Go to Post I do this stuff because...well first inspired me to become me. I now understand who i am better and what i want to do. - Marygrace [more]
Unread 10-05-2012, 15:42
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Source for Shaft Couplers
Does anyone have a good source for inexpensive shaft couplers? I'm looking to couple a 1/4" od encoder to the end of a 1/4" od shaft for the steering portion of a swerve module. Both shafts will be smooth, no flat spots, so I'm looking for a clamp style (not set screw style) shaft coupling. To allow for some manufacturing tolerances I don't want it to be completely rigid, so I was looking at using a semi-flexible slit type coupling like this.
At $13.50 the SDP/SI plastic version is the cheapest version I could find. Aluminum versions all seem to be $25-30. Any comments on plastic vs aluminum?
Automation direct makes some (here) for $7 but they're setup for 6mm shafts. Does anyone have experience with these - do they work for 1/4" shafts, do they require modifications, etc?
Since we'll be buying several of these I'm trying to find the most economical option that will still be reliable. Any suggestions are greatly appreciated.
Thanks.
Unread 10-05-2012, 15:55
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Source for Shaft Couplers
While not very pretty, we often couple encoders to shafts using surgical tubing that is zip-tied into place. It works quite well.
--Madison--
...down at the Ozdust!
Unread 10-05-2012, 15:58
I've never looked at the cost while ordering these at work, but the company we always go to is Ruland.
http://www.ruland.com/index.asp
Unread 10-05-2012, 16:08
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
http://www.mcmaster.com/#standard-sh...plings/=hh6zib
There are a variety of shaft couplings here and you can specify which bore sizes you want.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 10-05-2012, 16:33
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Thanks.
Do you have access to a 3D printer? I've had good luck in the past with custom 3D printed couplers for applications like these.
-John
Unread 10-05-2012, 16:39
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
We've used these on our 2011 and 2012 robot for our arms/turrets.
http://www.mcmaster.com/#9658T3
-RC
R.C.
MadTown Robotics Team 1323
Unread 10-05-2012, 17:34
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Same here.
Unread 10-05-2012, 17:35
Gdeaver Gdeaver is offline
FRC #1640
We use the Automation Direct Couplers that were mentioned on our swerve steering sensor - 1/4" shafts. Just reamed them out. Be careful to not insert the shaft in too far or you will turn them into ridged couplers. A shaft flat can always be filed. Have worked well and the price is nice.
Unread 10-05-2012, 19:06
Small Parts Incorporated, they were an FRC sponsor long ago. Now they are part of AmazonSupply.
Unread 10-05-2012, 20:54
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
https://www.surpluscenter.com/item.a...ame=powerTrans
two of these would work
Unread 10-05-2012, 21:15
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
we made small flats on the potentiometer shaft and the shaft we were mounting on, and used the set-screw version from McMaster referenced above. They worked very well and are easy to install.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 10-05-2012, 21:54
We do the same. We got the idea from Dan Katanski from team 240.
Unread 10-05-2012, 22:52
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
In addition, that also is good for dealing with misaligned holes. Trust me, it happens.
Unread 11-05-2012, 00:53
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Unless you are 254/1114/1538/118/ETC
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 11-05-2012, 08:39
pfreivald's Avatar
AKA: Patrick Freivald
Anyone have a picture of how they use the surgical tubing to connect an encoder to a shaft?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
