Go to Post Friends don't let friends drive mecanum. Enough said... - Botsup [more]
  #46   Spotlight this post!
Unread 20-05-2011, 16:57
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: 6WD vs 8WD
Originally Posted by Hawiian Cadder View Post
... the goal of having the outer wheels raised is to make them act more like omni wheels. for the purpose of the argument imagine all we care about is drive systems with omni wheels on the corners.
You may want to look further into this assumption.
As you raise the wheel (or increase the center wheel drop) you decrease the load on those wheels. Yes, it decreases the sideways slipping force on the wheel, but it also decreases the tractive force in the same proportion. The first point is that it never really behaves like a omni wheel, just as a wheel with less traction.
The second point is that the load drops off across the distance of your wheel dropped (teams range from 1/16-1/4") which makes it hard to tune. I worked with an adjustable drop 6WD for a few years and we discovered that 2-3mm drop was what worked for us as optimum. Outside that sweet spot we began to get significantly different driving performance. We also discovered that a 1/2 day of matches was enough wear on gum rubber treads to get us outside this range. We eventually decided that it was not worth the effort and decided to let the wheel off the ground and allow the robot to rock between the two 4 wheel systems. It was much simpler in the long run and allowed us to apply our resources elsewhere. I know the 2011 kitbot configuration has enough lift to accomplish this.
You may want to spot check with teams to see if all of their wheels are actually on the ground or just really close. How might having one set of corners off the ground affect the logic you used above?
Mark
Brick walls are for other people. - Randy Pausch
  #47   Spotlight this post!
Unread 26-05-2011, 12:36
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Re: 6WD vs 8WD
For Logomotion, we had an 8WD chassis with 6" wheels. The four at the corners were "kit" wheels. The four in the center were closely spaced pneumatics with adjustable drop. (I noticed in St. Louis that 330 used the same arrangement). We adjusted the tire pressure and center wheel drop so that the corners were about 1/16" off the floor on a hard surface, and had light contact on the carpet.
We were quite happy with the arrangement. It turned very well, since the pneumatic tires had better traction and higher loading than the corner wheels. It didn't rock or bounce during accelearation or turning since the corner tires were hard. During acceleration or in a pushing situation, all four pneumatics and one set of corner tires were in contact with the carpet. It was very difficult for others to push or turn us.
It was a good balance between the agility of a 6WD with center drop or omnis, and the pushing power of an 8WD with pneumatic tires.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
  #48   Spotlight this post!
Unread 27-05-2011, 11:38
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
Re: 6WD vs 8WD
eight
See Ya
  #49   Spotlight this post!
Unread 27-05-2011, 11:44
Chris is me's Avatar
AKA: Pinecone
Re: 6WD vs 8WD
Originally Posted by Triple B View Post
eight
Why 8?
  #50   Spotlight this post!
Unread 27-05-2011, 13:44
all hail Passmore
Re: 6WD vs 8WD
From my experience, the 8 gives you more stability at higher speeds and better predictability of how the robot will handle. We also decreased the diameter of the outside wheels instead of offseting the axle height.
mike d
See Ya
  #51   Spotlight this post!
Unread 27-05-2011, 14:57
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: 6WD vs 8WD
mike d
Did you change the ratios to match teh diameter changes, or just allow for the inherent scrub to occur?
  #52   Spotlight this post!
Unread 27-05-2011, 15:22
all hail Passmore
Re: 6WD vs 8WD
no change of ratio, just let it ride.
See Ya
  #53   Spotlight this post!
Unread 27-05-2011, 16:09
Re: 6WD vs 8WD
Our 2007 "Rack 'n' Roll" robot was a six-wheel drive with no center drop. It had extra-thick tread on the center wheels and it drove like a dream. We never figured out whether the very slight discrepancy in wheel circumference made any difference one way or the other. There was some conjecture that a teeny bit of scrub on the corner wheels might actually result in better turning.
  #54   Spotlight this post!
Unread 30-05-2011, 11:47
Blake L's Avatar
Blake L Blake L is offline
FRC #2016 (Might Monkey Wrenches)
Blake L is an unknown quantity at this point
Re: 6WD vs 8WD
Personally, I like 8WD, although my opinion might be a bit biased because I haven't driven a 6WD robot anywhere near as much as I've driven an 8 wheeled one.
This year my team used eight 4" diameter wheels geared 7:1 and I loved it.
Here is a video of us playing with the chassis a week into build season:
http://www.youtube.com/watch?v=inI40uMKuEE
If I remember correctly, the center two wheels are dropped 1/16". We later added another two motors to the drive train which gave us a nice balance of speed and power.
  #55   Spotlight this post!
Unread 03-05-2012, 16:00
Dr. Shocker's Avatar
Dr. Shocker Dr. Shocker is offline
Alumn
FRC #1126 (SparX)
Dr. Shocker is on a distinguished road
Re: 6WD vs 8WD
Originally Posted by Grim Tuesday View Post
Can someone tell me what a "West coast drive" is?
From what I understand, West Coast Drive is essentially a 6/8 wheel drive platform with cantilevered wheel axles, but I've seen a few mentions that it might have to do with how you actually power the wheels.
  #56   Spotlight this post!
Unread 03-05-2012, 17:17
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: 6WD vs 8WD
If you go to CD Media and search FRC254 or FRC968. They have many awesome pics of their chassis that is dubbed "WestCoast Drive".
Key Features are:
-Cantilever Wheels
-Direct Drive
-Inline system
-CAMS
-Sliding Bearing Blocks
-Small Wheels (We goofed, big wheels are ugly )
There are a few other tidbits, but that should sum it up.
-RC
R.C.
MadTown Robotics Team 1323
  #57   Spotlight this post!
Unread 03-05-2012, 17:38
FRC #1836 (MilkenKnights)
Re: 6WD vs 8WD
Key Features are:
-Cantilever Wheels
-Direct Drive
-Inline system
-CAMS
-RC
Yeah, small wheels are amazing: they can potentially reduce a sizeable amount of weight. I would have perfered to use small wheels on our robot this year, with 8wd instead of 6, but it all worked out in the end. I was wondering though, I don't remember 254 or 968 ever using cams. Do you have a picture? Also, to add on to your list, just some things that are also really nice:
-2 speed
-Custom gearboxes
-Custom wheels
What does it take 6WD/8WD to be successful? TEE Technical Discussion 26 06-05-2010 08:30
pic: Rastogi 8wd Iteration 1.2 Akash Rastogi Extra Discussion 56 05-05-2010 15:16
pic: Sheetmetal 8wd Akash Rastogi Extra Discussion 16 02-05-2010 15:38
pic: Concept 8wd Drivetrain sdcantrell56 Technical Discussion 77 25-11-2008 23:05
8WD drivetrain? David Sherman Technical Discussion 16 09-04-2006 17:32
