Any one up for a discussion?
I'm in the mood for a good engineering-based discussion. By engineering, I mean math, physics, programming, or whatever.
topics similar to: refraction of light: why did it start, and was it first noticed in water or glass? waves and electronics: why do microphones work, and who figured that out? etc. ![]() |
Re: Any one up for a discussion?
Here's a microphone fun fact tied to a bit of music history. Microphones basically work in the same fashion as a loudspeaker, only in reverse (sound wave -> electrical signal and visa versa). It uses electromagnetic induction - sound waves move a magnet surrounded by a coil, producing a current.
But anyway, when recording Paperback Writer, Geoff Emerick (the Beatles' recording engineer) actually used a loudspeaker wired in reverse instead of a microphone to record the low end of Paul's bass better. That's why that song has such a distinct bass line. Fun fact of the day! Last edited by plnyyanks : 10-05-2012 at 22:17. |
Correct! which, by the way, I think is pretty darn cool. How do you think someone discovered that?
If I had to guess, It started with two separate discoveries. First, the discovery that a moving diaphragm could pick up and reproduce sounds (ears and drums are respective examples that are respectively naturally occurring and well known throughout history). The second was that a current traveling through a coil can move things. Anybody passing a current through a long wire that had been coiled to keep it organized could have discovered this if there was any iron or magnetic material around, a compass would work too. Then the two were put together and the transducer was born.
Of course, that system was eventually optimized a lot. Tinfoil coating, for example. The second was a Michael Faraday thing, IIRC, but of course it wasn't seriously implemented in practice until amplification came about. But before then* Alexander Graham Bell used a bunch of carbon granules beneath the diaphragm which, when mechanically excited** generated a small current and, conversely, vibrated when electrically excited. * Emile Berliner actually had the first microphone, the "loose contact microphone", but it wasn't as practical as the carbon granule type, which is still in use today. **meaning 'have energy put in'. Don't get excited. |
By the way, the fact that these two cases had separate physical interpretations was a burr under Einstein's saddle that was a motivating factor for his 1905 paper On The Electrodynamics of Moving Bodies. Microphones can also use capacitance (sound waves move a diaphragm which changes its capacitive coupling to a second diaphragm) and the piezoelectric effect (sound waves distort a crystal which creates a voltage). |
