Go to Post Mentors can always use mentoring. - JaneYoung [more]
Unread 13-05-2012, 21:49
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Three joint arm
My Arm Design Methodology:
1. What orientation is the scoring object in when I pick it up?
2. What orientation is the optimum orientation of the object for scoring?
3. What elevation changes do I need to make to the object?
4. What is the simplest mechanism I can use to accomplish the above orientation and elevation changes?
Now, #4 is a bit tricky since "simplest" is somewhat subjective. How do I define "simplest"? My personal concept:
  • The less degrees of freedom the better.
  • The less actuators required, the better. (I give bonus points for pneumatics over DC motors, since they are simpler control wise).
  • Easy to control -- I want to be able to drive it with default code. I want my drivers to be able to maneuver it almost intuitively.
  • Low power -- I don't want to need to use a lot of motor power to actuate it. I like any arm I can use passive assistance on (i.e. surgical tubing) to do the majority of the work.
IMHO, multiple jointed arms rarely result from this methodology...
-John
AdamHeard's Avatar
Lead Mentor
Re: Three joint arm
Originally Posted by PAR_WIG1350 View Post
My suggestion would be to do everything you can to make the segments farthest from the attachment point of the arm as light as possible. and those closest to the attachment point as strong as possible. Flexing and torque are your enemy. I suggest very thin wall high-strength aluminum round tubing for the last section or two, 1/16th for the second segment, and 1/8th for the first. I also recommend that all segments except for the last one be constructed from two parallel sections. this makes the load distribution more symmetrical and results in less twisting. Your first joint will need either a strong motor, or large bore pneumatic cylinders. to reduce the torque caused by the large cantilever, place the motors at the beginning of the segment before the one that it moves. Also, the first segment should be balanced with surgical tubing so that it is stable with the arm folded. To get an idea of the kind of load the arm will be under, bolt three pieces of aluminum together and bolt one end down to something sturdy so that it pivots at that end. Then try to lift it from the pivot end.
The entire structure could easily be 1/16". 1/8" is very inefficient in comparison.
Unread 14-05-2012, 09:45
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Three joint arm
5. How do the "initial configuration" and Maximum dimension requirements effect what I would normally choose as ideal?
I added one to John's list that has often required the "need" for an additional joint even if the joint was temporary. In my opinion, many of the great arms in FRC have required a "stowage" joint in order to meet the first 4 objectives and still fit in the starting configuration box. The "stowage" joint would sometimes be a non-articulating joint that would have a release and lock position (Team 67-2008). While great designs can come from out of the box thinking, the rules often require that you at least start in the box and grow from there.
I put "need" in quotes because of the 2011 1503 machine that seemed to defy common logic on what was needed to be excellent. I would put team 25's "2012 bridge manipulator" in the same category.
Unread 14-05-2012, 09:51
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Three joint arm
I know it's not FRC, but I thought of NI's Scorbot ... if your school offers Computer Integrated Manufacturing or something like it, you've likely got one of these in-house.
The joint controlling motors are housed near the shoulder joint; the motor at the hand operates the end effector. This design also turrets.
Hi!
Unread 14-05-2012, 09:52
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Re: Three joint arm
That robot was optimized to score the top row, making tube reorientation unneccesary, as the tube was always in the same plane as the arm. The plan from the get-go was to take care of the top row and let more complicated robots worry about the bottom two. We discussed having a wrist on the end of the arm even after we had abandoned fighting for tubes on the floor, and deemed it still unneccesary for our strategy that year.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 14-05-2012, 09:53
pfreivald's Avatar
AKA: Patrick Freivald
Re: Three joint arm
That's why our 2011 robot had a two-joint arm: reaching the floor and the top peg while fitting within the starting configuration. There were of course other ways to do that -- single-joint arm with an extender or forklift-type mechanism, but I don't know that they were in fact any easier or more elegant than what we came up with. (Some were faster, which mattered far, far too much! )
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 14-05-2012, 10:05
Kyler Hagler's Avatar
Kyler Hagler Kyler Hagler is offline
Jack of all trades
Kyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura about
Re: Three joint arm
Here's a look at out 2 jointed arm. The Shoulder is chain driven by the cim on the top half of the robot and the second stage of the arm is driven by a window motor. The claw was controlled by a pneumatic piston that opens and closes. The metal on the arm was .060 i believe, and had aluminum circle tubing that spanned to each side that we riveted into it. This would be something to look at. Message me if you want some more pictures. You could use this for some ideas.
Kyler Hagler - 3310 Alumni/Mentor
Black Hawk Robotics Team 3310
2012 Dallas West Regional Winner
2013 Dallas Regional Winner
2014 Colorado Regional Winner
2015 Hub City Regional Winner
2016 Arkansas Regional Winner
2016 Hub City Regional Winner
Http://Team3310.com
Unread 14-05-2012, 11:20
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Three joint arm
In 2011 we had both an extender to aid in picking up off the floor and a forklift style lift to reach the upper row. We thought this enabled the best and simplest driver control.
The driver drove the arm into a hard stop to go to the down position, to pickup he extended the claw out, as soon as he had the tube he released the extension and could rotate the arm up and raise the list to position at the same time without haveing to adjust to rotational joints. The extension had multiple effects, it kept the arm as short as possible so it wouldn't sway bounce or move as far during adjustments, it gave us a quick move to steal tubes if was were going at the same one as an opponent, protected the claw by keeping it inside the robot perimeter most of the time, and allowed us to hang middle row without raising the lift.
In my experience the easier it is for the driver to understand the movements the better they drive. 2 rotational joints allow multiple ways to get to the same position and creates many possible combinations. of how to get there. Which violates the very solid design rules that JVN outlined above.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 14-05-2012, 12:54
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
Re: Three joint arm
Three joints arm is hard to the driver to control. my team had in 2011 1 joint and a telescope which is much simplier and more effective
https://picasaweb.google.com/1136626...48580818847090
https://picasaweb.google.com/1136626...48660390128850
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
Unread 14-05-2012, 13:00
Brandon Holley's Avatar
Re: Three joint arm
Elaborating on JVN and Ike's point...
If additional joints and DOF are necessary, simplifying their execution is key. Our 2011 arm utilized a rotation "elbow" and a very simple "wrist". The wrist only allowed us to fit inside the starting envelope at the beginning of the match and hold the roller claw parallel to the floor. Small pneumatic cylinder with a 1/4-20 bolt as the pivot point. Super simple, super effective.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 14-05-2012, 13:46
pfreivald's Avatar
Re: Three joint arm
Yup, ease of use should always be high on the design priority list. The reason we went with screw drives (in restrospect at least partially a mistake) is because it was easy to make push-button controls for each necessary height -- there was a driver override just in case something went wrong with the encoders, but otherwise all the positions were pre-set and slaved to specific buttons.
Team 1551
I write books, too!
Unread 14-05-2012, 20:10
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
MIssin' the MItten
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Re: Three joint arm
A few people have mentioned surgical tubing to help out the motors. Definitely look into this or maybe air shocks, which we used last year on our arm.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 14-05-2012, 21:34
FRC #1836 (MilkenKnights)
Re: Three joint arm
While air shock look nicer than surgical tubing, the nice thing about surgical tubing is that you can tune it to the right strength. Unless you are trying to do something with a lot of power(ie. lifting your robot off the ground), usually surgical tubing is fine.
Unread 14-05-2012, 23:22
Jack of all trades
Re: Three joint arm
We actually used a gas strut to help raise the arm in our robot back last year and used one this year for our ball intake/bridge pull down. I would recommend looking into using one.
Http://Team3310.com
Unread 15-05-2012, 14:19
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
Re: Three joint arm
Thanks alot guys, I found your replies really helpful
We might actually go for two joints after all, but it's still a great discussion so no reason to stop here...
