Go to Post I continue in FIRST because I'm not looked down upon for not knowing how to do something, but held up because I want to learn. - LemmingBot [more]
Unread 23-04-2012, 20:08
Looking Forward Looking Forward is offline
Honest Analysis
Rookie Year: 1992
Looking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond repute
Predictions Championship 2012: Where Amazing Happens
Nothing can ever quite describe it correctly. The most brilliant adjectives are too dull to capture it. In that moment, everything else is washed away. It's the feeling that makes grown men cry, fans stampede into city streets, and leaves the most eloquent among us speechless. It's the feeling that only three of four hundred will feel this weekend.
Victory.
The preparations are over. Throw out the regional season, it doesn't matter anymore. One hundred teams in each division get a clean slate to try and leave their lasting mark on the FIRST world. After all the work put in over the past months, everything will hinge on two minute spurts over the course of three days. There aren't any more second chances. Execute or go home.
Thanks, once again, to team 1114 for their incredible spreadsheet.
http://i.imgur.com/BEDAH.jpg?1
Top 25
Top 10 Breakdown:
Archimedes - 3
Curie - 3
Galileo - 1
Newton - 3
Top 25 Breakdown:
Archimedes - 6
Curie - 7
Galileo - 4
Newton - 8
As with seemingly every year, there is some imbalance between divisions. Yet, it's not to the point where any division should be written off or any crowned beforehand. Each division has enough top contenders and enough depth to field an alliance capable of winning Einstein. Yes, even Curie.
Ask any athlete, once you reach the top levels of competition you cannot win on talent alone. The same applies here, as it takes supreme and consistent execution in order to add up qualification points and advance in the tournament. In the high stakes world of the elimination tournament mistakes can prove dire. A failed balance has obvious ramifications, but moving to the bridge too soon will prove costly as well. No longer will alliances be able to afford 45 seconds to balance in every match. On the fly decisions of when to balance and how many robots to send will be absolutely critical, and it correct call will vary significantly from match to match.
The overall strategy will have common themes on every field, but each field (and each alliance) will have a bit of its own personality. We've seen that different game plans can prove successful. At the highest level, teams will have to be flexible and be able to follow the balls. Crossover play (and crossover defense) will be critical, especially when alliances play a "possession" game rather than "run and gun." Human player loading will take on a bigger role than before, as possession teams often will not risk an intercepted or misfired inbound pass. Due to the recycled, but limited quantity, of game pieces, getting an early lead will be huge. Thus, hybrid will be huge. An early lead forces the other alliance to try and speed up its game to make up ground and forces them to return balls into play faster than they might otherwise.
It doesn't take three robots scoring to put up huge scores in this game. In fact, many elite teams can clean up the front court by themselves. This can free up partners to do the "dirty work" of slowing down the opponent, feeding balls forward, drawing penalties, and manipulating bridges. That's not to say scoring depth won't be important, as well timed defense and ball starvation tactics can put a dent into just about any scoring machines output. Getting balls to the most accurate shooters in a given situation, both in hybrid and teleop, will become increasingly important as the competition wears on.
The obvious trade off debate will be the triple balance. Not every alliance will be capable of it, and there will be cases where alliances opt not to go for it despite being able. It doesn't take three "wide" bots to complete, nor even two if the "long" bots are capable of overhanging properly or turning on the bridge. Especially for alliance captains that have their own "stingers" or other triple facilitating devices, wide vs. long might not be a huge debate. But in fields as large as these, there will be plenty of wide options that can hang tight with their longer counterparts, and many captains might decide to go with the "sure thing" when it comes to the triple.
Triple balancing, or actively defending the opponent's triple (and exposing yourself to the judgement of the reffing crew), will be all but essential at the highest levels of play. Sure, there are a handful of teams out there with the capability of knocking down 21+ points in baskets in the last 30 seconds of a match. But they're the exception to the rule, and more importantly, there have yet to be any who have shown they can do that two out of every three matches. The ball economy simply doesn't support it on a regular enough basis. Beyond that, the best of the best are going to be cutting their triple times shorter and shorter. Teams like HOT, Las Guerillas, and Miss Daisy have shown just how quickly and reliably a triple balance can be completed with the right partners.
Ultimately, the winning alliance will be well rounded, flexible, robust, and lucky. Eliminations matches are as much about survival as they about beating the opponent. The winners will have relatively few failures along the way, and we be able to respond well to whatever is thrown at them. The alliance will not be critically dependent on fender scoring, human player in-bounding, crossing over a particular field element, or a single machine. If they are, an opponent will recognize it and take it away from them. Balance, in more than one way, will be the key to victory.
Each division will have it's own prediction thread, but here's a layout of how they will work. "Tips", "locks", "dark horses", and "sleepers" will be named for each division. In this context a tip is a team to watch, with a solid chance of going deep. A lock is a team that's guaranteed to do well, with a 50% chance or better of making the divisional finals. A dark horse is a team that has played very well all year but hasn't generated a lot of attention and stands a strong chance to surprise a lot of people. Sleepers are teams that have shown flashes of brilliance but haven’t been able to put it all together yet, but have some potential to shine in St. Louis if they can play well. As always, if you don't like the predictions, go out there and prove them wrong.
Unread 23-04-2012, 20:14
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Re: Predictions Championship 2012: Where Amazing Happens
I'm interested to hear your take on these divisions. I've tuned into EWCP and heard those, let's see how different they are.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 23-04-2012, 20:15
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Great post as always LF. The quote above is a good point. Similar but different strategies will emerge on each field. This will make for a very interesting Einstein field!
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 23-04-2012, 21:56
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
I'm excited to see the action on Curie. I can see an alliance of 254 and 971 would be as unstoppable as it was at SVR. We had a difficult time defending against these bots and it's not easy. I think these two teams will take Curie, but after that I'm not so sure because Newton and Archimedes look pretty solid too.
Unread 23-04-2012, 21:57
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
definately looking forward to Looking Forward's predictions for the championship divisions... i'm hoping some of the teams from the Pacific Northwest really turn some heads this year.
Unread 23-04-2012, 22:05
Volunteer, WPILib Contributor
no team (Waiting for 2021)
I agree. This is going to be the breakout year for the PNW. We have alot of VERY good teams this year.
On a similar subject, does anyone know if any team from the Pacific Northwest has ever made it farther then a division finalist?
Team 4488 - Mentor 2013-2016
Unread 24-04-2012, 03:59
SamMullen SamMullen is offline
Team Alumni
FRC #0360 (Revolution)
SamMullen is a jewel in the roughSamMullen is a jewel in the roughSamMullen is a jewel in the rough
I'm pretty sure that division finalist is as far as any of the PNW teams have gone, although I could easily be forgetting someone from Oregon. In 2005, 1510 and 492 both got silver medals , and 488 got theirs in 2009. Also, I think the only PNW team to ever win an actual award at champs is 1983 with the Xerox Creativity award last year.
Proud 360 Alumni
Volunteer of 6 years
Supporting my good friends on Skunkworks, Mean Machine, and Pandamonium in Spokane and Silicon Valley
Last edited by SamMullen : 24-04-2012 at 21:27. Reason: redundant sentence that made things harder to comprehend.
Unread 24-04-2012, 08:24
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
This could not be more true. Getting through Einstein is a grind.
In 2008 our robot could barely score by the end. Battles with 1124 and 148 rendered a good scoring machine all but useless. In 2009 we smashed into 1717 in the Galieo finals. We had to make major repairs between Divisions and Einstein. In 2010, we were very close to pulling in a backup bot because 177 was having drivetrain issues. Last year the RS775 gremlins bit 781...and I believe 177 was again fighting really hard to resolve all of their issues too.
Pit crews better stay alert all weekend to potential issues and buds of issues, otherwise they will bite you at the worst possible time.
Good luck to all!
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 24-04-2012, 08:52
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Good luck to all!
If you look at the video of the end of SF2-2 on Einstein last year you can see the gas spring on our arm go flying off we didn't have time to properly fix it between the matches because of the speed they ran the last few matches at last year, so our quick fix with latex tubing was too short to pick up off the ground. Also I'm still shocked how few people so our minibot smoking on field in the finals.
As Adam and LF mention durability is important. To get through the championship finals it can take a minimum of 10 matches and a maximum of 15. That is as many matches as an entire regional for most teams in a span of 5 hours. You do not want to be fiddling with issues after every match in those circumstances.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 24-04-2012, 16:34
Banderoonies's Avatar
Banderoonies Banderoonies is offline
Team Mentor
AKA: Sandra
FRC #0195 (Cyber Knights)
Banderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of light
Each division will have it's own prediction thread, but here's a layout of how they will work. "Tips", "locks", "dark horses", and "sleepers" will be named for each division. In this context a tip is a team to watch, with a solid chance of going deep. A lock is a team that's guaranteed to do well, with a 50% chance or better of making the divisional finals. A dark horse is a team that has played very well all year but hasn't generated a lot of attention and stands a strong chance to surprise a lot of people. Sleepers are teams that have shown flashes of brilliance but haven’t been able to put it all together yet, but have some potential to shine in St. Louis if they can play well. As always, if you don't like the predictions, go out there and prove them wrong.[/quote]
195 is the darkest of horses and ready for St. Louis Quick Triple balance, stinger, 100% auto, amazing shooting and wheelies. So excited to be in Archimedes!!!! and looking forward to the links to the prediction threads!
Sandra
Unread 24-04-2012, 16:52
ttldomination's Avatar
Sunny
Announcing that your team is the dark horse doesn't really convince anyone, and defeats the purpose of a dark horse. Additionally, considering your OPR is actually top 15 in the division, you might actually be a semi-gloss white horse.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 24-04-2012, 21:00
AKA: noops
- Sunny G.
Remember, only 1% of FIRSTers are on Chief Delphi (maybe not 1% but a low number). Also, OPR is not a great metric this year at all.
Unread 24-04-2012, 21:19
hg273's Avatar
hg273 hg273 is offline
AKA: Henry Gordon
FRC #1540 (Flaming Chickens)
hg273 will become famous soon enough
Originally Posted by SamMullen View Post
I'm pretty sure that division finalist is as far as any of the PNW teams have gone, although I could easily be forgetting unless Im forgetting someone from Oregon. In 2005, 1510 and 492 both got silver medals , and 488 got theirs in 2009. Also, I think the only PNW team to ever win an actual award at champs is 1983 with the Xerox Creativity award last year.
Although not on the FIRST website, 1540 won the the championship website award in their rookie year, 2005.
Unread 24-04-2012, 23:11
AdamHeard's Avatar
Lead Mentor
These predictions will be much more accurate than the EWCP cast.
When comparing Looking Forward to the EWCP cast, the cast is a bunch of amateurs discussing rumor and hearsay.
Looking Forward clearly has some good sources.
Unread 25-04-2012, 01:16
JackS's Avatar
JackS JackS is offline
Sideline Observer
no team (EWCP)
JackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond repute
We appreciate your honest feedback, we will be take this into account in our future casts. We're always trying to improve. Some of us are curious, what part of the cast would you call rumor and hearsay?
[2009-2014] FRC Team 2791 - Shaker Robotics
Colgate University
'16
