Go to Post I've got a couple team members who have an incredible knack for destroying robot parts... - Tom Line [more]
View Poll Results: Was this useful?
Yes, it was! It helped point out diamonds in the rough 109 70.32%
No, its numbers generally did not correspond to robot's actual on-field performance 46 29.68%
Voters: 155. You may not vote on this poll
Thread Tools Rating: Thread Rating: 32 votes, 4.88 average. Display Modes
  #286   Spotlight this post!
Unread 26-04-2012, 20:09
MoHottaMoBetta's Avatar
MoHottaMoBetta MoHottaMoBetta is offline
AKA: Bruce Kahn
FRC #0842 (Falcon Robotics)
MoHottaMoBetta is an unknown quantity at this point
Re: Easy to use Offensive Power Rankings (OPR) program for mid-regional scouting
I just tried to use OPRNet 25 on a couple of the divisions at the current Championships and it is not happy with something:
3 [C:\Downloads\OPRNet25] oprnet arc 2012 opr r
Temporary file created
URL opened
Downloaded 1024 bytes
Downloaded 1245 bytes
File download complete
Parsing!
No matches found. This regional may not have run yet, or may have HTML output that the parser does not recognize.
Failure to parse XML. Code: -2147467259
Press any key to continue . . .
3 [C:\Downloads\OPRNet25] oprnet new 2012 opr r
URL opened
Parsing!
Is anyone else seeing this? (I know there is data as I can see it on the FIRSt site.) Just thought I would ask before I try to dive into the source.
  #287   Spotlight this post!
Unread 27-04-2012, 01:22
The Lucas's Avatar
CaMOElot, it is a silly place
URL opened
Parsing!
I had that issue. Just use the full division name (e.g. newton). OPRnet just uses whatever string you type into that parameter as part of the URL. The New FIRST website no longer redirect the division abrieviations (e.g. new) to the correct URL.
On a side note, the OPRs of the Divisions Thursday night are pretty much worthless. With only 3-4 matches completed for 100 teams, the matrix is barely solveable. Expect lots of redculously high and low numbers
Robot Inspector
  #288   Spotlight this post!
Unread 27-04-2012, 01:41
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
lol, I ran the numbers earlier just to see how they were looking for Archimedes, and yeah... they seem, how should we say... less than accurate.
  #289   Spotlight this post!
Unread 27-04-2012, 08:31
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Yeah, the numbers probably won't be usable until teams' 6-7th matches. I wish I knew more stats and could give error bars on team's OPRs, that'd be handy. It's just a simple linear regression, I'd think the math on how to get confidence intervals would be straightforward, but I haven't found it.
  #290   Spotlight this post!
Unread 30-04-2012, 21:39
AKA: Bruce Kahn
I found it took until the 7-8th matches to settle down enough to be usable.
For fun I also had it predict the Saturday AM matches for all 4 divisions. It correctly predicted 72.72% of the Archimedes matches and a few were pretty dang close to the predicted score. I will check how well it did on the other 3 divisions if anyone is interested.
  #291   Spotlight this post!
Unread 01-05-2012, 15:39
It might be more complicated than you think. Consider the following problem:
http://www.chiefdelphi.com/forums/sh....php?p=1165314
  #292   Spotlight this post!
Unread 14-03-2013, 12:32
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Sorry for thread bumping if this is a dead channel, but I'm curious as to where I could find the OPRNet.exe for this season.
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
  #293   Spotlight this post!
Unread 14-03-2013, 12:36
the previous version still works, as long as you apply the new event codes.
  #294   Spotlight this post!
Unread 14-03-2013, 13:08
fr05ty27355's Avatar
fr05ty27355 fr05ty27355 is offline
AKA: Paul
FRC #2169 (KING TeC)
fr05ty27355 is on a distinguished road
Where can I find the new event codes?
Innovation: The best way to predict the future is to create it - Peter Drucker
FTC: 3855 Tempered Steel
2010 - Minnesota Snow Drift - FTC Winning Alliance
2010 - World Championship - FTC Finalist Alliance
FRC: 2169 KING TeC
2013 - MSHSL State Championship - Finalist Alliance
2013 - Galileo Division - Finalist Alliance
2013 - Colorado - Winning Alliance
2013 - Northern Lights - Winning Alliance
2012 - MSHSL State Championship - Winning Alliance
2012 - Wisconsin - Finalist Alliance
2012 - Lake Superior - Regional Chairman's Award
2012 - Lake Superior - Winning Alliance
2011 - 10,000 Lakes - Finalist Alliance
2011 - Lake Superior - Regional Chairman's Award
2011 - Lake Superior - Finalist Alliance
2010 - 10,000 Lakes - Regional Chairman's Award
  #295   Spotlight this post!
Unread 14-03-2013, 13:09
http://frclinks.frclinks.com/
  #296   Spotlight this post!
Unread 14-03-2013, 13:16
Bongle's Avatar
Sweet!
Because I don't have the time anymore to update it
Couldn't even make it to montreal with 2702
  #297   Spotlight this post!
Unread 14-03-2013, 13:23
Thank you, I'll give it a shot!
Founding Member
  #298   Spotlight this post!
Unread 14-03-2013, 13:40
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
Doesn't work for me... It doesn't allow me to use the new codes. For example, whenever I type "ista" it reprints the list of old codes.
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
  #299   Spotlight this post!
Unread 14-03-2013, 13:53
I got it to output the raw OPR for Oregon correctly. It's just weird that it has an option to select bridge points :S
I would love to be able to sort by hybrid, climb and do everything from last year. Maybe I'll need to take a look at the source code and see how hard it would be to bring it up to speed with 2013.
I don't know if I'm up to the task, but I'd certainly like the data
Founding Member
  #300   Spotlight this post!
Unread 14-03-2013, 13:56
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Does it allow for week 2 events? I tried everything for Orlando and then tried San Diego to just make sure I wasn't doing anything wrong and it failed every time.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Offensive Power Ranking Calculations Greg Marra General Forum 4 18-03-2009 22:03
Offensive Power Rankings for 2008 Bongle General Forum 166 18-05-2008 15:05
Offensive+Defensive Power Rankings BornaE General Forum 4 05-04-2008 01:33
2006 Offensive Power Ratings sw293 General Forum 16 10-05-2006 17:04
(CURIE) Let's make this Easy for all of us. [scouting] 157#1Driver Championship Event 13 22-04-2002 08:56
