Go to Post The numbers that I gave were purely theoretical and should not be considered realistic - Karibou [more]
Unread 04-05-2012, 00:29
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Victors or Jaguars
Originally Posted by Andrew Schreiber View Post
My personal preference is Jags based on my love of CAN. If not for CAN I'd use Victors.
I have to agree with this. If you're not going to use CAN, stick with Victors. If you think CAN is imperative for your application, then add Jaguars to the mix. We had Victors for everything except our shooter motors, which were controlled with Jaguars running their infamous closed-loop PID.
One point that I've never seen mentioned before and I feel really needs to be said is that if you use CAN, make sure you have people in the pit crew who know how to troubleshoot it. There are many teams that never run into issues with CAN (and that's great for them) but there are infinitely more teams who experience incessant issues with CAN. Jaguars are much more complex devices than Victors and have far more failure points. Familiarity with and knowledge of CAN is an absolute must, and there are only so many issues that can be caught during build season (like finding out that your CAN loop takes longer to execute than the allocated loop time).
We had one incident at our first regional where only after ten minutes of frustrated troubleshooting did we manage to isolate the issue to a bad Jaguar in the CAN chain (the traditional move-and-replace-stuff method just barely caught this), which for some (still unknown) reason refused to interact with other Jaguars on the network (no, it wasn't a contact pin issue; later off-board testing yielded inconclusive results as to the source of the problem). If it wasn't for my and another programmer's familiarity with CAN (our lead programmer even had to step back, due to his unfamiliarity with the issues at hand), we may never have caught the problem in time. I eventually handed it off at CMP to a TI rep who hopefully will be able to get back to us with more concrete results.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
