Go to Post In my opinion, the right mix of student, mentor, and engineer involvement is when everyone gives it 100%. - Jack Jones [more]
View Poll Results: Which Drivetrain
4 Wheel Tank 47 19.42%
6 Wheel Tank 92 38.02%
8 Wheel Tank 55 22.73%
10 Wheel Tank 3 1.24%
Mecanum 19 7.85%
Swerve 9 3.72%
Omni Drive 2 0.83%
Other (specify) 15 6.20%
Voters: 242. You may not vote on this poll
  #31   Spotlight this post!
Unread 08-05-2012, 17:14
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: 2012 drivetrain
Originally Posted by Tubatroopa View Post
We only did 6 so we could be wide and hang off the bridge.
Originally Posted by Siri View Post
True, It's not important for turning. That doesn't means it has no use. In fact extra wheels can provide many useful benefits, especially in non-flat field years.
I agree with you both. Yet there are only marginal incentives to drop the center wheel(s) in the wide drive configuration, as can be demonstrated by running through the math in the paper. My point isn't about extra wheels, but rather the negligibility of dropping those extra wheels. I also wanted to bring up a pretty good paper showing the math/science behind what people think they saw on the field.
GitHub
  #32   Spotlight this post!
Unread 08-05-2012, 17:42
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
Re: 2012 drivetrain
Originally Posted by Alex.q View Post
... I know 111 tipped up the front of their robot to do this, but I never saw exactly how this was done.
Correct. We had pneumatically operated 'landing gear' - two omniwheels on a plate that would push down and lift the front of the robot up. There were two sensors at the front, one on each side, so that when the front of the robot touched the barrier, the landing gear would retract so that the robot could go over smoothly*.
You can catch a quick glimpse of it in action in our reveal video at the 1 minute mark here
*As smoothly as a 120lb robot on air-filled tires can go.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
  #33   Spotlight this post!
Unread 08-05-2012, 17:43
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: 2012 drivetrain
Wide brecoflex tank treads.
  #34   Spotlight this post!
Unread 08-05-2012, 18:45
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: 2012 drivetrain
Wide base, 6-wheel tank. AM roughtop plaction center, omni-wheel corners, back 4 wheels powered. CimPLE boxes, 2 CIMs per side.
  #35   Spotlight this post!
Unread 08-05-2012, 18:51
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: 2012 drivetrain
Originally Posted by Taylor Nicholson View Post
Our method is passive. We just angled the front and back edges of drivetrain, and riveted on strips of Teflon along the entire base to slide over the the barrier. This has allowed us to drive full speed into the barrier and get over. On 1114, we like the Dukes of Hazzard method of getting over obstacles.
The drivetrain is a 6WD using the AndyMark 8" pneumatic wheels (long configuration).
It was very smooth looking from what I could tell. I was trying to figure out if that behavior could be replicated with 3.5" wheels and some 3x1 tubing, but it looked like you need something more like 4x1, if they even sell that. I know you guys use sheet metal, but do you know what the height from the bottom to the top of the angled part is, and what angle it's at?
The bump liked to get between our 6" wheels and lift our front really high in the air, and it always behaved differently when crossing. The teflon coated skis are probably helpful, but do you have any insight into what you think is most important? I'm guessing the frame getting close to the ground helps so you slide over, but that's just a guess.
  #36   Spotlight this post!
Unread 08-05-2012, 18:52
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
Re: 2012 drivetrain
Swerve baby swerve.
  #37   Spotlight this post!
Andrew Lawrence
Posts: n/a
Re: 2012 drivetrain
Just curious - Why not power all 6 wheels?
  #38   Spotlight this post!
Unread 08-05-2012, 18:53
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: 2012 drivetrain
Here's a picture of a prototype of our drivetrain. In this picture, we've got two in-house made drive wheels on each side, each being run by two CIM's. Eight colsons are being driven via polycord to power us over the barrier. In our final design, we're powering the lower four colsons on each side via a chain, and powering the upper four via a polycord linkage to the bottom four colsons. I'll try to get a picture that shows this setup tomorrow. It's actually pretty cool what our build team came up with, especially the tensioners. We ran the chains which power the four lower colsons thru a piece of PVC.
EDIT: You can sort of see the final setup in the lower right hand side of the picture, thru the hole in the side of the aluminum plate.
Name:	FIRST Prototype.jpg
ID:	12741  Click image for larger version
  #39   Spotlight this post!
Unread 08-05-2012, 18:59
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
Re: 2012 drivetrain
We had a wide base 6wd dropped center (3/32") with 6" plaction roughtop wheels. All 6 wheels are powered by 4 cims through toughboxes.
Anybody find it weird that according to the poll, there were more teams who did swerve than mecanum? At least at the regionals that I went to, this wasn't the case.
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
  #40   Spotlight this post!
Unread 08-05-2012, 19:02
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
Re: 2012 drivetrain
1126 was on Swerve drive. The problems that come with being a team in their first year of Swerve aside, the only major problems were had was not directly related to the Swerve. It was mostly that our robot was top heavy and the weight was poorly distributed (When we tried to drive onto the bridge, we would almost flip ourselves because our back wheels didn't have enough weight to keep the bridge down, so it would start coming up on the middle of our drive system).
That aside, the team is generally very happy with how the swerve turned out, and (apparently, I wasn't there) we were even complimented by 16 for having a swerve as good as we did for our first year!
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
  #41   Spotlight this post!
Unread 08-05-2012, 19:56
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: 2012 drivetrain
Originally Posted by Jefferson View Post
Swerve baby swerve.
Can you elaborate more on your module and frame setup, especially for getting over the barrier? I've been drooling all season since your reveal video and am still kicking myself for missing you at Champs.
Whoa. Can I ask how/why you guys came up with that idea? Looks awesome!
  #42   Spotlight this post!
Unread 08-05-2012, 20:33
FRC #0023 (PNTA)
Rookie Year: 1620
Re: 2012 drivetrain
I'll take more pictures tomorrow that better show what I'm trying to describe. I'm not entirely sure how/why we came up with the idea. All I know is the fact that we wanted to get over the barrier as well as climb up and down the bridges. I'll find out more info tomorrow.
  #43   Spotlight this post!
Unread 08-05-2012, 20:38
Billfred's Avatar
Billfred Billfred is offline
Re: 2012 drivetrain
2815 used a kitbot-derived 6WD--kit wheels and all. Our frame was a hair low for the bump, but I think that was okay in the end due to our CG. If I were doing it again, I'd be more conscious of figuring out the bump.
  #44   Spotlight this post!
Unread 08-05-2012, 22:36
cgmv123's Avatar
AKA: Max Vrany
Re: 2012 drivetrain
Wasn't my decision. I'm assuming it was because we would have only powered the center wheels, but they would have sat there spinning and looking dumb when we tried to go up the bridge and back gave more pushing power. (Carpet vs. lexan)
  #45   Spotlight this post!
Unread 08-05-2012, 22:49
AKA: Jeff Clements
Re: 2012 drivetrain
We had 4 modules with a CIM mounted in the module (no bevel gear) and a window motor turning. The encoder was mounted as flexibly as possible above the module.
Thinking back on the year, we probably could have gotten away with a three wheel system, but we had such luck with the four wheel swerve last year and 2010 offseason, it was hard to get away from.
We crossed the bump in both directions. Our ball pickup helped us in one direction. There were angled guides on the bottom of the box to lift that end of the robot as it contacted the bump and delrin guides mounted to the frame next to the wheels to make sure the wheels don't take the impact. On the other side, we just had the delrin guides next to the wheels.
