Go to Post Don't let what you think you can do get in the way of what you can do. - Daniel_LaFleur [more]
View Poll Results: What should IRI do with Co-Op points
2 Points. Same value and ranking system as regular season. 59 27.83%
1 Point. Different value but ranking system as regular season. Only counts if fully balanced. 61 28.77%
1 Point. Ranking based on win-loss. Co-op is tie-breaker for ranking. Only counts if fully balanced. 92 43.40%
Voters: 212. You may not vote on this poll
Unread 02-05-2012, 12:58
Donovan0217's Avatar
Donovan0217 Donovan0217 is offline
FRC #0217 (The Thunderchickens)
Donovan0217 is an unknown quantity at this point
Re: Co-Op Rules for IRI - Unofficial Vote
Originally Posted by Tom Line View Post
Leave it as is. Adding in the ability to 40 point balance in the qualification matches will really hurt bots that are a long configuration.
That is not necesarily true. While it is more difficult to triple in some cases, there are plenty of long bots that are capable of tripling. 217, 1114, 2056 all have their own dinguses to help tripling. Wave 2826 *almost* tripled with HOT in Archimedes, and Robostang has tripled as well, and that is just off the top of my head. There are plenty long bots that can triple.
(Thanks to Adam for correcting me)
Student 2012, Mentor 2013-present
2013 Michigan State Champions (469, 3539, 217)
2013 Newton Finalists (1986, 1538, 217)
2015 Archimedes Finalists (1640, 1310, 217)
2016 Newton Champions (217, 3476, 4678, 188)
Unread 02-05-2012, 13:14
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Originally Posted by Donovan0217 View Post
Wave 2826 tripled with HOT in Archimedes...
Unfortunately, Wave has never tripled with HOT in an actual match. That was part of the problem.
Now I will go sit in the corner and cry...
Regarding Triple Balancing in Quals - I agree with Paul...teams can either decide to triple, block it, or attempt to out score it. It just adds another element of strategy to qualification matches.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 02-05-2012, 13:17
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Originally Posted by Paul Copioli View Post
Chris,
I want option 4: 2 co-op points but not used for anything other than the co-op award. Allow triple balances in qualifications since the robots will be good enough to either triple or defend the triple. Let's make all IRI matches like elimination matches. It will be an insane tournament this way.
I like that idea alot!
Unread 02-05-2012, 13:18
P.J.'s Avatar
P.J. P.J. is offline
Proud Member of the Herd
P.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond repute
If I may make a comment, while I do like the discussion that is happening, it is kind of irrelevant to the topic. Mr. Fultz gave us three options, and from what it sounds like they have probably narrowed it down to these three from all the other suggestions in the other IRI thread. So I believe that they have decided to not allow triples in quals for whatever their own reasons are.
That said, I like option 3.
P.J. Lewalski
Team 910-The Foley Freeze -- Student 2007-2010, Mentor 2012-2016
FRC Referee 2011-Present
Referee at 29 Regular Season Events, 3 World Championships, 24 Off Season Events, and Counting
Unread 02-05-2012, 13:23
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
While I won't attend IRI, I agree with Paul. IRI is traditionally all about being competitive on the field the whole time.
The biggest incentive to add in a triple balance is that it will give more opportunities to teams to *try* a triple balance when they've never been on an alliance that had an incentive to do one. More triples = more excitement for the successes and more heartache for the teams who fall off.
Are HP's/BP's still being tracked at IRI? Towards the end of a full set of Qual matches, one would be hard-pressed to find two teams with identical QP's and HP's. Yet if BP's were tracked (much easier) at IRI, then that could be the secondary sort after W-L-T, thus incentivizing the triple balance.
GitHub
Unread 02-05-2012, 13:30
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
There will not be a co-op award at IRI.
Andy B.
Unread 02-05-2012, 13:48
AdamHeard's Avatar
Lead Mentor
Triple balance in quals sounds like fun!
Unread 02-05-2012, 13:55
President, VEX Robotics, Inc.
Andy B.
OK, fine. Revised option 4: 2 co-op points for every co-op. It is not used at all in the rankings, but for every co-op point earned at IRI Innovation First will donate $50 to the IRI Scholarship fund. Triple balances count in qualifiers and every robot balanced on the co-op bridge is worth 10 points for that color alliance.
C'mon Andy and Chris, let's breaks some eggs and make Omelets!!
EDIT: By the way, many voting processes in the US have a write in option. I am exercising that right with option 4! Option 4! Option 4! Option 4!
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 02-05-2012, 13:59
twetherbee twetherbee is offline
Mentor, Team 987
FRC #0987 (High Rollers)
twetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud of
How about Option #5: Eliminate co-op points, but make the middle bridge worth 5 points to any robot that balances on it at the end? It would narrow the 7 ball gap, slightly, needed to out score a triple balance with a double balance, which could make for some exciting matches and create some interesting defensive strategies.
Unread 02-05-2012, 14:03
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Give a group of engineers the choice of three options, and they'll pick choice number seven.
Having said that,
::stand and applaud::
Although - I could see this becoming a no-holds-barred king-of-the-hill contest for the middle bridge, resulting in more than one broken body upon the white altar.
Hi!
Unread 02-05-2012, 14:32
O-H
FRC #0048 (Delphi E.L.I.T.E.)
What if the "random" match scheduler puts 3 longs on an alliance? Or 2 longs and a wide that isn't compatible? This option certainly gives some designs an advantage over others, if other rule modifications are not made to level the playing field in such situations.
Even as a longbot, I'm potentially ok with allowing triples in qualifying (we've got a stinger, we can hang off the bridge - we're game), and I agree that all triples all the time sounds more exciting (maybe not for pit crews dealing with agony of defeat moments), but "Option 4" is a definite non-starter for me, UNLESS...
...IRI relaxes the namby-pamby bridge defense rules implemented at the championship - no penalties of death if triples are attempted on the alliance's basket side of the field. If defenders want to park over to block, and they are pushed into the bridge - tough. No 40-point penalties. Nothing. You widebot stinger boys want to triple - get ready to do it by fighting through some pain, break away from scoring and line up earlier, or cross the bump and get your butts lined up in the protected area where ye belong.
Option 4 is too much reward for a certain subset of robots, with not enough risk.
I do like some kind of co-op bridge charitable incentive option, especially if Copioli is writing the check. :-P
Unread 02-05-2012, 14:42
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Given a free choice I'd be up for triples in quals. It will make the rankings the most accurate possible by making the game the same between qualifications and elminations, while also giving people more practice and better scouting for triples resulting in more exciting finals.
If forced into the three I'd pick option 1
Unread 02-05-2012, 14:48
O-H
Having said that,
You want a bloody altar? Let the team with the most co-op points at the end of qualifying get to bestow the accumulated funds to one of their seniors, their discretion.
Unread 02-05-2012, 15:04
rick.oliver's Avatar
rick.oliver rick.oliver is offline
Mentor - Retired
AKA: Pap
rick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond reputerick.oliver has a reputation beyond repute
I see your point. So, perhaps the committee would consider relaxing all of defense-inhibiting rules, I mean why draw the line at bridges
But seriously, Chris explained their intent around game play and their philosophy about rules changes. I agree that Paul's suggestion has merit. I also think that it is outside of the box that they chose to work in.
That said, if they do add that option and we are fortunate enough to be invited, we, being among that certain subset, would be inclined to support it
Unread 02-05-2012, 17:48
Clayton Yocom's Avatar
Clayton Yocom Clayton Yocom is offline
Programming Mentor
FRC #0027 (RUSH)
Clayton Yocom will become famous soon enoughClayton Yocom will become famous soon enough
Send a message via AIM to Clayton Yocom Send a message via MSN to Clayton Yocom Send a message via Yahoo to Clayton Yocom
This isn't without precident, especially after last year's changes.
I vote option #4, because it takes co-op bridge out of the rankings. (And no bias either, we made it up to 11th with co-op points and ended up winning the regional.) I feel co-op is really pointless at IRI where either everyone tries to co-op or nobody does. If I have to vote within the 3, it'd be option #3. Again, get co-op out of the rankings at such a high competition event.
