Go to Post Am I just a freak? - Josh Hambright [more]
Unread 05-05-2012, 16:35
AaronSonn's Avatar
AaronSonn AaronSonn is offline
FRC #0537 (Charger Robotics)
Team Role: CAD
AaronSonn is an unknown quantity at this point
pic: Prototype 8 Wheel Drive Chasis
Unread 05-05-2012, 16:37
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Re: pic: Prototype 8 Wheel Drive Chasis
This chassis is just begging to have AM Shifters sit on top of those side rails.
Good looking chassis, looks like you will need to do a lot of machining on it. What's the clearance from the bottom of the chassis to the ground?
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 05-05-2012, 16:43
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
What is the sheet-metal thickness?
Good enough is the enemy of anything great!
team 1671
Unread 05-05-2012, 20:29
Borobo Borobo is offline
AKA: Patrick
FRC #0159 (Alpine Robotics)
Team Role: CAD
Borobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really nice
you might want to think about putting another frame member somewhere in the middle of the side rails, especially with the heavy pocketing on the end members, it looks like it wouldn't be very rigid.
Unread 06-05-2012, 16:21
AaronSonn's Avatar
Team Role: CAD
We have a laser cutting sponsor that would be able to cut the frame out, so the only in house machining is really the spacers and driveshafts. It has 1.125" clearance in the middle and 1" on either side.
Unread 06-05-2012, 16:22
AaronSonn's Avatar
Team Role: CAD
.1"
Unread 06-05-2012, 21:01
AaronSonn's Avatar
Team Role: CAD
There will be a cross member when there is a special function added.
Unread 06-05-2012, 21:13
tzjin tzjin is offline
AKA: Tony Jin
FRC #0192 (Gunn Robotics Team)
tzjin has a spectacular aura abouttzjin has a spectacular aura abouttzjin has a spectacular aura about
Why not have the gearboxes in the center? An 8WD needs to have a center of gravity somewhere over the two middle wheels, or it will rock violently while turning. Chain will also be nicer if its symmetric on both sides.
With a smile,
Tony
Unread 07-05-2012, 12:39
Yalib Yalib is offline
FRC #2630 (Thunderbolts)
Yalib is on a distinguished road
If you bring the two middle wheels on each side closer to each other you would probably get better turning ability.. looks good!
good luck!
Unread 07-05-2012, 12:53
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
good luck!
If anything the center wheels should be further apart to avoid lots of rocking. 8wd with even spaced wheels already has a much shorter track length than a 6wd layout. Splitting the difference in lengths by spacing the center wheels apart seems to be the sweet spot.
Mentor 2415
Unread 07-05-2012, 12:55
ttldomination's Avatar
Sunny
I think if you maintain your COB on any portion of the DT, it'll really be ok. Sometimes, it's preferred that the gearbox is in the front/back to leave for a large mechanism/intake. Either way, I can say that on a 6WD it wasn't that bad, and I doubt it'll be as bad on a 8WD.
good luck!
Bringing the two middle wheels closer will allow for better turning, however, I think it will also cause relatively more rocking/disturbance. I suppose this is why we've seen various teams opt for the 8WD, but the middle wheels are actually spaced out *more* for added stability.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 07-05-2012, 19:40
AKA: Tony Jin
A 6WD needs to be slightly off-balanced so it stays on the same 4 wheels while turning. However, I do see your point of having more room for a mechanism or controls system.
With a smile,
Tony
