Go to Post Also, If I am not mistaken, the name indicates that your robot is female :P They're all female... like cars, ships, and airplanes. - JVN [more]
Unread 04-05-2012, 09:56
Norfen Norfen is offline
FRC #0302 (The Dragons)
Norfen is an unknown quantity at this point
Finding Documentation
Team 302 has decided to look into C++ for next year, and we've run into an odd problem. We can't find much documentation. The majority of the stuff we found is from 2008-2010 and such. Is there any central source or do we have to hunt?
Unread 04-05-2012, 09:59
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Finding Documentation
FirstForge is the "official" place for WPILib for C++ and Java. This link should take you to the Documents section.
http://firstforge.wpi.edu/sf/docman/...ib/docman.root
Unread 04-05-2012, 10:24
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
WPI's ThinkTank portal has some programming resources
http://thinktank.wpi.edu/tag/38
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 05-05-2012, 09:15
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
The best documentation is ALWAYS the source code. Luckily for you, WPILib is open source, and you get said source when you install the software.
Also, if you've ever used doxygen before, you can generate documentation FROM the source code. This documentation is *relatively* complete. You can see an example at http://rbmj.github.com/612-code/doc/html/ of what this looks like.
