Go to Post I like my eyeballs where they are ::safety:: - ,4lex S. [more]
Unread 18-02-2012, 19:28
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Cross Hairs on Camera in C++
Anyone know how to do this?
We are not going to do vision tracking instead our robot is low enough there we will line it up manually with our lazy susan. we need the camera to center on the bottom hoop. We need the center cross hairs to do this though on the laptop. we are not going to use tape we have tried that in the past and havent had good results
Unread 19-02-2012, 09:20
Re: Cross Hairs on Camera in C++
Please search, I answered a similar post a month ago.
Greg McKaskle
Unread 19-02-2012, 11:06
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
Tape?
Unread 19-02-2012, 11:58
Find the center of the computer screen and put on it
Unread 19-02-2012, 13:06
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
Our team took a hole punch to the sticky part of a pink post-it note and put it on the center of the bottom hoop. When our driver lines up with that dot in the square of the lower hoop we sink it in the top one every time. Cheap and much simpler than cross hairs.
Unread 19-02-2012, 17:28
r0b0man r0b0man is offline
FRC #1308
r0b0man is an unknown quantity at this point
It may not be that difficult to modify a labview dashboard example that overlays rectangles and have it permanently overlay a crosshair.
Unread 15-04-2012, 10:49
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Greetings!
It's pretty easy to put an overlay on the camera image at the camera itself. Create a .bmp file of your crosshair in MSpaint or similar program. Log into the camera and select the image set up. There you will find an overlay function. Use that function to upload your .bmp to the camera's flash. The camera will automatically convert it to a .ovl. Then use the overlay function to set the X & Y position of the overlay and viola!
Good luck,
Mike
Unread 01-05-2012, 04:11
rainbowdash's Avatar
rainbowdash rainbowdash is offline
Director of Programming
AKA: Souvixada S.
FRC #1671 (Buchanan Bird Brains)
rainbowdash is an unknown quantity at this point
Did you know you can move the crosshairs manually on- screen on the computer?
Or are you asking for something more complicated?
"Why change the code? Just reverse the polarity."
Unread 03-05-2012, 08:37
Software Mentor
AKA: Mike Anderson
If you use the camera overlay approach, the simply give the camera a pixel location and the image is moved to that location. Very easy to sight in as long as the ball and shooter speed are consistent.
Mike
