Go to Post I can't help but notice during the building sequence, there were a whole lot of student hands working on that robot. Just sayin'. - Taylor [more]
Unread 09-01-2003, 19:12
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
When we all say "drill motor" yes that's the one we mean. But we usually refer to it with the gearbox attatched (longer brown box same bag) as the motor is almost never used by itself. The gearbox has a high and low speed shift selector. For a rookie team, I would recomend locking it in place and not shifting during the match. Check out these links
Gear Ratios
FIRST Drill Motor Gearbox Exploded View
There is also the option of using the Chiaphua (Atwood, CIM) motors which have a coupler provided but no mount.
The rpms and gear reductions for the drill motor can be found in the Kit section of the Robot Rules. The Chiaphua motor specs have been posted as an attatchment in another thread here on Chief Delphi.
If you want to use all four motors. Match their free (no load) top speeds. Your rpm will be th number you match them at. The number you will actually get in performance will be a little lower so design with that in mind. You will get the torque of both motors combined plus whatever you get through a reduction.
Also, look thorugh the white papers on this site as they are very helpful. Just remember, I would not recomend shifting for a rookie team. (This is our third year and we are still too scared to attempt it)
Hope this helps,
sanddrag
question on launching boxes 2PI4Julia Rules/Strategy 4 18-01-2003 10:17
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
