Go to Post Right, play to win. Play to win the event or play to win one match? This year, unfortunately, they are not the same thing. - Paul Copioli [more]
Go Back   Chief Delphi > Competition > Championship Event
  #136   Spotlight this post!
Unread 27-04-2012, 19:46
Re: Archimedes 2012!
Originally Posted by NickTosta View Post
Hmmmm. While it does sound like something should be done about that, there are two issues I see:
1. We need to bring this to someone's attention, someone with the power to correct it
2. We need to prove that it happened
I think the problem is that nobody knows who to talk to, and nobody knows if any concrete evidence (pictures, videos, etc.) exist at the moment. I'm not sure how anyone would go about either of those. Any thoughts?
First, I know who you'd talk to. The head ref and/or the scorers. The problem is, you need the drive team to talk to the head ref. The pre-college members of the drive team. And you'd most likely need it to happen in the match.
You could try finding a GDC member, but that's going to be difficult to find them, difficult to convince them that it happened, and then they get to convince the head ref/scorer to fix the scores.
Second, especially regarding evidence: The head ref will not review evidence per [T13]. You need to raise doubt in his mind that he's been calling this correctly, and possibly get him to contact GDC members present for clarification.
  #137   Spotlight this post!
Unread 27-04-2012, 20:19
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
Guys are the rankings weird for you too? http://www2.usfirst.org/2012comp/eve.../rankings.html
Steve
-Programming Mentor
- Team 578 Alumni
  #138   Spotlight this post!
Unread 27-04-2012, 20:33
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Yes, all entries are duplicated. It wasn't like that earlier in the afternoon.
Awards are still empty.
  #139   Spotlight this post!
Unread 27-04-2012, 20:37
stundt1's Avatar
Steve
I wish they posted the score for the last 1114 match does anyone know who won that match? It was the last match of the day.
Steve
-Programming Mentor
- Team 578 Alumni
  #140   Spotlight this post!
Unread 27-04-2012, 20:41
speedbuggy76 speedbuggy76 is offline
Manellis
AKA: Matt Ellis
FRC #0118 (The Robonauts)
speedbuggy76 is a jewel in the roughspeedbuggy76 is a jewel in the roughspeedbuggy76 is a jewel in the rough
1114 lost that match after not moving for much of the match. I forget if there was a coop or not
Mentor for Team 118 - The Robonauts
Former mentor of 2415 - The WiredCats
Former member of 1002 - The CircuitRunners
  #141   Spotlight this post!
GaryVoshol's Avatar
Cogito ergo arbitro
[G41]
If a Robot from each Alliance is Balanced on the Coopertition Bridge when the final score for a Qualification Match is assessed per Rule [G37], each Alliance earns 2 Coopertition Points. If the Coopertition Bridge is not Balanced, but a Robot from each Alliance is fully supported by the Coopertition Bridge, each Alliance will earn 1 Coopertition Point.
(emphasis mine)
By definition the bridge is not balanced because another robot is touching it. Yet there are two robots, one from each alliance, that are fully supported by the bridge.
I'm wondering if it was being called wrong all season long, and it's correct now.
(since 2004)
  #142   Spotlight this post!
Unread 27-04-2012, 20:51
Manellis
AKA: Matt Ellis
Originally Posted by GaryVoshol View Post
(emphasis mine)
I didn't see these matches this morning, so I'm not quite sure what happened. I'm assuming there were two robots trying to get on the bridge, and they slid down and one of their bumpers stopped them both from rolling further. It sounds to me like you're saying there were three robots involved?
  #143   Spotlight this post!
Unread 27-04-2012, 20:52
Chris's Avatar
Chris Chris is offline
So apparently it hangs......
AKA: Chris Carnevale
FRC #0177
Chris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond repute
This occurred at CT also and involved Team 118 (and whom ever else was in the match i don't remember the teams).
Team 118 went up to the ref's immediately after the match and pointed out the error. That they had received a co-op point when they shouldn't have. Later in the day the referees stopped by the pit and 118 was told "merry Christmas" its too hard to go back and fix.
This is the only reason 118 was 2nd and 177 was third. (didn't end up mattering at all since we were pretty sure 2168 was going to pick 118 and we'd end up picking second no matter what).
I never went back and figured out if it affected anyone else in the top eight (i wouldn't be surprised if it did).
Hopefully if the points were incorrectly awarded you have better luck.
Chris C.
Team 151 | Alumni | 2000-2002 | Nashua High School
Team 229 | Alumni | 2003-2006 | Clarkson University
Team 148 | Alumni | 2007 | RackSolutions.com
Team 177 | Engineer | 2008-? |
  #144   Spotlight this post!
Unread 27-04-2012, 21:03
GaryVoshol's Avatar
Cogito ergo arbitro
I have no idea - I was only commenting on what I read here. If it was just 2 robots, one touching the carpet, then coop points should not be awarded.
I note that only on Archimedes are there odd coop points - and there's quite a few of them. It appears that the fields are not doing things in the same way.
(since 2004)
  #145   Spotlight this post!
Unread 27-04-2012, 21:36
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
We witnessed a similar situation after Match 129. Immediately after the match, we noticed that both alliances received a single coopetition point despite that one of the robots attempting to balance was obviously touching the ground. We approached the head ref following the match, and the response our student representative was given was that he was going to converse with the Chief Referee about it.
After getting back to the hotel, we noticed that the score for match 129 was no longer posted, the standings seem to be duplicated, and the single coopetition point was removed from all teams in match 129.
We plan to bring the remaining matches in question to the head ref's attention tomorrow morning, as this currently affects whether 2826 or 3481 is the number 1 seed on Archimedes.
I’m sure the referees will do their best to sort out this confusion and get the bridge points awarded properly.
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
  #146   Spotlight this post!
Unread 27-04-2012, 23:08
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
We've been having some coms issues plaguing us. After our last match today, we found our gyro was shorting out. This was causing multiple issues with the digital sidecar.
Hoping for the best tomorrow. Our accuracy and speed has been consistent with our past performances, unfortunately the controls issues slowed us down a bit.
  #147   Spotlight this post!
Unread 27-04-2012, 23:56
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
Interesting, a team who was not involved in the match went to the head referee to dispute the call. Judging from the rules all rulings are final once the head referree gives the okay to clear robots and nothing can be changed. Even with video and photographic proof. It should be interesting to see how this plays out tomorrow.
My posts are solely my own and do not necessarily reflect the views or opinions of FIRST® or my affiliated team.[/center]
FRC® Kit of Parts Engineer: 2014-Present
Team 238: 2016-Present
Team 1403: 2008-2014
  #148   Spotlight this post!
Unread 28-04-2012, 00:12
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
I don't think this is true - considering how fast field resets are this year, it would essentially prevent any changes from being made. The rules even call for questions to be asked after said "okay"...
[T14]
If a team needs clarification on a ruling or score, a pre-college student from that team should address the Head Referee after a field reset has been signaled. An team signals their desire to speak with the Head Referee by standing in the red or blue Question Box which will be placed on the floor at each end of the scoring table. Depending on timing, the Head Referee may postpone any requested discussion until the end of the subsequent Match.
[T13] indeed bans viewing of "recorded replays", but actually says nothing about photos. Do you know if either was presented?
Does anyone else remember when TBA signatures actually worked?
  #149   Spotlight this post!
Unread 28-04-2012, 00:18
[T13] states that all head referee rulings are final. However, it gives no timeline. If all rulings were absolutely final, carved in stone, no review, as soon as the all-clear sounded, then there would be no real point to [T14].
So: [T13] says, all head referee rulings are final, no recorded replays will be reviewed.
[T14], however, gives teams the right to a clarification of calls made on the field and a procedure to get the clarification. Much of the time, this clarification results from a team's misinterpretation of the rule in question. Some of the time, however, the referee is actually mistaken or wrong. He can get input from outside sources, including the GDC (which includes the Chief Referee and Volunteer of the Year, Dr. Aidan Browne) per [G13]. When the input comes in on a call that is asked about, the head referee has to make a call--either he was right, or he was wrong and what he will do about it. Note that in this case, the Head Ref indicated that he would in fact consult with the Chief Referee.
If the head referee rules that he is right, see [T13]. If the head referee rules that a mistake was made, then he will say, "I made a mistake. We will do X to fix it." Now see [T13] again. That will be the final ruling.
In the case of a team not involved in the match asking for clarification, [T14] does not specify that the team has to be involved in the match. It just says, "If a team needs clarification,". Obviously, the team in question needed clarification, and [T14] not restricting this to teams involved in the match, they addressed the Head Referee as per protocol.
I think everything in this one was within the rules and the Head Referee's authority, and we'll see what happens with the other matches tomorrow morning.
  #150   Spotlight this post!
Unread 28-04-2012, 01:08
JB's Avatar
JB JB is offline
AKA: Jon Bryant
FRC #0238
I know for a fact the will not take photo evidence. At one of our events we had a balanced bridge not counted as balanced and the refs refused to review photo's.
