Go to Post Driving without the trailer was quite fun, but driving with the trailer was just painful. - Paul Copioli [more]
Unread 28-04-2012, 23:01
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
The communication tides are shifting...
After today's lack-luster performance from the FMS on the Einstein field, many people are beginning to lose faith in the FMS and current mode of communication. I happen to be one of them. Problems began at Regionals, and were exacerbated on Einstein. Common sense says that if a robot and DS ran fine in Match 1, if nothing changed between Match 1 and Match 2, the robot should preform just as well in Match 2. Unfortunately, this was not the case.
It might be time for FIRST to shift from their current setup to a more robust and reliable way for robots to talk with the field and DS's.
What say you?
Unread 28-04-2012, 23:04
Racer26 Racer26 is offline
Re: The communication tides are shifting...
Never should have moved away from the IFI system.
The current cRIO is a solution akin to using a sledgehammer to drive a finishing nail. Sure, it works, but its clunky.
Unread 28-04-2012, 23:05
FRC #0023 (PNTA)
Rookie Year: 1620
Wasn't the cRIO initially designed to be used in an industrial setting as a data logger?
Unread 28-04-2012, 23:06
shawnz shawnz is offline
Flamewar Initiator
FRC #0907 (E. Y. Cybernetics)
shawnz will become famous soon enough
I think the idea of using Wi-Fi is mostly fine, but the hardware we're using for it (d-link consumer products) isn't the most robust ever. I personally think the cRIO is a godsend over the old PIC18 stuff.
Unread 28-04-2012, 23:11
If they really want to stick with a TCP/IP based solution, they should run it on the licensed 3GHz band, using gear like the stuff made by Ubiquiti Networks.
Unread 28-04-2012, 23:23
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
It's a real time industrial control system. It's plenty hardy enough for what we're doing and the treatment we're giving it. I'm seriously doubting this is a hardware problem with the cRIO. It's possible it's a software problem with the cRIO or FMS, but the most likely answer really seems to revolve around our consumer-grade WiFi radios. The fact that a firmware change on the router causes massive communication problems is pretty troubling, really.
Unread 28-04-2012, 23:28
Andrew Lawrence
Posts: n/a
/sarcasm/ Yes, let's get rid of the crio and never again using vision processing or any of the cool advanced things introduced with it. /sarcasm/
The crio isn't the problem. It's the connection with the field.
I'm all for a new piece of equipment that better connects to field, but first we have to find one. Something we implement in our team is "don't shoot down an idea unless you have a better one".
So, get your heads a cracken and those brains a moven. Let's find us a new bridge.
Unread 28-04-2012, 23:29
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Exactly. We're having data processed on an industrial-grade controller with a consumer-grade transmitter. That's the problem I see. I think the best we can hope for right now is that next year in the KOP we get a nice new radio that's much much more powerful than the one we currently have.
Unread 28-04-2012, 23:30
FRC #0023 (PNTA)
Rookie Year: 1620
If the issue actually does stem from our radios, why was this issue not uncovered in 2009 when FIRST switched over to TCP/IP?
Unread 28-04-2012, 23:36
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
Not sure how your team is doing vision processing... Most teams use the laptop for that to not reduce robot performance... Also, there was vision processing before the C-RIO. Look at Rack 'n Roll (2007)...
Anyways, C-RIO needs to stay. The kit needs some updates with more safety protection (built in) for the thousands of dollars in electronics we have. WI-FI will stay. It's secure and quick. The current problems lie within the field system. Also, the paranoia about wireless work in the pits needs to stop. If the system can't handle wireless pit work, then they are doing something wrong...
Flamewar Initiator
Well, aside from the fact that different wireless bridges were used in 2009, the problem may represent a more complete usage of the platform by teams now than there was then.
Unread 28-04-2012, 23:37
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
a new model came out this year. so they obviously activated the code to break old ones so everyone byes new ones.
a team by us had random communication issues from the beginning of the year. They tested the bridge on two separate robots, made a thread here asking for advice, but nothing stopped it. the communication seemed to drop out randomly
cole?
Unread 28-04-2012, 23:39
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
We actually lost in CT that year to comms issues only uncovered well after the regional, albeit due to irregular coding structure.
In 2010, the radio used was much simpler. The question, really, is what changed between 2011 and 2012 that caused this disaster.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 28-04-2012, 23:40
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
a few reasons:
1. there were packet size rules, which limited bandwidth, hence why until 2011 nobody really used a live camera feed.
2..they were using different radios (linksys gaming adapters) 2009-2010. 2011 was the introduction of multiport bridges, which allowed the bypass of the cRIO for camera feeds. The reason it became an issue this year might be because the bypassed camera trick wasn't stock in the code in 2011 but was in 2012, resulting in more team using the live camera feeds and in turn increasing the load on the communication equipment.
Unread 28-04-2012, 23:41
foote stepped in
AKA: E. Foote
FRC #0868
I think we need find a radio supplier that will show up at each of the competitions to help us through our troubles.
Also, there needs to be a better way to diagnose the entire system. Event logging in the radios would help.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
