Go to Post It is not necessary to draw 200 amps to move a robot through a two minute match. Rule of thumb is you robot should be able to compete for three matches without a battery change. - Al Skierkiewicz [more]
View Poll Results: What should IRI do with Co-Op points
2 Points. Same value and ranking system as regular season. 59 27.83%
1 Point. Different value but ranking system as regular season. Only counts if fully balanced. 61 28.77%
1 Point. Ranking based on win-loss. Co-op is tie-breaker for ranking. Only counts if fully balanced. 92 43.40%
Voters: 212. You may not vote on this poll
Unread 02-05-2012, 09:15
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Co-Op Rules for IRI - Unofficial Vote
We are considering three options for the co-op bridge at IRI, and will probably let each attending team vote (one vote per team) on how to proceed.
Here is an "unofficial" vote to see what CD thinks.
1. 2 points. No change to point values, ranking structure, etc.
2. 1 point. No change to ranking structure, just make a win worth more than the co-op bridge. Only counts if fully balanced.
3. 1 point. Ranking based on win-loss record, with co-op points as a tie breaker. This keeps the ranking focus on win-loss, but also makes the co-op important for teams with the same record. Only counts if fully balanced.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 02-05-2012, 09:28
foote stepped in
AKA: E. Foote
FRC #0868
Re: Co-Op Rules for IRI - Unofficial Vote
I'd vote for a bonus for 3 robots on the co-op bridge.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 02-05-2012, 09:34
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Well how about 3 coop points for 3 on the coop bridge or 4 coop points for 4 on the coop bridge. I've seen it happen
461 Westside Boiler Invasion
45 Technokats
Unread 02-05-2012, 09:38
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
Has there been any talks about making the coop worth 0 and adjusting the qualification balance points?
I would have to agree with Adam's post in the MARC thread:
http://www.chiefdelphi.com/forums/sh...7&postcount=55
Originally Posted by Adam Freeman View Post
I am not sure that making it 1pt is going to make things any better. If nothing else, it makes it easier for a team to decide not to do it. Which, if you are on the other side of that decision is still going to effect your ranking. All it does is change the situations in which a team decides to coop or not.
We used the coop bridge with great success this year. We took advantage that winning + coop will move us way up in the rankings and that doing it consistently everytime will lead to great success. In our local districts team s that knew us pretty much agreed we should be the ones to do it, and we had no shortage of willing and capable partners. At MSC, so teams from farther away from metro-Detroit, did not know us so well and we had to have a direct conversation about why we should do it. Everyone at MSC was capable. In St. Louis, it was even worse...we needed to convince most teams that we should be the one coop'ing and then struggle to find an opponent that was capable of performing the task with us.
I also saw a lot of teams declining to coop or agreeing and not showing up. We have never experienced that this season, but I can imagine that is probably one of the worst feelings...knowing someone is messing with your ranking for their own benefit (without beating you) or even worse they just lied to you.
Making it 1pt, lessens the pain of those lies, but also makes it easier to either decieve someone or just plain tell them you don't want to do it. It definitely changes the dynamic a bit.
It still takes the same effort and time to do it. If you are going too...wouldn't you want to get the most benefit from it?
I say either leave it as 2pts...or get rid of it all together for off-season events and let us just run up the scores as much as possible...
-Clinton-
Unread 02-05-2012, 09:44
Rookie Year: 1942
We posted three options.
Chris Fultz
Unread 02-05-2012, 09:54
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Option 1.
The scoring system, as it stands, is great. Leave it as-is.
This invites many strategies to the competition and the meta-competition as it were. Especially when every contestant is regional-champion-or-beyond quality, as they are at IRI, I can see no benefit to denying any team the coop bonus.
[disclaimer]opinion of a likely non-participating but interested third party[/disclaimer]
Hi!
Unread 02-05-2012, 10:12
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Well since no one else has actually commented on the available three options, I will try too.
I am debating which option between 1 or 3 is best. Option 1 pretty much makes everyone at atleast attempt to Coop early in the event. Since all the teams attending will believe they have a shot at seeding first and selecting the best robot available. But, as the competition carries on Friday evening and Saturday morning, all the strategic and competitive juices will be in full force. Will this coop bridge be more like MSC, where there are so many qualified teams that 100% coop scores will be the norm...or will there be significant strategic plays similar to what we saw at Champs. Any time someone messes with the coop bridge (ie; not doing it in any way...) people's feelings get hurt. I would hate for IRI to turn into another controversy over this bridge.
Clinton quoted my opinion on a 1pt coop bridge. Just not worth it to perform every match and easier to accept screwing others over. I am not a fan of option #2.
I am leaning towards option #3. It's as close to just doing W-L-T as they are going to allow. I think the competition will devolve into no one doing it at all, since it takes too much effort to do it and at IRI you are probably going to need to score the entire match to win, unless there is agreement between the teams that a match is too lopsided and both teams agree to get the 1pt bonus for the tie-breaker. I believe this option limits controversy and makes the qualification matches more exciting.
After typing through all of this, I think I have decided on option #3.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 02-05-2012, 10:58
Craig Roys's Avatar
Craig Roys Craig Roys is offline
Coach - Team 1718
FRC #1718 (The Fighting Pi)
Craig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond repute
I like option 1, but I am a bit biased as we were able to use the coop bridge effectively all season long. I know there are many who believe that it was worth too much. If not option 1, I would also vote for option 3 and use it as a tie-breaker. I don't think option 2 with a 1 pt coop makes it worthwhile to do - it would tend to make it more likely that you would get stood up at the bridge as the game came down to the wire and a team decides the win is more important that the coop.
2016 Waterford District - Semifinalists and Entrepreneurship Award Winner!
2016 Troy District - District Winner and Chairman's Award Winner!
2016 MI State Championship - State Champs with 27, 67, and 6086 and Entrepreneurship Award Winner!
2016 FIRST Championship - Carson Field Quarterfinalists
Unread 02-05-2012, 11:37
President, VEX Robotics, Inc.
Chris,
I want option 4: 2 co-op points but not used for anything other than the co-op award. Allow triple balances in qualifications since the robots will be good enough to either triple or defend the triple. Let's make all IRI matches like elimination matches. It will be an insane tournament this way.
To me, all of the other options are bad for IRI. It may have worked fine for a competition season where 90% of the robots were OK or bad, but at a competition that will have the top 2ish% robots participating, what will the co-op bridge achieve? It will just be another strategic option for teams to use to manipulate rankings.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 02-05-2012, 11:40
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
I'm with Paul on this one. The triple balance is the most exciting aspect of this years game, why not extend it to the qualification matchs?
Unread 02-05-2012, 12:15
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I'm also with Paul but if we can't have triple balances then option 3.
Unread 02-05-2012, 12:34
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
If this option is chosen, would co-op points be the first tie-breaker, shifting the other tie breakers down in priority? So HP (hybrid hoop points) would become the 2nd tie breaker, BP (bridge points) would become the 3rd tie breaker, etc.?
I think I like option 3.
Richard Wallace
since 2003
Unread 02-05-2012, 12:40
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
My initial opinion would be to leave it as it was originally written, however if a change is required I agree with Paul with a minor tweak.
If triple balances are worth 40pts in Qualifications then balancing on the Co-Op Bridge should be worth 10pts.
Unread 02-05-2012, 12:50
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
Leave it as is. Adding in the ability to 40 point balance in the qualification matches will really hurt bots that are a long configuration.
Unread 02-05-2012, 12:57
IndySam's Avatar
Never thought of that Tom, it would significantly change design choices.
Change me to a 3.
