Go to Post 118 embodies everything this entire program is supposed to be about: INSPIRATION. Respect that. Acknowledge that. Support that. - barn34 [more]
Unread 02-04-2012, 09:46
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
pic: VEX power from 12v
Unread 02-04-2012, 09:48
djshaffer djshaffer is offline
FRC #1708
djshaffer is an unknown quantity at this point
Re: pic: VEX power from 12v
im woundering what resistors you had used in this project, my team is wanting to do the same thing, Thanks!
Unread 02-04-2012, 10:06
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Whoa, way to revive an old thread!
The key part is a variable voltage regulator (probably an LM317T), so take a look at the datasheet to find out exactly what resistors you need. The Vex controller needs between 7.2 and 9V. You could also use a straight 9V voltage regulator, although you would probably have to order these instead of getting them from Radio Shack.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 02-04-2012, 13:23
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Plug it into your Digital Sidecar, that's all we did.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 02-04-2012, 14:36
There were no Digital Sidecars in 2006.
Unread 02-04-2012, 17:51
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
the vextrollers do work at 12v. just have to be careful with the amp draw at the higher voltage.
Unread 02-04-2012, 19:54
DonRotolo's Avatar
Back to humble
FRC #0832
The LM317T also really prefers a heat sink for anything more than about 1/2 Amp, and a large capacitor (~10 uF) at the output will help it as well. Again the datasheet is your friend.
Unread 05-05-2012, 02:40
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
I made one of these based on the information in this thread and a data sheet from I believe it was TI. I've drawn up a rough sketch of what the circuit looks like and figured I'd share it. Works great for us and outputs 7.2 Volts, just about what the Vex computer would love to have.
Here's the rough schematic I made:
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Unread 05-05-2012, 02:53
http://www.vexrobotics.com/products/.../276-2170.html
At least on the old computer it says that with motors and servos the computer should draw about 62 mA. I have a heatsink on the LM317 on the converter I made but after testing it and reading this bit of information, i think it may be unnecessary.
