Go to Post I think this just hit the nail in the head with a sledgehammer. - Yan Wang [more]
Unread 25-04-2012, 19:28
Looking Forward Looking Forward is offline
Honest Analysis
Rookie Year: 1992
Looking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond repute
Predictions Championship 2012: Einstein
From the four hundred teams loading in their robots today, only twelve will emerge from their divisions to compete on Einstein. Only three of those will scrape together the last four wins necessary to be crowned champions, giving everything they and their machines have left in the tank to do so. Robots will be beat up and far from their initial calibrations. The teams who can adapt on the fly and best avoid these issues will be the ones with the best odds. But all twelve teams will be well used to the rigors of elimination play by this point.
This game has the potential for absolute greatness at the highest levels. It also has the potential to be a disciplined and well controlled game, where starvation and ball control are more important than blasting away at the net at every given opportunity. When the top teams tango, it will come down to who can out execute the other. Expect smart play to prevail.
All twelve teams will be able to score three point buckets, and likely from the key (even if it isn't their preferred position). Each alliance will be capable of putting up 36+ points in hybrid in a good match, though it won't happen every match. All four alliances will have the capability to gun for the co-op bridge in autonomous, but in some cases it may be to prevent the other team from reaching the balls more than it is to score the balls themselves. All four alliances will have triple balanced to reach Einstein, and will likely chose to triple themselves instead of subjecting themselves to the judgement calls of referees when it comes to bridge defense.
Tele-op game play will have a focus on obtaining loose balls and avoiding putting any of the balls on the ground. Human loading may become a key factor for robots on the far side of the court, as it can save precious seconds compared to loading from the lane. Some alliances will opt to have robots pass balls forward, while others will opt for teams loading and crossing the field to score. Crossing the barrier will be hotly contested, especially after alliances scope out each others' strategies. Expect battles for loose balls and crossing the field, with teams trying to goad one another into taking a penalty via contacting the bridge or obtaining a lane violation. Teams that can rapidly change from crossing a defended barrier to hopping over their alliance bridge may have an edge.
As with any year, the participants on Einstein will be hugely impacted by the seeding in qualifications. This year, the seeding system is particularly volatile with the inclusion of coopertition points. It's going to take a perfect, or near perfect, QP to seed first and probably just shy of 30 of the 36 possible QP to be an alliance captain. This makes predicting how the tournaments will play out particularly difficult, but it won't stop me from taking a guess. Not to mention the loss of a "sure thing" bet in 177 (as well as Einstein regulars 217, who missed CMP by a single point in FiM, and 71).
ARCHIMEDES:
HOT utilizes their surefire coopertition skills to edge out the competition for the #1 seed. They select 2056 first and the Adambots with the last pick of the draft. They're significantly challenged along the elimination tournament, but 1114 is eliminated at some point due to a failed triple balance.
67/2056/245
CURIE:
The High Rollers stay close to undefeated and emerge as the top seed on Curie. They select Daisy, who seeded highly as well. The rookies from Indiana, 3940, round out the alliance. Other major contenders are split up pretty well, and despite some close calls the #1 alliance emerges from Curie in only 6 or 7 matches.
987/341/3940
GALILEO:
None of the major players go undefeated, but the Bomb Squad are still a mid seed captain. They select the Killer Bees, who showed promise but were inconsistent in qualifications, and 801 (the twin of 1592). The original "stinger" helps them triple balance quicker and more consistently than most of their foes, and some strong fender defense keeps their opponents off balance. It's close, but they emerge on top.
16/33/801
NEWTON:
A mid-major power seeds on top and claims D'Penguineers with the first selection. Las Guerillas seed 3rd or 4th and add Wildstang and Birds of Prey to their alliance. The deep Newton field provides plenty of challenge, but 469 and 111's dual assault and veteran tactics help them overcome the adversity.
469/111/181
EINSTEIN:
AvC and GvN in the first round.
987/341/3940 defeat 67/2056/245 in three, tightly contested matches. Daisy's hybrid proves the difference.
469/111/181 defeat 16/33/801 in two matches. Galileo simply can't match the speed and volume of Newton's offense.
469/111/181 top 987/341/3940 in three matches. A mistimed failure or hybrid miss costs Curie their chance at their first championship, while Wildstang gets their second in a row, fourth overall (to tie Beatty), and their second alongside 469 (2003).
These predictions are just a bit of fun. Neither these, nor the division threads, are meant to be comprehensive. Don't like 'em?
Go out there and prove them wrong!
Unread 25-04-2012, 19:40
penguinfrk's Avatar
penguinfrk penguinfrk is offline
AKA: Larry
FRC #1899 (Saints Robotics)
penguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of light
Re: Predictions Championship 2012: Einstein
Interesting, no specific comments on triple balance except on Galileo.
Looking forward to how it all actually turns out!
Larry
Saints Robotics 1899
High school intern at FIRSTWA
2011 Seattle Olympic Regional:
Website Excellence, FIRST Dean's List Award (for team captain Kevin Kimura), Tournament Winner (Thanks 3393 and 2990!), Chairman's Award Winner
Unread 25-04-2012, 19:42
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Looking at past Einstein predictions, it looks like usually one alliance has the captain and first pick correct. IMO the alliance of Daisy and High Rollers looks to be most likely. It'll be interesting to see how Archimedes plays out with 2056, HOT, and Simbotics.
However, I don't see the winner of Curie/Archimedes(assuming the alliances are close to what's here, ie. HOT with 1114 instead of 2056, or any other combination of the three) NOT winning Einstein overall. Especially if 987/341 are with 3940. Part of me also thinks that the 16/33 combo would defeat the 469/111 combo...unsure about that one...
Unread 25-04-2012, 19:43
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
Nice predictions LF.
So im not completely convinced that Curie defeats Archimedes though. Its a very close call it seems.
Einstein this year is going to be very close and a failed balance or hybrid will determine it.
Good luck teams.
Steve
-Programming Mentor
- Team 578 Alumni
Unread 25-04-2012, 19:44
Andrew Lawrence
Posts: n/a
While I love LF's predictions, it's crazy how accurate they are, and I want to see Las Penguinauts emerge victors from Newton. (469, 1717, 118)
Looks like the next few days will tell if LF is right once again.
Unread 25-04-2012, 20:07
Norman J's Avatar
Norman J Norman J is offline
Killer Bee
FRC #0033 (Killer Bees)
Norman J is a splendid one to beholdNorman J is a splendid one to beholdNorman J is a splendid one to beholdNorman J is a splendid one to beholdNorman J is a splendid one to beholdNorman J is a splendid one to beholdNorman J is a splendid one to beholdNorman J is a splendid one to behold
Uh, implying any of those three is a third pick? If this happens, I'll swallow a sword.
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
The field would have to be blind, deaf and insane to let that combination happen, 2 of the 3 maybe. I doubt any of those teams will make it past the 17-18ish range.
Unread 25-04-2012, 20:11
Andrew Lawrence
Posts: n/a
A guy can dream, can't he? Realistically, it'll most likely be a wide feeder bot that can back up the two high scoring machines and will enable a triple balance simply and effectively.
So Las Penguinxxxxx?
Unread 25-04-2012, 20:27
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Las penguinkats!
45 is hopeful
461 Westside Boiler Invasion
45 Technokats
Unread 25-04-2012, 20:35
FRC #1836 (MilkenKnights)
Honestly, the chance of 1717 or 469 not seeding 1st, is very, very low. Of course there is luck.
Unread 25-04-2012, 21:32
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
You can never count on any team, no matter how strong, to seed first. If you look at just last year, you'd have expected teams like 1114, 2056, 111, 71, 67, 118 or 33 to have seeded first in their divisions. However, none of them did, and last year mostly consisted of teams no one expected to seed first!
Maybe my example is flawed, but the point I'm getting at is, rankings are largely based on schedule. Even if 469 or 1717 coop balance EVERY MATCH, losses can still bring down their rating. Especially on a deep field like Newton, expect the first seeded team, not to be the best team, but the team that pulls the best schedule related to their ability.
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
Unread 25-04-2012, 22:49
stundt1's Avatar
Steve
To add to your statement Co-op adds another way for upsets to occur. Such as the 1114 and 2056 splitting up. Teams with a great schedule can wiggle themselves up in the rankings.
Newton seems very leveled and its pretty hard to predict the outcome on a deep field. 1 qualification match could make all the difference in the outcome of pretty much any field.
Don't expect those teams to always get the first seed in the divisions.
Steve
-Programming Mentor
- Team 578 Alumni
Unread 26-04-2012, 01:16
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
I'm curious about those second round picks. I would not expect to to see some of those teams on Einstein.
Unread 26-04-2012, 01:23
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Did you expect to see 1139 on Einstein in 2006? 3357 in 2010? 348 in 2008? 1270 in 2007? 177 in, well, almost any of the years they made it?
Unread 26-04-2012, 02:02
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Will DFS (dead Field Syndrome) strike Einstein this year? Or any other divisions?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
