Go to Post Different approaches to the same problem. Isn't it better to focus on understanding both than to be dogmatic about it? - Greg McKaskle [more]
Unread 27-04-2012, 18:32
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
Re: 100% CPU usage and double timeout bug
I'm not sure about the double timeout as a cause, but I've seen the effect you've described this year. After some optimization, our code uses about 50% of available CPU, but we still need to use the No-App switch to deploy new code, or we time out during deploy:
1) Flip switch to No-App
2) Software reboot robot
3) Deploy built LabVIEW project
4) Flip switch away from No-App
5) Software reboot robot
I've also seen intermittent instances where for some runs the machine will be pegged to 100% cpu, but the issue will not repro once we reboot the machine.
