Go to Post "at some point in the next six weeks you are going to start feeling like you are involved in a robot building contest. Then you are in serious trouble" -Dean Kamen - KenWittlief [more]
Unread 03-05-2012, 21:29
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Victors or Jaguars
In permanent fault, either can continue to produce output current when the robot is disabled. It seems that the Jags are more prone to this condition.
This is correct. I'd like to add that the situation I've seen with the Jaguar fully on but disabled was not a permanent fault (at least not one where it happened and the unit never recovered...I still have the unit and it still works...don't know if it's entirely uninjured but it can drive a CIM).
The other mentor had a specific process to inducing this failure. He indicated to me that he had forwarded his findings to FIRST and was distressed they did not apparently respond to it.
I've never been able to replicate the fault beyond a very small number of late night sessions where I was hot on the trail of an unrelated issue.
