Go to Post The toughest regional is always the one you are competing in! - AcesPease [more]
Unread 04-05-2012, 23:01
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: 2012 KOP Wheels failing.
For the record no loctite was anywhere near the wheel.
Seeing this is an somewhat common issue we will probably fill the area around the bearing with some epoxy to help it hold up.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 04-05-2012, 23:33
Brant Bowen Brant Bowen is offline
no team (AndyMark, Inc.)
Brant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant future
Send a message via AIM to Brant Bowen
I saw a few of these that were broken at Championships.
You said that the first one that broke was one of the middle wheels. What wheel was the second one that broke? Do you remember?
Operations Manager - AndyMark Inc.
Co-Volunteer Coordinator - Boilermaker Regional, Crossroads Regional, Indiana Robotics Invitational
Unread 04-05-2012, 23:34
Mk.32's Avatar
AKA: Mark
We broke one of the middle wheels, switched it then broke the other side middle wheel a week or so later.
