1771)
Re: Stacking robots
I don't know, we asked him about starting the match that way.
Unread 25-04-2012, 14:12
Re: Stacking robots
Right. He may have been unable to remember the exact rule that made the stacking strategy illegal, but he knew there was one. It was added in the Update on 1/20 (TU#4).
I know I had to look up the rule before replying--I knew there was a rule, and that it had been added to an existing rule, but I didn't know the number/wording.
Unread 25-04-2012, 14:17
AKA: Matt B
FRC #1771 (1771)
Re: Stacking robots
Perhaps. We both looked at the rules (The pregame section) while discussing the legalities of it.
Unread 25-04-2012, 14:22
Re: Stacking robots
Ah. The pregame section. Yes, that would be why he couldn't remember. [G30-1] is in Robot-Robot Interaction.
