Go to Post ...remember, this is coming from someone that spent the better part of an afternoon playing with an omniwheel--not assembling, not disassembling, just playing. - Billfred [more]
Unread 07-05-2012, 18:14
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
8 Wheel Chassis Design
Finished My 10th Chassis Today!
Named: Silver Stream
Specs
- SuperShifter Transmissions
- 39.96 lbs
- 8 Wheel Drive
- 6" AndyMark Performance Wheels
- #35 Chain
- 1/8" Sheet Metal
- 1/8" Center wheels Drop
And Comments or Suggestions for Improvements are Welcome
Thanks!
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 07-05-2012, 18:38
ttldomination's Avatar
Sunny
Re: 8 Wheel Chassis Design
Very nice there.
I'd recommend reading through this running thread. Especially the parts about perhaps spacing out the middle wheels a little more.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 07-05-2012, 18:56
Are you suggesting that I move the transmissions to the back? And then move the middle wheels further outward?
I can understand why I should move the wheels out. But I wold rather have a better turning radius. The Rock wont effect too much.
The transmissions in the back would make it back heavy. thus making the back and rear-middle wheels touching the ground. then it wouldn't turn on the middle wheels.
This is how I had the chassis before, but i was told I should put the Transmissions in the middle to keep the COG in the center. I literally spent 1.5 Hours changing it to the middle of the chassis.
2013-Present
2010-2013
Unread 07-05-2012, 19:14
Sunny
I was referring to changing the distance between the center wheels, but if you prefer the quick turns, then so it shall be.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 07-05-2012, 21:58
FRC #1836 (MilkenKnights)
The turn speed should not change that much, unless there is significant scrub. That being said, there might be slight differences, but nothing really noticeable. It is not worth it though.
Unread 07-05-2012, 22:13
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Keep the transmissions centered but space the center wheels. Do a comparison between effective wheelbase between a 6wd and 8wd and you will realize the with the wheels evenly space on an 8wd your effective wheel base will already be shorter leading to quicker turns than a drop center 6wd. Try to split the difference somewhat.
Mentor 2415
Unread 08-05-2012, 07:38
Everyone is assuming that a 6WD center-drop drivebase necessarily rocks and has only 4 wheels on the ground at a time. This is not always the case. With just the right amount of center wheel drop, all six wheels are in contact with the field carpet at all times and there is no noticeable rock. With the appropriate center of gravity, the robot spins around its center wheels.
Besides, some 6WD systems have no drop and still work well.
Unread 08-05-2012, 08:30
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
This.
The average Long Base 6WD has an effective wheel base of somewhere around 14"-16" depending on wheel size and chassis design. The last two drive trains I worked on (10WD and an 8WD) had effective wheel bases of 16.5" and 17.25" and neither had any major problems turning and both liked tracking straight at speed. If I were going to make an 8WD again, I think I'd space the center wheels ~14" apart from each other to have a good mixture of straight line stability and maneuverability. (Short center wheelbase 8WD's have a tendency to over rotate)
-Dustin Benedict
Unread 08-05-2012, 09:48
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
I have a few other questions/comments.
What is your reason for selecting 6" wheels?
With the ground clearance, and lack of a "wedge" on the front and rear of the chassis, I don't see an advantage to a large wheel.
For a non-direct drive application, why choose the AM Supershifter over the Gen I shifters?
The AM Supershifter contains an additional reduction but is otherwise the same internally. The output of the Gen I can be modified so that the sprockets are outside of the gearbox (see out drivetrain from 2011 or 2012).
Unread 10-05-2012, 19:16
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Silver Stream has just been added to FRC Designs! Check it out!
FRC Designs - Drives: http://www.frc-designs.com/html/drives.html
Matt
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 10-05-2012, 20:49
Originally Posted by thefro526 View Post
This.
Sorry for the delayed responses.
Silver Stream 1.0 (I will have multiple version that I reiterate and they change to 2.0, 3.0...) has a center wheel base of 8in. I think in my next iteration I will change the wheel base. I have never made an 8WD Chassis before, so I wasn't exactly sure where thee center wheels would go for optimal performance. After looking at other 8WD (such as 2056's This year) I believe you are correct that the Center Wheel base should be larger. Though for the part about them over turning, could you not technically change that in the program? Although I think the better solution would be to fix it in CAD.
@jwfoss
My choice of the six inch wheels was mainly just cause I like them. They arent too small, or Giant like 8in. My team has no experience with smaller wheels, which I know isnt much of a change, but we are just comfortable using 6in or 8in. I personally don't like 8in though.
Regarding the supershifters...
We have used the gen I/II's for every year since 2007 except 2011. And we are simply sick of them. We though we would try something new, and we were looking at 234's Robot and liked the SuperShifter's they had.
You can find a lot of my Designs on FRC-Design.com
I love the idea of the site and I encourage anyone to visit the site to look for ideas from other teams, and to submit their own designs
2013-Present
2010-2013
Unread 10-05-2012, 21:03
In my opinion, there is no such thing as too small wheels, only wrong gearing.
Unread 10-05-2012, 23:54
Andrew Lawrence
Posts: n/a
Why are you sick of them? Performance? Maintenance?
Unread 11-05-2012, 00:13
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Suggestion: Beef up the axle mounts... they look a bit skimpy and given a hard enough ramming could warp. with an integrated design like that, such a failure could be catastrophic.
Unread 11-05-2012, 07:32
I have't had a problem with axle mounts like this in our 2012 chassis. What should I do to make them better? cross braces meeting in the middle? or make it wider? (currently 1")
@SuperNerd256
We've used them so much they have just been over used. We like the idea of having the gears closed in too. We wont have to worry about getting chips in the gears anymore.
2013-Present
2010-2013
