Go to Post After all, when any student is isolated because of a difference - because of race, gender, social beliefs, or ideological concepts - we all lose. - MysterE [more]
Unread 07-01-2003, 23:42
Gunslinger's Avatar
Gunslinger Gunslinger is offline
#0624 (Cryptonite)
Gunslinger is an unknown quantity at this point
Send a message via AIM to Gunslinger
Question Rotation with reference to translation question
how do you set up a cylinder to rotate when you move it like a wheel would rotate in real life? I'm assuming you would use the motion tab to add a rotation constraint, but i can't figure out which constraint to use or how to use it. any help would be much appreciated.
Commence Destruction
Unread 08-01-2003, 07:23
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
quite simple actually.
first rotate the wheel so that it is in contact with the surface that you wish to roll on. Then with the (autokey or animate) button turned on drag the wheel in the direction it will move. let's say it goes 0-100 and travels 50 feet.
Now go back and select the key mode and every say 5 frames rotate the wheel 90 degrees in the Z (depending on which axis it should rotate around)
quite simple to figure out, talk to me if you need some more help.
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
Unread 08-01-2003, 22:50
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
look in the tutorials...
there should be one about keyframing. that's what you need to learn about.
to make it short, keyframing is basically making a frame, then going to another frame and making a change, then letting 3ds max fill the frames in between.
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 09-01-2003, 00:34
Gunslinger's Avatar
#0624 (Cryptonite)
Oi, that's not what i mean. hhhmmm, let's see how to describe this. i wanna be able set up a constraint that says whenever you translate in say the X-axis, rotate so-and-so degrees for each unit moved. All this without actually creating an animation timeline or keyframes. well, i saw it done in Maya so maybe it's not possible in MAX.
Unread 09-01-2003, 07:33
Soukup's Avatar
Animation Guru
AKA: David Soukup
to my knowledge it's not possible...but maybe someone else could help you out. My only guess is that something like this would be under the motion panel.
Team 74 Alumni
Unread 09-01-2003, 09:33
Daishichimaru Daishichimaru is offline
Daishichimaru is an unknown quantity at this point
Send a message via AIM to Daishichimaru
Alas, without plugins you can't get MAX to do this automatically. Going to have to keyframe each bit individually, I'm afraid, so break out your calculator and start crunching the numbers.
Unread 09-01-2003, 16:34
JonathanE JonathanE is offline
#0619 (CA Robotics)
JonathanE is an unknown quantity at this point
Send a message via AIM to JonathanE
Rotate along path
The only way I know of to do this in Max is to use a Maxscript plugin (freeware) that will automatically roll a ball or wheel along a spline path.
The plugin I have used is Roller from HABware (http://www.habware.at/duck4.htm). This is freeware, and is supported by Max 4.x. I have not tried it yet with Max 5, but it should work.
Good luck!
Jonathan E
Team Co-Captain
Team Mentor - Strategy / Design
Student Lead Programmer
Student Lead WebDev
3D Animation Lead and Mentor
Student Lead Electrical / Control
CA Robotics - 619
Charlottesville, VA
Unread 09-01-2003, 23:23
Gunslinger's Avatar
#0624 (Cryptonite)
ok i'll check that out.
Arigatoo Gozaimasu
Unread 10-01-2003, 02:31
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
MAX 5 is more powerful than you guys think...
reactor* now has a "toy car" system, that will take care of animating the wheel rotation, plus many other motions. It might be confusing if you've never used reactor before, but if you want details about the system, see Chapter 8 of the reactor reference (Pg 49)
reactor is awesome, I think. Animators should use it. Sadly, I won't work on an animation this season...
*by discreet
Unread 10-01-2003, 07:14
Soukup's Avatar
Animation Guru
AKA: David Soukup
hey suneet thanks for the reactor tip, that actually worked.
but you're not making an animation this year....can you elaborate.
Team 74 Alumni
Unread 10-01-2003, 09:43
Oh, my team is sort of short on real engineers, and I managed to get handy with Inventor over the summer. So I'm doing CAD work for robot systems instead of an animation. In fact, we don't plan to submit one this year. ::shrugs::
Unread 14-01-2003, 01:29
Markfuscius's Avatar
Markfuscius Markfuscius is offline
Markfuscius is an unknown quantity at this point
OK, so basically Reactor can do wheels. What about timing belts/ treads/ chains in loops? Is there an easy way to maybe IK them to the wheels so that they'll rotate as well?
Just curious, in ne1 knows ^.^;; thx!
"War is the Way of Deception"
-Sun Tzu, The Art of War
-Markfuscius
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
