Go to Post Meh, that's nothing a freshman with a drill press and a dremel can't fix... - Chad987 [more]
Unread 03-05-2012, 17:27
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Non-FRC Motor Controller?
Originally Posted by Alan Anderson View Post
Where did you find this information? It's totally wrong.
Spike relay modules contain a pair of simple physical relays that use a pair of logic level signals to independently switch each relay's output between the 12 volt power and "ground" return inputs. When wired to motors, both relays are usually connected in an H-bridge configuration, but they don't have to be used that way. They are just as easily used as separate circuits, such as when powering LEDs or pneumatic solenoid valves.
Pulsing them is not recommended, as they are rated for a finite number of cycles and are likely to fail either electrically or mechanically.
If this is the case the documentation is not consistent, and in that case your criticism of the idea is quite valid:
http://en.wikipedia.org/wiki/User:As...novation_First
"The Spike relay, available in mechanical and solid state models"
In any case the flaky documentation aside (here's a video of PWM driving a solid state relay...it's not ideal but under just the right circumstances it'll work):
http://www.youtube.com/watch?v=LL2Sryi57xA
I suspect that the confusion was caused because Innovation FIRST does sell a solid state module, but I don't see any evidence that it's called a Spike relay.
The Red Spike seems to have had no reverse polarity protection according to what I could find.
The Blue Spike fixed that apparently.
If that's incorrect please do correct me because Innovation FIRST Spikes are not something I usually mess around with, so my experience with all the flavors is limited.
Unread 03-05-2012, 17:28
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Originally Posted by rbmj View Post
I was looking for a couple of motor controllers for some personal projects of mine and was wondering if you all had any suggestions.
If you describe the projects in detail, we might be able to give you some suggestions. Otherwise we're all just guessing, which is not very helpful.
Unread 03-05-2012, 17:47
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by techhelpbb View Post
If this is the case the documentation is not consistent:
I'd be really careful using Wikipedia.org as an authoritative document source.
The example you gave is a perfect example as why caution should be used.
As far as I know, they have always been mechanical contact relays.
You can find some Technical Specs on this page.
Unread 03-05-2012, 17:56
techhelpbb's Avatar
Fair enough I provided the other link previously.
http://www.chiefdelphi.com/forums/sh...2&postcount=13
The term H-bridge shouldn't even apply to this unit anyway.
An H-bridge is a very specific circuit.
http://en.wikipedia.org/wiki/H-Bridge
This is at best a half bridge or half h-bridge.
I suppose if this were transistors you could also see it referred to as a totem pole, push-pull or class AB amplifier configuration.
However, to keep this on topic as I stand corrected on the details:
A solid state relay *can* be used to control motor speed under the right circumstances and Innovation FIRST does sell one (I've just never tried it with this relay and we don't know what kind of motor):
http://www.ifirobotics.com/ssr.shtml
Unread 03-05-2012, 18:04
Nikkocharger's Avatar
Nikkocharger Nikkocharger is offline
The R/C'er
AKA: Dontae
FRC #3398 (Crushing Crusaders)
Nikkocharger will become famous soon enoughNikkocharger will become famous soon enough
If your motors are DC brushless, not DC brush, there are quite a few cheaper options than the FRC electronic motor controllers, for example:
http://www.hobbypartz.com/skyrcesc.html
Recently I have been looking at motor controllers for my R/C car and I know that this place is always out of stock and those Leopard motors will de-bond if you put to much load on them. I would however recommend. http://www.hobbyking.com/hobbyking/s...ntrollers.html
Suddenly, a wild prototype appears!
Unread 03-05-2012, 18:11
A Wiki user page is not documentation, especially when it contains a disclaimer about needing work.
Unread 03-05-2012, 18:17
techhelpbb's Avatar
The first bit of documentation I provided in this topic at Ether's request:
http://www.robotmarketplace.com/prod...sersManual.pdf
Seriously, this is professional documentation and it does not mention mechanical relay or solid-state.
However, it does incorrectly refer to itself as an H-bridge which as you and others say it is not. Should I also know better than to read Innovation FIRST documentation and take it for granted?
I've already stated I stand corrected on that detail....are you interested in the validity of my original suggestion which I provided a video demonstration for or something a little less gracious and professional?
Again:
A solid state relay *can* be used to control motor speed under the right circumstances and Innovation FIRST does sell one which apparently someone...somewhere thinks is called a Spike (I've just never tried it with this relay and we don't know what kind of motor):
Unread 03-05-2012, 18:39
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
these are all pwm esc's
for less than 1a http://www.fingertechrobotics.com/pr...d=ft-tinyESCv2
3-9a http://banebots.com/pc/ELECTRONICS/BB-0309
the sabertooth 25 is a pretty beastly dual channel controller. it will do 25a per channel or 50a single. i run one in my 30lb battlebot. http://www.robotmarketplace.com/prod...ER2X25-RC.html
the 12 amp version isn't too bad either.
for bigger stuff http://holmeshobbies.com/product.php...4&cat=2&page=1 it will do 80a at 24v and dosent have a fan like a victor.
robot market place has a pretty cool tool to find speed controllers
http://www.robotmarketplace.com/prod...lers_main.html
http://killerbotics.com/kbtools/TentacleTools/ is a great drivetrain calculator.
i would invest in a esc instead of pulsing a spike relay and you can always re use them in another project.
Unread 03-05-2012, 18:45
techhelpbb's Avatar
Okay, LOL, let's correct this because it was my mistake...the Innovation FIRST Spike (red or blue) relay shouldn't be pulsed as it wouldn't work Alan's statement is quite valid.
I was under the impression from the Innovation FIRST documentation and the Wikipedia page I linked it was a solid-state H-Bridge it is not (if you really need details why read posts from start of topic).
My earlier error removed:
If you pulsed the Innovation FIRST *solid state relay* with just the right circumstances you could control brushed DC motor speed with it.
BTW thanks for the reminder I couldn't remember that SaberTooth's name...they apparently ran out of big cat names so they went to extinct big cat names .
Unread 03-05-2012, 19:33
Again:
Agreed. Those circumstances might even be applicable to what rbmj (the original poster) is trying to do. He specifically asked about exactly what you suggested, but he quite properly recognized that such a scheme would not be using a speed controller.
The usual meaning of "motor speed controller" in this context is something which takes a hobby servo control signal and provides a suitable modulated and polarity-switched output. Using a solid-state relay is a lot like using raw transistors; you need to provide your own PWM. And you're not going to be able to control the motor direction with one.
Brian, I encourage you to slow down a bit and let some of the information you're reading sink in and get sorted out before you repeat it. Innovation FIRST hasn't sold that product for a great many years, and actually doesn't sell any of the products listed on the ifirobotics.com catalog pages anymore. Those pages are no longer accessible from the IFI home page. If you manage to find one by some other means, they all have that prominent red text at the top explaining that the Innovation First products are now sold by VEX Robotics under the VEX PRO brand. That solid-state relay module is not one of the products which made the transition.
Unread 03-05-2012, 19:47
techhelpbb's Avatar
I absolutely agree. I don't think he ever made it clear that the needs to go both forward and reverse from the input (he could just use more solid state relays or a reversing clutch...etc), or even what kind of motor, but if he does obviously your point is quite valid.
The other point taken as well, normally you'd expect your electronic speed/motor controller to operate on the input signal and condition the result for the output. Perhaps even give you some features like thermal protection.
Still without more detail we don't know what's expected. Several of those R/C speed controls will differ slightly in how they react as well.
Additionally I've assumed again he needs to drive a DC brush motor. I hope that the difference between that and a DC brushless motor has been realized. These two kinds of motor are rarely interchangeable unless the controller for the brushless motor is part of the motor.
Fair enough. I saw that it linked over. The point was more that I suspect the initial confusion of the Wikipedia author originated in the availability of this item. It does not appear to me that Innovation FIRST ever actually called it a Spike relay. Perhaps you know better on that point.
I'm almost positive that this confusion is not new either. I recall vaguely a previous topic in these forums with a similar issue Spike relay related issue. Sorry didn't mean to step in the same mess again.
Unread 03-05-2012, 20:35
OK,
Here goes...
The Red Spike which has not been sold for quite a while (+12 years) had a small limitation in that while it could reverse polarity to the output (M+ and M-) it could not independently switch from positive voltage to common. (It could make both outputs common) The Blue does allow that and so it has four states, one is both outputs high (+v), one is both outputs low (common), one where one output is high and one is low or one where the last condition is reversed. Spikes have never been solid state. In the strict definition of an "H" bridge i.e. four independent switches, the Spike meets that definition. It is simply two single pole, double throw relays, with the common terminal of each connected to the M+ and M- outputs.
The nature of the self resetting breakers used in FRC allow a 600% over current rating for up to 2 seconds before trip when at ambient temperature. That is 240 amps for the 40 amp breaker. It is likely that you will not experience a trip even at 45 amps. The CIM motor is rated at 133 amps in stall, and free speed current of almost 3 amps.
While you would think that software might be able to pulse the relay, in reality, the time it takes to move the contacts might make this a frustrating experience. When used with higher current motors, those above the rated 20 amps, significant arcing of the relay contacts will result from the inductive loading of a motor switched at a frequency needed to control motor speed. Used in this operation, the resulting degradation of the contacts may even fuse the contacts in some cases, rendering the relay permanently in one state.
Please note that while a single solid state relay is capable of switching the current to the motor, it is not capable of reversing the motor. An "H" bridge could be constructed using four such solid state relays. The cost of the four devices and drivers would approach the cost of a Victor or Jag. However one needs to be careful to use SSR designed for switching DC loads and rated currents. Please note that the IFI SSR linked above is rated for 7 amps.
Unread 03-05-2012, 21:10
techhelpbb's Avatar
OK,
Okay that description I agree forms strictly a relay based H-bridge.
Again, sorry about the confusion.
Unread 04-05-2012, 11:18
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
Thank you all for your input.
One last question:
If I can't pulse a relay, is it feasible to pulse a bunch of MOSFETs? The data sheet at sparkfun says the switching delays are < 1us As long as my pulse period is in the ms order of magnitude than I should be fine, shouldn't I? I don't see propagation delay having a measurable impact here... Just need to make sure to have flyback diodes, right?
Again, my experience with electrical stuff is all theoretical digital logic stuff, so your input is appreciated! This is what happens when a code monkey tries to actually make something
Unread 04-05-2012, 11:29
techhelpbb's Avatar
One last question:
Okay, before I step in this mess again.
Do you need forward *and* reverse or just one direction?
