Go to Post This is a risk. Life is full of risks. FIRST is life... therefore, FIRST is full of risks. - Andy Baker [more]
  #211   Spotlight this post!
Unread 10-05-2012, 12:36
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Intermittent connection on field only
Originally Posted by Mark McLeod View Post
Teleop shouldn't be showing a loop time any faster than 19-20ms, because it's triggered by the DS packets arriving every 20ms.
You've got something else wrong going on with Teleop.
I'm speaking of the actual time it takes to finish the teleop vi, not how often it is called. It is still called every 50ms as it should be. The actual processing of tr teleop vi is what takes only 3-4ms, and it should be pretty low and consitent for all teams.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
  #212   Spotlight this post!
Unread 10-05-2012, 19:45
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
[quote=RyanN;1168414
We have also been testing CAN out a bit, and found some unsettling results.
If you have an intermittent connection where a CAN devices does not appear on the CAN network, the whole CAN network will drop out, and the digital side car will not work. The thing is that the robot remains connected the entire time.
[/QUOTE]
I imagine the Digital Side Car not working is not a result of the CAN device dropping out, but rather, the error handling when a CAN device drops out is expensive and therefore watchdogs start tripping because loops aren't going fast enough and packets are processed quickly enough and suck.
This was not the cause of our problem as we went back to PWM during Bayou, but I can see teams complaining about no communication due to this.
[/QUOTE]
Again, expensive error handling means the cRIO stops processing communication packets with the DS, and there for it "loses comms"
We originally had 4 CAN-enabled Jaguars, IDs 2, 3, 4, and 5. ID 5 was the last in the chain, and had the terminator resistor installed. We wanted to test 8 Jaguars over the RS-232 to see how well it worked. Well, we assigned IDs 6, 7, 8, and 9 to the drive motors. When we plugged it all back in, nothing worked. We found out that when we extended the network, that the Jaguar with ID 5 had a bad RJ-45 port. To work temporarily, we rearranged the cables to make that Jaguar the last in line, and it all worked again.
So that's another idea that I had as far as troubleshooting.
We can't use the 8 jags though... I'm not sure if we reached the limit of RS-232 driving CAN, but we were getting tons of CAN timeouts, and Drive Motors not being called fast enough warning (in teleop). I analyzed the timing of Telop, and found that it ran every 10ms on average, but 60ms to 500ms spikes were not uncommon (where we saw the timeouts). When this occurred, we would also glitch/jerk.
[/QUOTE]
So, since the last Jag in line's other RJ-12 (RJ-45 is 8p8c I think, whereas the CAN plugs on the jaguars are 6P6C and 6P4C) port was bad, the terminator couldn't terminate, therefore it was like having no terminator. This wouldn't be an issue in a shorter chain since there isn't as much need for a terminator (I don't know why) but in a longer chain, it would cause timeout errors, and again, the error handling is expensive, so it would slow down the loop.
  #213   Spotlight this post!
Unread 10-05-2012, 20:18
mjcoss mjcoss is offline
FRC #0303
mjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the rough
I know that in the C++ case TeleopPeriodic is triggered, by default, on the arrival of a DS packets. This is bad if the network has a lot of jitter or latency issues. You can set the period, but then of course you need to handle the case where you have stale data.
  #214   Spotlight this post!
Unread 11-05-2012, 01:33
RyanN's Avatar
RyanN
The compressor is controlled in its own loop in periodic tasks and called every second. For no reason should CAN errors cause it to drop out like it is.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
  #215   Spotlight this post!
Unread 11-05-2012, 07:28
There actually is a possible reason for CAN errors to shut off the compressor. It's a second-order effect. The error processing and reporting uses up a lot of system resources, delaying other actions, including the communication task. The system watchdog times out because the data from the Driver Station didn't get processed in time. Every PWM and Relay output on the Digital Sidecar gets shut off. Since the compressor is controlled by a Spike relay, it stops.
  #216   Spotlight this post!
Unread 11-05-2012, 07:35
Oliver,
From what I understand, the resistors are an integral part of CAN signaling in addition to terminating the bus. With an intermittent resistor, CAN devices cannot signal when they want to transmit data to the bus.
Has anyone used a CAN splitter to any advantage?
  #217   Spotlight this post!
Unread 11-05-2012, 09:48
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Alan,
Great analysis. What I'm trying to figure out is how we've advanced, if when we used C, we would be careful about interrupt priorities so that critical functions (i.e. packet transmission) were not delayed. When I use Labview, I run sensors and actuators in separate vi's, not in the main case structure. I know that if I'm not careful, a separate process can eat up resources as well, but doesn't Labview allow you to prioritize specific processes? Could we then not protect comms? Of course, careless programming might have the robot stop because of the causes you outlined. But the comms would stay up.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
  #218   Spotlight this post!
Unread 11-05-2012, 09:57
Racer26 Racer26 is offline
While all this discussion of CAN is great, I know for a fact it is NOT the problem that 1114/2056 had on Einstein. They both exclusively use Victors.
  #219   Spotlight this post!
Unread 11-05-2012, 11:08
RyanN's Avatar
RyanN
Trust me. I know that wasn't the issue. It also wasn't our issue at bayou because we got rid of everything on our robot besides motors and solenoids. All using PWM, relay, and solenoid outputs, no camera.
It's just a potential problem that can come up that isn't easily diagnosable. CAN errors shouldn't cause everything to shut down.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
  #220   Spotlight this post!
Unread 11-05-2012, 11:48
AKA: Oliver Graff
FRC #3780
Oliver,
The terminator is required by the CAN spec, but it is there to prevent "signal reflection" which messes things up, however it will operate, without it, albeit with a smaller number of devices on the bus, however, my understanding is that no terminator at the end of the bus leads to issues with the Jaguars at the beginning of the bus, and lacking a terminating resistor at the beginning of the bus leads to issues at the end of it.
I have seen pictures of CAN splitters (there is a discussion about them on here somewhere), but they need terminators on each branch, and I believe the more branches you have the shorter each cable must be. In terms of CAN not being something that should shut everything down, when it comes to error handling and timeouts it can, even if it shouldn't.
I wasn't saying that CAN could have caused the problem at Bayou for you guys, I was just responding to the testing you were doing with it. I really do hope that the root cause of what happened to you guys at Bayou is found, I'd love to hear it.
  #221   Spotlight this post!
Unread 11-05-2012, 12:43
Oliver,
The nature of the signaling on the CAN bus uses switching in the transceivers to cause a device to enter a 'dominant' state for transmit and a 'recessive' state for receive. It is my understanding this is accomplished by driving the bus in a way that causes current flow in the terminating resistors. The CAN terminating resistors also provide the transmission line termination to allow 1 Mb/s traffic on a buss 40 meters long. Microchip has a nice application note, AN228, describing one of their products and the CAN signaling.
  #222   Spotlight this post!
Unread 11-05-2012, 12:56
Mikets did some interesting work on CAN backboning and posted about it here: http://www.chiefdelphi.com/forums/sh...d.php?t=102108
  #223   Spotlight this post!
Unread 11-05-2012, 14:05
Thanks,
I remember that discussion now.
  #224   Spotlight this post!
Unread 11-05-2012, 14:06
AKA: Oliver Graff
FRC #3780
Oliver,
I will talke a look at the info about that chip, thanks! My comments are based purely on observation of the behavior in certain fault conditions with the FRC control system. I don't know exactly how the internals of CAN work (yet, this is what the offseason is for!).
- Oliver
  #225   Spotlight this post!
Unread 11-05-2012, 14:12
Oliver,
Still learning myself. Considering the actual implementation was for cars, I would suspect that the protocol would allow for devices to go off line without killing the whole thing. So I am wondering what actually would cause the effect described above with a loss of a single device. Having seen the internal destruction on some Jaguars, it is always possible that an internal failure could have taken out the transceiver and shut down (shorted) the bus. In that condition, I would guess it is possible for the Crio to keep attempting to transmit data and do nothing else. I do not have any data to suggest that is what happened, just that it is possible. I bet Jim Zondag would know or at least could render an opinion.
