Go to Post I'll do my best, but I'm this --><-- close to telling our drivers they're NASCAR styling it this season..."Sorry boys and girls, left turns only!" - Mr. Lim [more]
Unread 05-05-2012, 18:20
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
KOP Accelerometer with Arduino
Hello,
Well I have spent a while banging my head into a wall trying to interface the KOP accelerometer with an Arduino to no avail. Does anyone know of an easy way to do this?
Thanks,
Davis Catherman
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 05-05-2012, 20:16
DonRotolo's Avatar
Back to humble
FRC #0832
Re: KOP Accelerometer with Arduino
Does the KoP Accelerometer have an analog output? If so, read the voltage at the analog input of the Arduino, then do the simple multiplication (or division) to come to a useful value.
Otherwise, what kind of output does the accel have?
Unread 07-05-2012, 17:01
FRC #0539 (Titans)
No it does not, but I have heard that the easier way to hook it up is via the 12C interface (4 pins).
I believe its the FIRST KOP accelerometer from 2011 but it was recent anyways (accelerometer + gyro combined).
Thanks,
Davis C
FRC Team 539
Unread 07-05-2012, 20:51
DonRotolo's Avatar
Back to humble
FRC #0832
Ah, OK, I2C. First watch this, then read this (and the second part, chapter 21). That'll help you make sense of I2C. Google can find other references too. Here is the programming reference. You'll need to find the details of the accelerometer yourself...
Unread 08-05-2012, 05:26
docdavies's Avatar
docdavies docdavies is offline
Doc Davies
FRC #0346 (RoboHawks)
docdavies is an unknown quantity at this point
You might also want to look into this item. This is the route we went...
http://www.ebay.com/itm/290631526078... 4.m1423.l2649
Unread 12-05-2012, 17:27
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
Use the source Luke. If you check WPILib, its just an read through the analog:
float Accelerometer::GetAcceleration()
    return (m_analogChannel->GetAverageVoltage() - m_zeroGVoltage) / m_voltsPerG;
