Go to Post We only ask that, when able, you too help other teams as we have helped you. It is this mentality of passing it forward that makes teams and FIRST great. - E. Wood [more]
Unread 13-05-2012, 11:39
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
Three joint arm
Hey, I'm the new build team leader of our team (#2212 The Spikes) and I decided to have the crew bulid soething we've neve tried before. We decided on building a multiple-joint arm, preferrably more than two, just to make things a little more interesting.
Did anyone ever see (or build) such a thing and direct me to someone who can explain it to me, or atleast a team? Pictures would be very helpful too.
Thanks in advance,
Bar, #2212
Unread 13-05-2012, 13:48
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Three joint arm
Wildstang's 2007 robot comes to mind (3rd joint pivoted along arm's axis, allowing them to reach to the side). If you do this, you should also devise a way to control such an arm reliably, there is no point in having a fancy arm if the driver can't use it effectively.
http://www.chiefdelphi.com/media/photos/27788
http://www.chiefdelphi.com/media/photos/27192
Unread 13-05-2012, 14:09
bardd's Avatar
That loud guy
AKA: Bar Danino
Re: Three joint arm
I actually meant arms with all joints on the same plane ( --O--O--O-- ). And you're right, for compatition purposes it's pointless to have a fancy and uncontrollable arm, but in this case the goal is to have a big fancy arm that has no purpose (maybe Isould have mentioned that earlier...).
But thank you very much
Unread 13-05-2012, 14:26
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Three joint arm
Team 33 2005 was a double jointed arm, and 2007 was a triple (shoulder, elbow, and rotating wrist). There is a lot of good documentation on the 2007 arm in the Behind the Design book from 2007.
Most FRC games I have seen can effectively be played with the 2 joint arm. The third joint adds more complexity than it would likel be worth for many games, but it would be a good learning exercise.
I think it is wise to protype an arm as the likelihood for a pick and place game is pretty high this next year. Also important to any arm design is the object manipulator. Instead of doing a 3rd joint, I would focus some effort on trying to pick up an odd shaped piece like a cone, cylinder, or some other non-ball shaped piece (inner-tube, tetra, box...).
Unread 13-05-2012, 14:32
ecchorobotics's Avatar
ecchorobotics ecchorobotics is offline
Eric Scardelli
AKA: Eric S
FRC #0075 (RoboRaiders)
Team Role: CAD
ecchorobotics has a spectacular aura aboutecchorobotics has a spectacular aura aboutecchorobotics has a spectacular aura about
Re: Three joint arm
Our 2001 and 2007 robots have several joints.
Another picture of the '07
The CAD will be posted to FRC-Designs.com soon.
Unread 13-05-2012, 14:35
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: Three joint arm
Team 2056's 2011 robot is another example of a successful 3 jointed arm.
Unread 13-05-2012, 14:45
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Three joint arm
2056 was only a two joint. Shoulder and wrist.
Team 1519's 2007 robot was a triple joint.
1058 PVC Pirates 2016 - xxxx
Unread 13-05-2012, 14:51
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Re: Three joint arm
How about 25's 2004 robot's arm?
http://www.chiefdelphi.com/media/photos/17115
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 13-05-2012, 14:55
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Three joint arm
2056's 2011 robot was only a 2 joint arm. But it had a "jaw" like tube manipulator.
EDIT: BrendanB beat me to it
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 13-05-2012, 15:21
pfreivald's Avatar
AKA: Patrick Freivald
Re: Three joint arm
Our too-slow, wonky-clawed two joint arm could pick up from the floor and place objects up to 12 feet off the ground. Why would you need a third?
http://www.youtube.com/watch?v=m3TE2FCp9A8
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 13-05-2012, 17:07
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
Re: Three joint arm
For the 2011 year we built a three jointed arm: shoulder, elbow and wrist. The picture below shows them fairly well -
http://team1912.com/photos/mediapage...ach11/_h21.png
From that year we learned 3-jointed arms are probably not the best idea. (although i dont doubt that effective ones can be beautifully made). We could have built something with less degrees of freedom that would have weighed less, been easier to control, and operated in faster and safer mode. It was a hard learned lesson and I hope we don't make similar mistake any time soon.
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
Unread 13-05-2012, 17:10
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Three joint arm
My suggestion would be to do everything you can to make the segments farthest from the attachment point of the arm as light as possible. and those closest to the attachment point as strong as possible. Flexing and torque are your enemy. I suggest very thin wall high-strength aluminum round tubing for the last section or two, 1/16th for the second segment, and 1/8th for the first. I also recommend that all segments except for the last one be constructed from two parallel sections. this makes the load distribution more symmetrical and results in less twisting. Your first joint will need either a strong motor, or large bore pneumatic cylinders. to reduce the torque caused by the large cantilever, place the motors at the beginning of the segment before the one that it moves. Also, the first segment should be balanced with surgical tubing so that it is stable with the arm folded. To get an idea of the kind of load the arm will be under, bolt three pieces of aluminum together and bolt one end down to something sturdy so that it pivots at that end. Then try to lift it from the pivot end.
Unread 13-05-2012, 17:40
Re: Three joint arm
Here's a short clip of our 3-jointed arm from 2007. The controls were fairly simple, because for that game most of the joints could be slaved to the position of a master joint. So the arm driver just specified where the tip needed to go and the rest of the arm followed.
There was a tightly constraining 80" cylinder written into the rules that year, so the software managed all the joints to keep the whole arm within that imaginary cylinder.
The arm was modeled and controlled in Vex first to test the control logic.
Unread 13-05-2012, 20:22
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Three joint arm
My personal design philosophy is single-joint or bust. Simpler to build, easier to control, easier to program, fewer points of failure, and require fewer motors (and speed controllers). There are plenty of other options to increase an arms "reach" other than adding more joints.
I do appreciate the desire and lessons that can be learned from taking this on as an off-season project, especially in regards to the control perspectives.
Unread 13-05-2012, 21:45
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: Three joint arm
68's robot from 2011 had 3 joints (well 2 and 1/2; we had a shoulder, a elbow, and could flick our "wrist".)
Skip to 2:57 for the arm, sorry I couldn't find any better pictures. They're all at school.
http://www.youtube.com/watch?v=QWKMNXKR7Ns
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
