Go to Post stop whining about something that can be solved by working harder. - artdutra04 [more]
Unread 06-05-2012, 00:06
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: 967 Off Season Project
While I disagree with a few of the detailed decisions in this, I can't question the quality or the work ethic that brought this to existence. It's this kind of detailed and quality work in the offseason that will bring your team to the top level.
I love the bellypan, in the future I would try to add material to the bellypan specifically for electronics; it forces a clean layout and lets you mount electronics with the minimal amount of weight.
I think switching to a 2-stage gearbox, then directly driving one of those wheels would clean up the assembly and increase reliability substantially.
The webb of the diamond pattern could be decreased for maximum weight efficiency, but probably isn't too heavy now.
What is the weight of the two outer "rails"? Seems like a lot of material in there that could be pocketed out, especially with the reinforcement bumpers provide.
Why Omni on the outside, you could easily do traction without sacrificing turning speed or ability.
Overall I like it though, it definitely looks robust and quality. Don't take my questions negatively, I just hold drive trains to a ridiculous standard.
Thanks for the great reply.
I believe the outer rails are 2.25-2.5 lbs each, based on a pretty similar model that I have on my home PC. Agreed, some pocketing on those would be a good next step.
2 stage + direct drive would be smart, no doubt. We liked one stage because it is so light and simple, it puts the CIM motors a little lower, and it puts the weight right in the middle of the robot. We aren't locked into a particular gearbox, though. Two speed is also an option that we will consider. We'll try to drive this thing hard and see if we can break chains with it, and that might influence the direction we go.
There is a good reason for the omni wheels, but let me wait until the students put out their other teaser. You will probably see what we did from looking at that. We stole that wheel arrangment idea from Team Titanium, by the way. Their 2011 bot has a 2 speed 4WD with four unpowered omnis on the corners. It's a cool drive.
Unread 06-05-2012, 15:25
Gigakaiser Gigakaiser is offline
AKA: Brandon Hjelstrom
FRC #0987 (High Rollers)
Gigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant future
A wild guess:
A wheel may be dropped through the hole on the frame, tilting the robot on the omni wheels. The dropped wheel is powered and lets the robot strafe.
FRC Team 987 - It's not enough
Unread 06-05-2012, 15:40
404'd's Avatar
404'd 404'd is offline
Lead contributor of sweg
AKA: Josh
FRC #0967 (Iron Lions (9-sits-7))
404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all
Originally Posted by Gigakaiser View Post
A wild guess:
I didn't think someone would guess the drive correctly this fast. Good guess! Here is a link to a video of an earlier version of this drivetrain. http://www.youtube.com/watch?v=X5rNaMhytZQ
We'll get our CAD model, pictures, and a video of the finished drive posted sometime early next week.
Driving "Career":
2012 GKC: Quarterfinals w/ 6th seeded alliance | Wisconsin: Quarterfinals - 3rd seeded alliance captains
2013 GKC: Quarterfinals w/ 5th seeded alliance | North Star: Regional winners, 2nd seeded alliance captains
2013 CMP: Curie Semis w/ 2056 + 3990
Unread 06-05-2012, 15:53
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Very cool. Why not 3 traction wheels per side though, and the omnis at the other end from the drop down wheel?
Seriously this is cool. It would be such a pan trying to T-bone you.
Unread 06-05-2012, 16:02
gracie.'s Avatar
gracie. gracie. is offline
forgot the heat shrink...
FRC #2399 (The Fighting Unicorns)
gracie. is an unknown quantity at this point
i know you guys are still working on it, but how much does it weigh?
2399: The Fighting Unicorns! - Alumna, team sister | Dean's List Finalist 2013
Anyone need a mentor in west LA?
Unread 06-05-2012, 16:24
JeremyLansing's Avatar
JeremyLansing JeremyLansing is offline
Team 967 Alumni
FRC #0171 (Cheese Curd Herd)
JeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud of
We decided to go with the omnis in the back to center the turning circle of the robot in 8 wheel mode, if we had used 3 traction wheels then the robot would have pivoted around the middle set of traction wheels not the center.
Unread 06-05-2012, 17:37
Gray Adams's Avatar
If you drop the center 4, then you're only ever riding on 4 wheels at a time. With your weight balanced in the center, you'll only pivot on the middle 4 wheels. All turning as far as traction wheels is concerned is just like a standard 8wd, despite the omnis at the other end.
Unread 06-05-2012, 18:16
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
Actually, we have it finished and will upload the final pictures this week. With all of the electronics and pneumatics it weighs just under 70 lbs (not including bumpers or battery). There are a few places where we can very easily save weight, but it would be hard to get it much below 65 lbs.
You are correct - that would make the most sense. The omni wheels on the front can't be raised much from the middle traction wheels, because otherwise you have to jack the back end up a lot more to clear all of the traction wheels in 3 wheel mode. With that in mind, we just went with all of the axles at the same height. It didn't occur to any of us to raise only the back wheels as traction wheels until we were putting this robot together.
Unread 08-05-2012, 21:55
404'd's Avatar
AKA: Josh
Here's some finished pictures and a video of the drive. Including a bridge balancing photo demonstrating the weight distribution of the drivetrain.
Video demonstration of strafing and driving:
http://www.youtube.com/watch?v=6gPQ8...qscNRRl5ahrunA
More Pictures on our Flickr stream
Driving "Career":
Unread 13-05-2012, 16:27
Jibsy's Avatar
Jibsy Jibsy is offline
Mentor - 3756, 4525
AKA: Jared Baribeau
FRC #3756 (Ramferno)
Jibsy will become famous soon enoughJibsy will become famous soon enough
I like this a LOT... Seems to achieve strafing ability without all of the negative side effects brought about by other drive systems (weight, complexity, lack of pushing power, etc).
I am curious though.. I think I'm missing how it manages to slide sideways without pivoting when the strafe wheel is so near the back.
Are the rest of the wheels on break mode such that the front omnis don't rotate, and rather just slide sideways on the mini wheels?
Not the best explanation of my question... but maybe you will understand.
Unread 13-05-2012, 17:45
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
Thanks! When we strafe, in addition to turning the sideways wheel, we also do a turn with the front omni wheels. Those are used to create enough torque to counteract the torque caused by a strafing wheel that is close to the other side of the robot.
Unread 13-05-2012, 21:02
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
This is extremely cool! How is the drive system when it is a competition weight? IE 150lbs total with bumpers and a battery?
Very cool design overall to give yourself the lateral movement.
EDIT: Could you post some more pictures of the wheel pod? Is that a custom gearbox or a CIM-sim from AM?
1058 PVC Pirates 2016 - xxxx
Unread 13-05-2012, 21:03
AdamHeard's Avatar
Lead Mentor
I figured this would be necessary for nice performance, about how much power are you applying to counteract the drift?
Are you doing it on some guesstimated value, or using a gyro to hold a heading?
Unread 13-05-2012, 23:37
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
We haven't tested this one with full weight yet, but we will. The previous prototype from the video worked well at close to full weight. That will be interesting to see, actually. The gearing is conservatively slow on the 9th wheel, so my guess is that it will strafe pretty similarly at full weight.
We should be able to eventually take some closeups of the actual wheel setup, but for now I can provide some CAD shots of the gearbox module. By the way, I designed the 9th wheel piece, but one of our students can take credit for the rest of the CAD design.
This is a custom 3 stage box that is basically a Toughbox plus a CIM-Sim. This is not the newest version (it's on a USB drive at school), so some minor differences exist. In particular, I swapped in the 60T gear from the CIM-Sim when AndyMark released that product. I LOVE that gear. The actual gearing is something like 60:15 / 50:14 / 50:16.
The thing is a puzzle to put together. I probably got carried away a bit in my efforts to make it as small as possible; notice the two holes on top of the gearbox for holding the top pivot brackets on - it is necessary to put the screws in there first, then assemble the rest of the gearbox, then tighten them last by poking the allen wrench between gears. It's a good thing the side plates were bent perfectly at the shop, because they need to be to fit together. Maybe for the next version we can think of something a little easier to make.
We thought about pushing the 9th wheel straight down instead of pivoting it off the back rail/bumper, but we never came up with a clean way to do that without adding a bunch of structure and weight in the back.
We're using both a fudge factor and a gyro. Maybe Josh will comment more on his programming. The programming presents some interesting challenges, to be sure.
It takes more power from the straight facing wheels than I would have expected. On last summer's 7 wheel version, the straight omni's couldn't keep up with the sideways wheel if we had it in low gear. In the new one, the 9th wheel is geared slower and the one speed drive is faster than the low gear we used last summer, so I think the 9th wheel's speed limits our strafing speed now. Josh, feel free to provide better info on that.
Picking the gear ratio for the 9th wheel is an interesting problem. Ideally, it would be nice if the 9th wheel accelerated the robot around in a circle at the same rate that the main drive's omnis accelerate into a turn in the other direction. That would reduce the amount of correcting needed based on the gyro feedback.
Unread 13-05-2012, 23:51
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
I'd like to call out a few teams that inspired our team and got us interested in trying a project like this.
JVN and 148 released lots of information about their Nonadrive after the 2010 season, including the
CAD model and a lengthy build season journal.
Madison and 488 put out lots of great pictures, videos, and answers to questions on their Octocanum drive starting in 2011, with an update in 2012. We've seen a bunch more octocanums since then, and I think 488 has a lot to do with that. I don't know if they were the first to do it, but the info they put out was awesome and caught a lot of peoples' attention.
Team 1625 put out info on their Lobster Drive last year, and I thought it was a mind-blowingly elegant way of turning a 6 wheel drive into a strafing machine without any extra motors.
I'm not saying these are on the first teams to ever conceive of a hybrid drive (I honestly don't know), but these are the ones who put out a whole bunch of information that we could devour and ponder. And they are all awesome teams who make awesome robots. My students and I really appreciate the openness these teams displayed with their designs, and we definitely learned a lot from them!
