Go to Post I, for one, refused to be railroaded down this train of thought so easily! Geeze, one lousy game hint just builds up steam for any old picture to come through and go two pages in a matter of hours. - Billfred [more]
Unread 04-25-2012, 08:04 PM
SeanPerez SeanPerez is offline
FRC #2625 (Arc Reactor)
Team Role: Driver
SeanPerez is an unknown quantity at this point
Re: Arduino and kop encoder
At any rate, when used as an interrupt, it only counts once per revolution.
it may only count once, but i was getting around 8000 rpm.
with your new code, the faster it spins, the lower the rpm.
Unread 04-25-2012, 08:06 PM
Michael Hill's Avatar
Are you looking at the first column?
If you are, disregard that. That's the "dt" value. Sorry, I didn't make it very legible. Look at the second set of numbers.
0.43 RPM: 2803.74 Pot: 82
means that 0.43 is the time between calculations, 2803.74 is the revolutions per minute, and 82 is the potentiometer value.
Unread 04-25-2012, 08:18 PM
Team Role: Driver
ok now im reading the right number. but it seems the rpm is way to high then the actual rpm.
im spinning it by hand and its reading around 21,000 rpm. this is way to high. im spinning it at around 60 rpm +or- 10 rpm
Unread 04-25-2012, 08:22 PM
You didn't multiply it by 360 did you? If not, The arduino board MIGHT somehow me picking up every encoder tick. If that's the case, divide by 360. (Notice that 21000/360 = 58.3)
Unread 04-25-2012, 08:23 PM
It would make sense, by the way, if it is. My code is for a hall effect sensor being used as an encoder that reads a screw once per revolution.
Unread 04-25-2012, 08:27 PM
Team Role: Driver
sorry if i was unclear but i was looking for code for a encoder that reads 360 positions per revolution compared to your 1 . no worries, all i did was divide your rpm by 360.
Unread 04-25-2012, 08:29 PM
So you got it working then? Dividing by 360 would be the solution I think.
Unread 04-25-2012, 08:40 PM
Oh, and I thought I'd caution you. There's a maximum read rate on the arduinos. It takes about 100 microseconds to take a reading, so it can read about 10,000 times/second. Since you're reading all 360 values every rotation, you've got a maximum of 27.78 rev/sec, or 1666.67 RPM. Not really sure what you're using it for, but keep that in mind.
Unread 04-25-2012, 09:32 PM
docdavies's Avatar
docdavies docdavies is offline
Doc Davies
FRC #0346 (RoboHawks)
docdavies is an unknown quantity at this point
Thank you folks. I found this thread very informative and useful.
We are also working to "off-load" more robot functions to an Arduino Mega.
Doc
Unread 04-25-2012, 11:32 PM
Team Role: Driver
are you sure its 1666? i went up to as high as 2000 multiple times in a row
Unread 04-25-2012, 11:36 PM
Team Role: Driver
i think the fastest i could spin it was 2100rpm
Unread 04-26-2012, 12:11 AM
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Actually, the Arduino mega maxes out at about 30,000 PPS. It can easily read 3500-5000 RPM depending on your encoder. Rather than sample at 1x/second, you might try sampling at 100x/second and adjusting the RPM accordingly. Here's an example:
File : turret.pde (opens in arduino IDE www.arduino.cc)
Description : Counts digital pulse on External Interrupt 0 (Digital pin 2) for 100 mseconds and prints the value via UDP
Date : 18th March 2012
Author : Mike Anderson FRC Team #116
Contact : manderson13@cox.net
// include the library code:
#include <SPI.h> // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUdp.h> // UDP library from: bjoern@cs.stanford.edu 12/30/2008
#include <SimpleTimer.h>
// Conversion of Analog value to degrees using U.S. Digital
#define ANALOG_TO_DEGREES 2.84
// Number of pulses per revolution on the shaft encoder
#define SHAFT_ENCODER_PPR 64.0
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(10, 1, 16, 9);
static uint8_t crio_ip[4] = { 10,1,16,2 };
unsigned int remPort = 8888;
unsigned int distance = 0;
unsigned int localPort = 8888; // local port to listen on
// buffers for receiving and sending data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
int iTestPin=13; //Pin which generates test pulses, this is not needed when actual pulse is available for measurement
int iPulsePin = 2; //Pin serving as external interrupt (INT 0) to count the pulses
static int siPulseCounter=0; //Variable keeping track of pulse counts
static int reportInterval=1;
static int multiplierFactor = 60 / reportInterval;
int sensorPin = A0; // select the input pin for the potentiometer
int sensorValue = 0; // variable to store the value coming from the sensor
int tmpDegrees = 0;
int oldDegrees = 0;
float tempFloat = 0.0;
SimpleTimer rpmTimer;
SimpleTimer hoodAngleTimer;
void sendRPM() {
tempFloat = (siPulseCounter / SHAFT_ENCODER_PPR) * 600.0;
Serial.println(siPulseCounter, DEC);
sprintf(packetBuffer, "1 %d\n\0", (int)(tempFloat));
// send a reply, to the IP address and port that sent us the packet we received
// Serial.write(packetBuffer);
Udp.beginPacket(crio_ip, remPort);
Udp.write(packetBuffer);
Udp.endPacket();
siPulseCounter=0; //Reset counter values for next minute cycle
void sendHoodAngle() {
sensorValue = analogRead(sensorPin);
tmpDegrees = (int) (sensorValue / ANALOG_TO_DEGREES);
sprintf(packetBuffer, "2 %d\n\0", tmpDegrees);
Udp.endPacket();
oldDegrees = tmpDegrees;
void setup(void)
// start the Ethernet and UDP:
Ethernet.begin(mac,ip);
Udp.begin(localPort);
pinMode(iPulsePin, INPUT); // Set Pulsepin to accept inputs
digitalWrite(iPulsePin, HIGH);
pinMode(iTestPin, OUTPUT); // Test signal generator pin as output. Can be ignored if the actual digital signal is available
attachInterrupt(0, count, RISING); // Caputres external interrupt 0 at iPulsepin at rising edge and calls funtion count defined below
Serial.begin(115200); // Begin Serial communication at baudrate 115200 bps
Serial.println(" Initialising, Please wait...");
rpmTimer.setInterval(100, sendRPM);
hoodAngleTimer.setInterval(250, sendHoodAngle);
void loop(void)
rpmTimer.run();
hoodAngleTimer.run();
/*** Following 4 lines just generate pulses for testing purposes.
All the 4 lines Can be ignored if the actual digital signal is available ***/
// digitalWrite(iTestPin, HIGH); // sets the iTestPin ON
// delay(1); // waits for a second
// digitalWrite(iTestPin, LOW); // sets the iTestPin off
void count() // Function called by AttachInterrupt at interrupt at int 0
siPulseCounter++; //increment the pulse count
/* End of turret.ino */
