Go to Post I bet a lot of us (mentors and students) got into this line of work first because we wondered how things work, and stayed in it because we thought "I can make that work better". Thus starts a life-long battle between perfection and time. So far, time is ahead. - petek [more]
Unread 04-05-2012, 19:25
nydnh01 nydnh01 is offline
AKA: Naresh Hing
FRC #1601 (Quantum Samurai)
nydnh01 is an unknown quantity at this point
Watchdog Not Fed!!!
Now that it is the off season our team is testing out our robot. When we run our robot the driver station keeps giving us the Watchdog Not Fed error and when we give a command the output is delayed. I have tried to reconfigured the cRIO but I keep getting errors and now I can't get the cRIO formatted or even get recognized by the laptop. Please help me solve this problem.Thanks in advance.
Unread 09-05-2012, 21:39
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: Watchdog Not Fed!!!
When you say you cannot get your laptop to recognize your cRIO, how are you connecting to it? Directly or via a router?
If you connect to the cRIO directly via Ethernet and set your computer's IP to 10.16.01.5 and subnet to 255.0.0.0, the FRC 2012 Imaging Tool should scan and detect your cRIO.
Unread 09-05-2012, 23:15
AKA: Naresh Hing
It turns out that I had to reconfigure the chassis of the crio and now we are able to communicate with the crio and format it.
