Go to Post theyre not planning on blowing up the comet... just running straight into it and seeing what happens. :D - Winged Wonder [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 01-05-2012, 06:22
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Re: 2013 Game?
2013 Game: Skee Ball
The game field has four giant skee ball tables. There will be one in each corner of the field – two for red and two for blue. The skee ball tables use maybe 5 or 6 inch diameter balls. In the center of the field is a ball pit which is initially empty. Above the ball pit is a ball bin which stores the balls at the start of the match. There will be 50 or 60 balls – half of them red and half blue. In autonomous mode, the robots deploy minibots into the empty ball pit. At the end of autonomous, the ball bin opens and all the balls fall into the ball pit. The minibots spend the entire match driving under the balls trying to find balls of the correct color and tossing them onto the field in the correct direction. The human players move the balls to a rail similar to Breakaway that rolls the balls back to the ball pit. For the endgame, there is some sort of mechanism that requires the two alliances to work together to move the balls back into the ball bin. The human players can toss balls directly into the ball bin during the endgame. The win is worth 9 points and the coopertition score is proportionate to how many balls get moved back to the ball bin (maybe 0, 3, 6, or 9.) The endgame helps field reset.
