Go to Post It wasn't about the ROBOT, or about whether I was male or female, it was about getting to compete in something that was just SO cool. - BandChick [more]
Unread 05-05-2012, 22:10
nxtsoccer nxtsoccer is offline
Wearer of the Pirate Hat
FRC #4087 (Falcon Robotics)
nxtsoccer is an unknown quantity at this point
Mechanum Wheel Sizes
Hello, my team (4087) recently completed our first FIRST season at FRC. We had a blast and are talking a lot about expanding the size of our team, budget, and quality of our robot for the 2013 season. Anyway, one major topic that my team has been talking about is holonomic drives, specifically mecanum ones for next season's robot. I've been doing some research into these wheels and have found many mixed success stories. At any rate, I found much info online as well as on Chief Delphi, however, I could not find a good thread discussing which sizes of mecanum wheels generally work best. I read somewhere that teams had problems with the 6" AndyMark mecanum wheels deforming and the 10" AndyMark wheels seem very expensive, too large, and too heavy for practical use in FRC. Does anyone have any first-hand experience as to which size(s) work well (movement not too bumpy, resistant to damage, ease of mounting, etc.)? Any recommendations and/or comments are welcome! Thanks in advance!
Unread 05-05-2012, 22:31
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
Re: Mechanum Wheel Sizes
Not to be a downer but in most FRC applications a standard 6 wheel "drop-center" tank drive with grippy wheels like Colsons will bring you far better performance than a mecanum drive train.
However, if your team is dead-set on using an omnidirectional drive train, I cannot stress enough how important it is to build the system you want to use in the OFFSEASON. This way you can work out all the kinks and learn from your mistakes. Building an omnidirectional drive system for the first time during build season will bring unexpected challenges that will require much more time than you think in such a short 6 week build window.
As for wheel size... I'm by no means an expert but the better applications of mecanum I've seen tend to be using 6" wheels.
MORT Team 11: 2008 - 2015
MKI Team 1923: 2015 - Present
Unread 05-05-2012, 22:46
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
I beg to differ on this point. The simple reason why tank usually outperforms mecanum drives is because drivers usually don't use mecanum to it's fullest potential. Mecanum drive is an unconventional drivetrain, thus it takes practice more than anything to be able to use the strafing regularly in your driving. People generally are not used to having that ability when driving, nor are they used to being able to spin on a point. The biggest thing you need if you're going mecanum is practice using it.
Aside from that, everything else Eric said is true about mecanum, though our team managed it in season. More complicated omnidirectional drives (ie swerve or octacanum) would require much more time.
Academic Student (Forever)
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
I wouldn't be so quick to dismiss mecanums, but there are better ways to achieve maneuverability - of course, that's another discussion itself.
We used 6" mecanums in 2011 with great success; we had absolutely no problem whatsoever with wheel damage. We did come away from that season with two particularly important lessons, though:
1 - make sure your wheels are always in contact with the ground. Although it seems obvious as the kinematics of mecanum drive rely on all 4 wheels, it's not obvious when your chassis is warped. Following unaccountably erratic driving control halfway through qualifications at CMP last year, we discovered slight chassis warp, on the order of 1/8" to 3/8". It ended up with two mentors jumping up and down on our chassis to fix the warp (we students weren't heavy enough ). After that, driving control was much more precise.
2 - precise speed control is a must. Because the nature of mecanum requires that each wheel be individually controlled to a relatively high level of precision to enable accurate driving, it's imperative that the software is capable of precisely controlling wheel speeds relative to one another. Unfortunately, it wasn't as easy as tossing CIMs into Nanos and bolting them to our chassis. Developing effective speed control took our software engineering team a good amount of time, and it was only thanks to that that we were able to achieve the level of driver control that we did.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 05-05-2012, 22:47
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
AM sells 6" 8" and 10" mecanum wheels.
The 6" and 8" are geared towards FRC use. We have used 6" HD wheels and loved them. We never had a single failure.
10" are pretty cool but a bit of overkill for FRC.
Unread 05-05-2012, 22:51
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Even at its fullest potential, I'm not convinced you will get better performance our of a mecanum drive.
I can't speak about mecanum wheels specifically, but we've come to like using the smallest wheels we can. They have a lower moment, they're lighter, and you need less gearing.
Unread 05-05-2012, 23:09
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
This thread has quite a long discussion about mecanum wheels. Take a look at it.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 05-05-2012, 23:18
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Red face Re: Mechanum Wheel Sizes
It's perfectly natural for a team your age to feel things like this. Many of us have experimented with holonomic drive trains at one time or another. It's nothing to be ashamed of, and it's good that you've come to us for help. With hard work, focus and determination, you'll come through this, better than ever.
The thing to remember is this: every single person on every single team, including the best teams in FIRST, have, when first presented with them, looked at mechanum drive trains, and said, "Whoa, cool!", and not one robot built with them has made it to Einstein in at least 2 years (because that's how far back I've checked).
It's not because they suck inherently, it's because it's hard to make them run to their full potential. So, because you'll ignore this warning and build it anyway (because, "Whoa, cool!"), the best advice I can give you is this:
1. Encoders on all 4 wheels
2. Only run it closed loop (typically velocity mode)
3. Make sure each one of the (48) little rollers is free spinning before each run. Bent wheels can cause these to bind.
4. Understand what the code needs to make the math work, especially any code you don't write yourself.
5. It still probably won't work great on anything but a flat floor.
People below me will contradict points 1,2,5, and maybe 4. They will have counterexamples. They also probably have a grandfather who smoked 4 packs a day and lived to be 100. Ignore them, believe me.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 05-05-2012, 23:19
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
I would suggest waiting until the game comes out before you decide whether you want to do a mecanum drive. Some games are going to be better suited than others for that drive. In my opinion, 2011 was a pretty good year to use mecanum, and 2012 was less suited for it.
2011: flat field, pretty big protected offensive zone where defenders can't touch you, scoring pegs are easier to score on if you can strafe, human players can throw the game pieces most or all of the way to the scoring zone.
2012: Harder to balance on bridges with mecanum, strafing less of a benefit for lining up to goals (but admittedly useful for gathering balls). Mecanums can get over the bump, but I don't feel warm and fuzzy about ramming that type of wheel into a steel barrier (seems like rollers would get bent and start to stick)
To address your question, though, here are my thoughts on 6" vs 8" wheels:
6": cheaper, lighter, smaller, less gearing required
8": tougher (except now there is a heavy duty version of the 6" wheels)
Even though we've used 8" twice in the past, I think we'd start by looking at 6" if we were going to switch back to mecanum for some reason. I'd probably be looking at direct driving them with a set of Toughbox Nano gearboxes with one of the lower optional gear ratios.
Unread 05-05-2012, 23:27
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
FYI, Mecanums ALMOST made it to Einstein. 2171 was a Finalist on Curie in 2008 and they were rocking AM 8" mecanums (IMHO the best COTS mecanums for FRC use).
Agreed that it is best done initially off-season and that competition usage should be decided on a game by game basis. Also agreed that part of the battle it is knowing how to use all 3 dimensions to the drivetrain.
Unread 05-05-2012, 23:37
Woah! First off, I'd like to thank you all for the amazingly immediate responses! Second, based on recent posts, I'd like to put something out here: we're a one-season team with only two or so of our members having any previous robotic experiences (myself and one or two others). Additionally, this is the first time I (and I believe my teammates) have gone beyond the LEGO Mindstorms NXT (r) level of robotics. In a nutshell: I''m really not sure what to think of some of these posts, much less what they mean! I know what an encoder is (measures/counts rotations), but I don't see how that would be beneficial to a holonomic drive. As for code, if we decide to go with mecanum wheels, they'll almost certainly be driven using four jaguars and the code for holonomic drive found in the WPI Robotics Library in LabView, without any changes.
Thanks for understanding our current lack of experience in pretty much everything at this point!
Unread 06-05-2012, 00:01
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
357 doesn't have a big presence on Chief Delphi, but if anyone is going to get to Einstein with mecanums, it will be them. I'd suggest trying to get in contact with them if you're looking for help designing driver practice for this or any other holomic drivetrain.
Unread 06-05-2012, 00:23
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
What bad things should I expect to happen when I run mecanum with open loop control?
Unread 06-05-2012, 00:29
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Encoders are beneficial to a holonomic drive because these drives largely rely on the kinematics involved with the wheels going at very precise speeds. Since an encoder can measure the revolution (in this case of the drive axle or an axle coming off of the gearbox), it is the proper sensor to close that loop and accurately control the speeds of all of your wheels.
If a mecanum drive is coded for voltage control (no closed loop, just set the motors to a given voltage), you could have a situation where your driver commands the robot to drive straight forward, but only 3 of the 4 wheels are driving close enough to the same speed. That fourth wheel driving at a different speed than the other three will cause a slight rotation/strafe in the driving, resulting in a robot that will not be able to drive in a straight line. This is why speed control of the wheels is very important and encoders can be used to achieve this.
Good luck, and I hope you guys have success with your off season projects! It's this kind of work that will prepare your team for a successful season.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 06-05-2012, 00:57
rocknthehawk's Avatar
rocknthehawk rocknthehawk is online now
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
If it's something your team wants to do, got for it! There will be naysayers that will give every reason not to try it, but what fun is that? Pushing yourselves to try something new, and learning in the process, can be hugely beneficial.
This was our (Team 126's) first year using mecanum wheels. I don't think anyone would have changed this decision. Our camera alignment was fantastic, with the ability to strafe. We spent a lot of time calculating gearing. We ended up with a final drive of about 17.5:1, CIM to wheel speed. Secondly, lots of drivers practice. Usually 4 days a week for 2 hours or more.
We did not run encoders on our robot. We initially made custom mounts for encoders, but ended up finding we did not need them. I don't know the programming side well enough to understand why, or what we did differently. Just that it didn't operate any differently for us not using them.
We used 8" AM wheels. They are heavy. I don't think the washer and brass bushing for the rollers is the best design possible, but it's simple and cost effective.
