Go to Post it takes a village to raise a robot. - Taylor [more]
Unread 10-01-2003, 15:19
randomperson's Avatar
randomperson randomperson is offline
Assembler Freak
#0904
randomperson is an unknown quantity at this point
Send a message via AIM to randomperson Send a message via MSN to randomperson
Sensor response time...
Hmm.. does anyone know the response time for the optical sensors? I know that it says it in the paper for them.. but how long does it actually take before the controller will tell the program that the sensor is on/off? I guess a simplified version of this question would be what kind of sampling rate are we getting with the sensors?
main() {
srandom(time(0));
while(1) {
int pid=random()%30000;
if (pid>1 && pid!=getpid()){
kill(pid, random()&1 ? SIGSTOP : SIGBUS);
sleep(10); }}}
Visit my completely useless website! http://randomperson.cjb.net
Unread 10-01-2003, 17:00
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
The best sampling rate that you can have (if the sensor is hooked directly to the RC) is only about 40Hz, due to the extreme slowness of the BASIC Stamp.
The actual sensor can detect changes much, much faster than this (1000Hz according to it's datasheet).
Worst case the delay between the actual transition of the light sensor output and the time at which your code knows about it is 25 milliseconds. Also, if whatever you're doing with the light sensor causes a pulse that is less than 25ms long, you run the risk of the RC never knowing about the pulse in the first place.
Let me know if this didn't answer your question, and I'll try to explain it better...
Unread 14-01-2003, 17:55
n[ate]vw's Avatar
n[ate]vw n[ate]vw is offline
#0933 (Adler Attack)
n[ate]vw is an unknown quantity at this point
Send a message via AIM to n[ate]vw
We've been playing with automatic control using the light sensors and their response time seems to be negligible. Like Dave said, the delay is going to come from the code, not the sensors. If a light sensor is physically triggered at the time the loop is running, it's safe to assume that your program will know it.
Adler Attack #933 -- Trigos
Unread 14-01-2003, 18:15
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
You get the same sampling rate as with everything else connected to the RC: 26ms minimum. If your code is excessive complex, this could be as high as 40ms, but I haven't seen much past that.
Unread 21-01-2003, 10:41
The "response" seems to depend on setting of the sensitivy, which in turn depends on what is needed to discriminate between the red carpet and the white line.
On a red broadloom, I notice 'considerable' (and considerably varying) time between the light hitting the calculator-tape curve, and the robot's reaction to it.
time change David Kelly Chit-Chat 14 06-04-2003 23:10
Solution to Timing Loops Steven Carmain Programming 39 10-02-2003 13:33
How long should production time be??? archiver 1999 4 23-06-2002 23:16
what time zone? Amy Beth CD Forum Support 5 15-04-2002 02:41
need help with time zone! Ken Leung General Forum 6 25-06-2001 12:44
