Go to Post Adaptability is the key folks. Your job will not be the same 10 years from now (when I retire), or 20 years or 30 years from now. The tools and systems you use will change, and you must be able to adapt along with them. - Bill Moore [more]
Unread 04-05-2012, 00:59
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: Best bridge manipulators/balancing mechanisms?
Originally Posted by Treadus View Post
But maybe I'm a little biased...
Nah. You aren't biased, you just love your sisters! And while this seems like I'm being self centered, I do think that we had one of the best bridge manipulation systems. We use our entire robot as the appendage (see attached pic)
And we have done some research and found out that we are ranked in the top 20 in the world for teleop points so we have determined that we did not make it to championships this year purely because of bad luck and/or the Woodie Flowers curse
Name:	Screen Shot 2012-05-03 at 11.54.58 PM.png
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 04-05-2012, 09:30
waitwhat?'s Avatar
waitwhat? waitwhat? is offline
Driver Coach
AKA: Bunca
FRC #0747 (Flight Crew)
waitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant future
Originally Posted by slijin View Post
Does anyone know whether their battery shifting mechanism was particularly useful as a balancing aid? It was something we considered early on, but rejected because we didn't think the ~17lbs of battery and apparatus would be particularly significant, among other reasons.
To answer the OP, 118. Their entire frame was built for passive bridge manipulation, and a good portion of their mechanisms were devoted to balance assists. They had a beautiful system to assist a double balance, complete with lights to indicate an unbalanced v balanced bridge. And that's all before their stinger.
I was skeptical of the effectiveness of this mechanism as well. However, given the fact that our battery was one of the heaviest and highest mounted components on our robot, we actually were able to use the weight shifter relatively well. The battery sits about 2 feet off the ground, and at least 90% of the robot is beneath is.
That being said, just to give some perspective, we parked our bot balanced, by itself on one of the bridges on the practice field, and we were able to get the bridge to start rocking back and forth without moving our wheels, only shifting the battery. Much more effective than I had initially thought.
Unread 04-05-2012, 10:42
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
One of my favorites would have to be 2056's manipulator/ball gatherer. It was used in unexpected ways when they would shove it under the bridge to aid the balance.
Some people have mentioned 1730's passive manipulator. For those unfamiliar: http://youtu.be/g_7ljqbIdi8?t=15s
I like the idea behind this design. I haven't seen anything like it other than theirs but if someone has go ahead and bring it up. With video/pictures
Unread 11-05-2012, 02:28
kiasam111's Avatar
kiasam111 kiasam111 is offline
AKA: Kiatin
FRC #3132 (Thunder Down Under)
Team Role: Webmaster
kiasam111 is a glorious beacon of lightkiasam111 is a glorious beacon of lightkiasam111 is a glorious beacon of lightkiasam111 is a glorious beacon of lightkiasam111 is a glorious beacon of light
I really liked 233, Team Pink's bridge manipulator. They just pushed it down and it covered right over the bumper, eliminating user error.
Unread 11-05-2012, 11:02
Samwaldo's Avatar
Samwaldo Samwaldo is offline
College Student / Between Teams
Samwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to behold
On our robot (team 1099, the disco techs) our shooters, ball picker upper, mechanism to move ball in shooter, electrical board and battery (over half our wait) moved, allowing us to move a large ammount of wieght while also changing the angle of our shooter. This helped while on the bridge alot!
