Go to Post Work hard. Then work even harder. Work until there is nothing left to work on, then work more. - RoboChair [more]
Unread 07-01-2003, 17:17
chrisw chrisw is offline
chrisw is an unknown quantity at this point
Send a message via AIM to chrisw
weight distribution?
going up hill on the ramp, where should most of the weight be (front or back of the robot)? and what are the advantages and disadvantages?
~ chris ~
Unread 07-01-2003, 17:26
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
The optimal weight distribution (placment) for this game would be low and and close to center on the robot as possible. You do say going up the ramp (which would require a more forward weight) but since this game would requuire going up and down the ramp in different situations, one would want a balance of the two... which is centered and low to the ground.
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
Unread 09-01-2003, 21:45
HolyMasamune's Avatar
HolyMasamune HolyMasamune is offline
41246017 O-('_'Q)
AKA: Y C
None #0840 (Aragon Robotics Team)
HolyMasamune is on a distinguished road
Send a message via AIM to HolyMasamune
Although going down the hill, you won't need as much power because gravity is also helping pull you down. I like the fact that the weight should be low though, but as for the center, there is a little bit of leeway you can play with.
Unread 11-01-2003, 13:25
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
Low and centre is the basic rule for weight distrib..
But, you also want to have weight over your drive wheels (if you only have 2) so they will skip less. Of course if you have 4wd, then low and middle holds true.
But, keep in mind that the "middle" is an average of all the weight on the bot. Like if you have something hanging off the front of the bot, you might want to mave everything back slightly in the bot, so that the average of the 2 weights is the middle.
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Q&A Discuss: parts as dead weight? CD47-Bot Extra Discussion 3 24-01-2003 12:30
ball weight? Gadget470 OCCRA 4 02-10-2002 17:24
Weight Distribution Mechanism in Tread System? Kai Zhao Technical Discussion 8 20-08-2002 16:38
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Robot dimensions & weight restrictions revealed? Mike Soukup Rules/Strategy 4 24-10-2001 20:51
