Go to Post drill holes, that should fix it - E. The Kidd [more]
Unread 06-05-2012, 22:09
Po Taters Po Taters is offline
AKA: Joanna "Po" Zhu
FRC #0694 (Stuypulse)
Po Taters is an unknown quantity at this point
Scale Recommendations
During this past season, our scale went awry and broke on us - giving us incredibly inaccurate readings for the weight of our robot and made us wait, with our fingers crossed, until our first regional to get our official weight. Thus, we are currently looking for a new scale - hopefully, the same one that FIRST uses.
Does anyone know the name of the brand and the model that they use? If not, does anyone have a recommendation for one that's similar? (A link to the scale would be preferred )
Unread 06-05-2012, 22:14
Nate Laverdure's Avatar
FRC #2363
Re: Scale Recommendations
Scale from a thread a few years ago.
Unread 06-05-2012, 22:22
Originally Posted by Nate Laverdure View Post
Thanks for the link!
I tried searching for older, scale-relevant threads but couldn't come up with anything too useful. Guess I just wasn't searching with the right words.
In any case, Wow that's pricey!
Unread 06-05-2012, 22:25
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Just an FYI, despite the calibration weights, we found the scales almost 1/2 pound different between events this year.
Unread 06-05-2012, 22:29
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
http://www.scalesgalore.com/ohaus_sd...ing_scales.htm
We have something very similar to this. We use it to weight assemblies and systems and the full robot.
To weight the robot, we put 4x4's on it, tare it, and then put the robot on.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 06-05-2012, 23:17
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
I know that this isnt the post you may be looking for but i'll post it anyways.
We have a platform scale, that we found to be pretty accurate. Though this may not be the case for all. Before you go out a spend that $600 you have right in your back pocket (like we all do) I would try and find an old used one. We got ours from the GM plant that closed in Windsor (at least that's where i think we got it). Point is try and find a scale that a company is trying to get rid of. They may be just getting a new scale or closing their plant. A lot of companies have scales that could be used. I know most plants will have one because they ship parts into/out of the plant.
Or your other option could be to get your current scale repaired. I obviously have no idea what happened to it, but it could just be a quick fix, that you have no idea how to fix. It could end up saving you so $$ in the long/short Run.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 06-05-2012, 23:43
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
As a team who always seems to ship a robot weighing 119.9 lbs I wouldn't survive the build season without a dead-on accurate hanging scale. We used to have a cheap platform scale but found the weight varied too much as we moved the robot around on the platform. You'll see this at the competitions as well. With a hanging scale you never have to worry.
We have an older LED version of this scale which I got new on ebay for $250 five years ago. Just get one with 250lb capacity by .05 resolution. You won't regret it.
Unread 06-05-2012, 23:49
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I wasn't there, but according to our team we weighed in at 119.4 on Wednesday night at champs.
The next morning we went back to weigh again and were at 119.9, having not put anything on our robot since the previous night.
2001-2004: Team 100
2006-Present: Team 254
Unread 07-05-2012, 07:49
well, thats a little different... cause all your weight was from the crumbs of Cheesy Poofs your team keeps eating over top of your robot
2013-Present
2010-2013
Unread 07-05-2012, 08:13
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
If your school has a wrestling team, they may be willing to let you borrow their scale from time to time. We put a couple 2x4s on top of the scale, calibrate it, then set the robot on. The wrestling team scales are usually good to within a tenth of a pound, and they keep them accurate.
Hi!
Unread 07-05-2012, 08:14
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I've used a scale similar to this one since 2006 for weighing robots: http://www.amazon.com/Pelouze-RUBBER...392618&sr=8-15
At ~$150 it's a worthwhile investment, especially if you take care of it and get a few seasons out of it. We added a 38"x28" piece of plywood to ours along with some simple brackets to hold the plywood to the scale and it works great for weighing robots.
One thing to remember when looking at scales is that you're limited by it's minimum increment and accuracy. Depending on what you get, this could lead you to be off by +/- a pound or two.
-Dustin Benedict
Unread 07-05-2012, 11:38
scott scott is offline
Free Agent
AKA: Scott Ray
scott has a spectacular aura aboutscott has a spectacular aura about
447 uses a 4-pad Long Acre Racing setup. A mentor is kind enough to allow us to use his personal set. It is really nice to be able to see how each adjustment could affect the balance of the robot, and these came really handy this year to get the weight bias we were looking for. Pricey, but another option...
2015 INDY DISTRICT CHAMPIONS (1501 & 829)|2015 PURDUE DISTRICT FINALIST (1747 & 5402)|2015 IN STATE QUARTER-FINALIST (3484 & 461)|2014 IRI QUARTER-FINALIST (624, 33 & 2481)|2014 CORI CHAMPIONS|2014 QUEEN CITY REGIONAL CHAMPIONS (16 & 2665)| 2014 QUEEN CITY XEROX CREATIVITY IN DESIGN|2014 CROSSROADS QUARTER-FINALIST (3494 & 3940)|2013 CROSSROADS FINALIST (1288 & 1756)|2013 QUEEN CITY REGIONAL CHAMPIONS (379 & 1985)|2013 QUEEN CITY EXCELLENCE IN ENGINEERING AWARD|2012 QUEEN CITY QUARTER-FINALIST (379 & 1706)|2012 SMOKY MOUNTAINS QUARTER-FINALIST (1501 & 1261)|2012 SMOKY MOUNTAINS XEROX CREATIVITY IN DESIGN|2011 CAGE Match FINALIST (461 & 1760)|2009 WISCONSIN QUARTER-FINALIST (1024 & 2826)2008 BOILERMAKER QUARTER-FINALIST (1000 & 201)|2007 MIDWEST FINALIST(1000 & 648)|2007 MIDWEST XEROX CREATIVITY AWARD|2006 BOILERMAKER ENGINEERING INSPIRATION|2005 Creator of IRI Vex, "Enter-Action"|2005 CHAMPIONSHIP RADIOSHACK INNOVATION IN CONTROLS|2005 CHAMPIONSHIP GALILEO FINALIST(1108 & 492)
Unread 07-05-2012, 11:51
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
we use a shipping scale one of our sponsors (tx seagate) has.
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
Unread 07-05-2012, 11:54
FRC #2363
Also: you could take your robot to visit your local veterinary clinic. Vets usually have a large walk-on scale that should be kept very well-calibrated.
Unread 07-05-2012, 18:33
lorem3k's Avatar
lorem3k lorem3k is offline
1 + 1 = 0 (in Z/2Z)
AKA: Andy D.
FRC #1482 (Bishop Grandin Ghosts)
lorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to behold
What do you mean it's only for pets? This thing IS our pet!
Boo! Bishop Grandin High School / GM Canada / Tenaris
2013 Western Canada - Quarterfinalists (thanks 288/4719) / 2012 GTR West - Quarterfinalists (thanks 188/1075) / 2011 GTR East - Regional Winners (thanks 1114/1503)
