Go to Post And to think, a lot of students are planning parties and celebrations on their last day of school and you guys are recycling trash. - JaneYoung [more]
Unread 30-04-2012, 01:15
Meshbeard's Avatar
Meshbeard Meshbeard is offline
Previously of 422
AKA: Jonas
FRC #0190 (190)
Meshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to all
Robot Lighting
Our team is looking into putting some lighting on our robot next year. If any teams that have previously done so would like to offer some advice, it would be much appreciated.
I know team 118's robot had some nice lighting this year, and team 148 always has underglow on their robot.
Unread 30-04-2012, 01:48
davepowers's Avatar
davepowers davepowers is offline
Currently dreaming about robots
AKA: Danger Dave
FRC #1687 (Highlander Robotics)
davepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud of
Re: Robot Lighting
It all depends how in depth you want the lighting to be. I know 118 used their lighting to signal their and other drivers of various things. This year we toyed with using our LED lighting to alert our drive team when we had balls in our elevator. You can use Audrino boards to make some pretty cool custom features. I'm not an expert on that stuff, but if you're really interested I'm sure someone on here can charm in.
As far as the lights themselves go, you have three choices, a static color and strip, RGB LEDS, and Addressable RGB LEDS. This year we stuck with a static white color just to give a little extra aesthetic appeal to our bot. In previous years, we've used RGB LEDS with success.
Purchasing and installing the lights after choosing which lights and features you're shooting for is the easy part. Many cheap LED strips, static, RGB, and Addressable can be found here.
From there the sky is the limit, here's a picture of GUS' 2012 competition robot.
-D
David Powers - Deans List Finalist - WPI 17' - Bleed True Clothing
1999-xxxx FRC228, GUS Robotics Inc.
2013-xxxx FRC1678, Highlander Robotics
Unread 30-04-2012, 03:38
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Robot Lighting
This year, our team used LED lights to:
- indicate whether the target is to the left, to the right or just right. This is so that the drivers don't have to look at the laptop screen for the video stream.
- indicate the shooter speed is within tolerance of the target speed, so the drivers can shoot consistently.
- indicate various teleop modes (e.g. fully automatic, semi automatic and full manual).
Our LED lights strips are connected to the solenoid module and we have written a generic light control module that allows the caller to either turn the light solid ON or OFF, or specifies any blinking patterns (e.g. 3 long blinks, 2 short blinks and repeat the pattern etc.). The module even supports RGB so it can specify what color combinations in the blinking pattern. In theory, we could even do pulse width modulation on the RGB lights to get many colors but we haven't tested if it actually works.
Unread 30-04-2012, 17:15
Meshbeard's Avatar
Previously of 422
AKA: Jonas
FRC #0190 (190)
Re: Robot Lighting
Thank you for the information! Is electroluminescent wire at all feasible?
Regarding the Arduino, would the Arduino just be powered out of the PD board? Is that legal?
What is the benefit of using the solenoid module as opposed to the relay outputs on the digital sidecar?
Unread 30-04-2012, 17:37
mikets's Avatar
Software Engineer
Re: Robot Lighting
I am not familiar with the power interface of electroluminescent wire but it seems it is powered by high AC voltage (90-120V 1000Hz) so it needs a power controller. If you manage to interface 12V DC to this power controller, it may be feasible. Searching the Internet, it looks like they sell these with a power controller that can take AAA batteries. So in theory, you could DC-DC convert 12V to whatever battery voltage the power controller uses.
Relay is mechanical, since we are trying to play with pulse width modulation on the RGB lights, relay has a limit of how fast you can turn the light on and off. BTW, in case you worry about whether the solenoid channel can power the LED lights, each solenoid channel can source up to 0.75A current, an LED light strip generally consumes about 100mA.
Unread 30-04-2012, 19:18
Miqi Miqi is offline
FRC #0422 (Mech Tech Dragons)
Miqi is an unknown quantity at this point
Re: Robot Lighting
Also, this exists.
http://www.lighttape.com/
It's what they used in Tron Legacy.
Unread 30-04-2012, 19:59
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: Robot Lighting
We've had good luck with using Arduinos and RGB addressable LED tape like this stuff:
http://www.adafruit.com/products/306
The Arduino can only source 40ma on one digital out. So, you'll likely have to create your own power transistor circuit if you want to trigger more than a simple LED.
Good luck and enjoy the lights!
Unread 30-04-2012, 20:07
gracie.'s Avatar
gracie. gracie. is offline
forgot the heat shrink...
FRC #2399 (The Fighting Unicorns)
gracie. is an unknown quantity at this point
Re: Robot Lighting
I have a little too much fun with lighting. We typically use cold cathodes, they're easy to attach and are great for underglow. They're REALLY bright. I didn't get to during competition, but I put some in our conveyor system and they look great!!! (I'll see if I can find a picture) This year, as a new thing we used el wire. That also worked really well. It's not quite as obviously bright as cathodes, though I'm sure it would be more noticeable if you bunched it up. We used it to trace designs on the shielding for the electrical board. It was also very easy to attach and wire.
2399: The Fighting Unicorns! - Alumna, team sister | Dean's List Finalist 2013
Anyone need a mentor in west LA?
Unread 30-04-2012, 22:55
RevonZZ
Posts: n/a
Re: Robot Lighting
Team 2016 used lighting in the shape of the FIRST logo elements last year. They were separately illuminated, allowing the human player to know which tube to feed, and all of them lit up when the robot acquired a tube.
We've also had some blue lighting on our robot since Breakaway. Must say... our robot's blue glow looked really nice next to 148's red at the 2010 Dallas Regional.
Unread 03-05-2012, 16:37
Johnny_5's Avatar
Johnny_5 Johnny_5 is offline
Whose cooking motor?
AKA: Isaac
FRC #3484 (Short Circuit)
Johnny_5 has a spectacular aura aboutJohnny_5 has a spectacular aura about
Re: Robot Lighting
In regards to this addressable strip, I saw that you must use a micro controller to use the lights. Instead of using an Arduino board couldn't you use a DIO off of the sidercar?
You fried..... another...... jaguar!
2011 CAMM CORI Robotics Invitational Runner Up Alliance
Unread 03-05-2012, 17:11
Software Mentor
AKA: Mike Anderson
Re: Robot Lighting
Yes, you can use a DIO off of the sidecar. However, we frequently find ourselves in the situation where we're maxing out our sidecar with limit switches and the like. So, if you've got the pins, use 'em ;-).
Unread 03-05-2012, 17:31
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
Re: Robot Lighting
We added our lighting very late this year at Championship due to making sure we had weight for it.
We used the addressable LED strip from Adafruit, as we did last year. This was controlled by an Arduino Uno R3, which was sent commands to change mode from our robot software through I2C. We were in danger of maxing out the available digital I/O ports early in the season, but had planned to use an Arduino anyway. I2C is available and keeps other robot-useful ports open, and has built in SPI support which is the fastest method of communicating with the LED strip.
Once we had the I2C figured out, it was easy after that.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 03-05-2012, 17:45
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
Re: Robot Lighting
this year, we went to the local auto shop and grabbed some lights meant to "pimp out" cars.
It u put lights on it, judges seem to like fancy lights that also have practical purpose. one practical use we had this year was lighting up the path the ball went through so we could see the number of balls in the hopper through the smoked polycarb we used for our sides.
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
Unread 03-05-2012, 20:07
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Re: Robot Lighting
Appreciated!
The lights were first put on the robot to look cool for the video, but it wasn't until we found an actual use for them that we were able to get the momentum to actually integrate them electrically.
We used an Arduino Uno to talk to this LED strip (mentioned above). The interface between the cRio and the arduino was some of the relay outputs on the sidecar. Specifically, there was one relay output (two bits) to run the lights for our co-op assist feature, and another for the fancy lights that fired when we picked up or shot a ball.
At championship, we added a switch to tell when the stinger was touching the ground, and wired that directly into the Arduino, which was simpler and makes a lot of sense, because we weren't doing anything else with that data.
Cheap additional processors like the Arduino hold a lot of promise for enhancing the possibilities for sensors on these robots that might have been limited by the number of inputs in a sidecar. I know that we explored some redundancy in our sensing this year, and that can exhaust the digital and analog input ports very quickly. A good off season project might be to explore interfacing something like the Ethernet Arduino with the cRio in order to fully exploit these possibilities.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 03-05-2012, 20:41
Re: Robot Lighting
That depends, some products actually need a high voltage module to turn them on. This would come under the custom circuit rules and for obvious reasons would be looked at very carefully from a safety standpoint.
Some of yo on Newton may have noticed that WildStang finally mounted it's LED strings at Champs again this year. What you may not know is that several different feedback schemes were programmed into the string. In addition to sound controlled lighting, there were other driver feedback patterns included as well. Mentors and students are in the process of writing up the system to provide to the First community. Please be patient, they are shooting for IRI at the latest.
