Go to Post Ah, this sounds like a sitcom whose pilot I should write and send to NBC - "Life With Lavery". There's a lot of eating, several practical jokes, and lots of bad hair. - Amanda Morrison [more]
Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Unread 03-05-2012, 08:31
AKA: Brad
#0190 ( Gompei and the Herd)
Re: paper: Team 341 Vision System Code
Jared -
Thanks so much for posting your code. It was good meeting you at the regional and amazing watching your teams robot do it's stuff. This will go a long way to helping teams learn about computer vision processing and raise the bar for future competitions. Expect to see better documentation and improvements for next season.
And thanks to Joe Grinstead and Greg Granito for helping develop the code over last summer at WPI. They did a great job with the camera code and network tables extensions to WPILib.
Brad
Brad Miller
Robotics Resource Center
Unread 05-05-2012, 15:58
sebflippers sebflippers is offline
FRC #2914
sebflippers will become famous soon enoughsebflippers will become famous soon enough
Thanks for the code. I believe lines 322-334:
private double boundAngle0to360Degrees(double angle)
        // Naive algorithm
        while(angle >= 360.0)
            angle -= 360.0;
        while(angle < 0.0)
            angle += 360.0;
        return angle;
could be replaced with
        return(abs(angle)%360.0);
Unread 05-05-2012, 17:50
Ziv Ziv is offline
Has code to be writing...
FRC #0125 (Nutrons)
Ziv is a glorious beacon of lightZiv is a glorious beacon of lightZiv is a glorious beacon of lightZiv is a glorious beacon of lightZiv is a glorious beacon of light
Originally Posted by sebflippers View Post
Thanks for the code. I believe lines 322-334 [snipped] could be replaced with
Consider the angle -90. Daisy's code returns 270, but yours returns 90. I think you're looking for something more like this:
        double ret = abs(angle)%360.0;
        if(angle < 0.0)
            ret = -ret;
        return(ret);
Unread 06-05-2012, 11:52
FRC #2914
        if(angle < 0.0)
            ret = -ret;
        return(ret);
right.
Unread 06-05-2012, 14:09
FRC #2914
done. This one kind of defeats the purpose of making your code simpler, though.
	public static double boundAngle0to360Degrees(double angle)
        return(angle > 0.0? angle % 360.0 : 360.0*(1 + (Math.abs((int)angle)/360))+angle);
Unread 07-05-2012, 03:58
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Why not just...
        return((angle+360)%360);
Unread 07-05-2012, 08:11
Jared Russell's Avatar
Taking a year (mostly) off
Originally Posted by Gray Adams View Post
Why not just...
What if angle is equal to -361?
It's awesome that you guys are analyzing the code and you have already taught me something new (that Java's "%" operator works on floating point values...as a primarily C++ guy, I have it burned into my brain that thou shalt use "fmod" for floating point modulus). But if this is the part of the code that engenders the most discussion, then I'm a bit disappointed
Unread 08-05-2012, 00:11
Gray Adams's Avatar
Ok, fine.
return(((angle%360)+360)%360);
Unread 08-05-2012, 19:58
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
I feel like at this point the original code was easier to understand from an outside perspective.
On another note, this is AWESOME! It's nice to see another team using Java to program, especially when it's done so well. Our camera tracking system is currently only used in auton to track after grabbing the third ball off the co-op bridge. It's very rudimentary code so that it can be run on the cRio (we had issues with a bad camera that made it impossible to test any sort of laptop based vision code). This is very interesting, and I'm excited to go over it in more detail later.
www.sharkattack744.com
Unread 08-05-2012, 20:58
Thanks for posting this, Jared. I took a look at your dashboard on the field at Champs and was very impressed. It seems incredibly useful to have the vision system draw its idea of target state on top of the real image.
I suspect if vision is a part of upcoming games, we will probably use a solution very similar to this. This year we wrote all of our vision code on top of WPILib/NIVision to run on the cRIO. In the end we got this to work pretty well, but development and debugging was a bit of a pain compared to your system.
Unread 09-05-2012, 09:43
Leeebowitz Leeebowitz is offline
AKA: David
FRC #2115 (Nightmares)
Leeebowitz is an unknown quantity at this point
Very cool! I just finished taking an online data structures course from IIT, so it was really awesome to see the implementation of the TreeMap! Just so that I'm sure I understand, it is used to quickly find an rpm based on your distance, right? What are the advantages (if any) of using this instead of plugging your data points into an excel graph and getting a polynomial best fit equation to transform your distance into an rpm?
Unread 09-05-2012, 10:14
The biggest advantage was it made tuning very easy. Take the bot to the practice field with some balls, fire away, and record the range/RPM information into the TreeMap if you like what you saw (we actually had a version of the software that let the operator do this with the push of a "commit" button, but we ended up doing it all by hand just to sanitize the values). No need to fire up Excel.
Unread 09-05-2012, 10:16
By far the biggest advantage of a laptop-based solution was the development process that it facilitated. Simply collect some representative images and then you can go off and tune your vision software on a laptop without needing a cRIO or the FRC control system.
Unread 09-05-2012, 11:13
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
Doh! I missed this before I responded as it was on the 2nd tab...
While I'm here though... if you are a c++ guy why use Java? Is it because it was the only way to interface with the dashboard? I gave up when trying to figure out how to do that in wind river.
Unread 09-05-2012, 11:33
Easy, it's because I am not the only person who writes software for our team! Java is what is taught to our AP CS students, and is a lot friendlier to our students (in that it is a lot harder to accidentally shoot yourself in the foot). I also have a lot of training in Java (and still use it on a nearly daily basis), even if C++ is my bread and butter.
