Go to Post At the end of the day, it really isn’t about the awards. - JesseK [more]
Unread 04-05-2012, 20:16
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: 2012 Lessons Learned:The Negative
Originally Posted by IndySam View Post
I can absolutely guarantee you that this was not the case. If it appeared it was it was truly just a random thing. I am basically appalled that you would believe that the head ref or reset people would conspire against you.
We saw this as well. In several matches, the same thing happened to us (and our scouts, like 1718's, found that it was happening in matches where a robot was setup to do a bridge autonomous, but not other matches)
When we questioned the field reset (and later head ref) including the Q&A mentioned above (stating that the balls will be placed in the center of the bridge), they made up stuff about the ball placement requiring the balls to be symmetrical on the bridge but not necessarily in the center, and the Q&A not being the rules.
When we talked to Aiden Brown (FRC Head Ref), including a picture of the ball placement and Q&A, the ball placement went back to normal (side by side, center of the bridge).
Kettering Motorsports
