Go to Post "You know, if we shoot the flame thrower out of the back of the car while driving down Main Street at 2:00am, we are probably going to get in a lot of trouble..." - dlavery [more]
Unread 14-05-2012, 19:24
yottabyte's Avatar
yottabyte yottabyte is offline
AKA: Clayton
FRC #4334 (Alberta Tech Alliance)
Team Role: Electrical
yottabyte is on a distinguished road
On Board Computer
I have seen some teams mount min itx computer on their robots. I would like to know how you would hook it up and what are some of the uses of one.
Unread 14-05-2012, 19:28
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Re: On Board Computer
We used it for image processing this year. We had a Kinect plugged into the onboard PC (consisting of a Zotac ITX motherboard with a dual-core Atom 330 and an SSD), image data was sent back to an applet running on the driver station where the driver could line up the target, get the distance, and then the wheel speed for the shooter would be calculated. Some teams did great image processing by using the Axis camera and doing all the processing on the driver station, but there certainly are some nice benefits to doing it all on the robot (one of them being that you can use the Kinect on the robot) and we hope to improve our system in the future as well.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 14-05-2012, 19:38
yottabyte's Avatar
AKA: Clayton
Thanks. But how did you power it? Did you use a pc power supple connected to the pd board or something else?
2015 - Utah Regional Winner
2014 - Western Canada Regional Regional Winner
2014 - Western Canada Regional Regional Chairman's Award
2013 - Western Canada Regional Regional Winner
2012 - Indiana Robotics Invitational Winner
2012 - Archimedes - Championship Division Winner
"If the women don't find you handsome, they should at least find you handy."
Unread 14-05-2012, 20:02
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
The simplest way to power an onboard PC would be with a DC/DC PicoPSU. It's much lighter and smaller than a standard PSU.
Here's one you could use.
http://www.mini-box.com/picoPSU-150-XT
It attaches above the motherboard's 24 pin socket. You would then strip the leads that are meant to go to an AC converter (laptop power brick) and plug those into a 12v on the NI PD Board. Simple as that.
Unread 14-05-2012, 20:12
yottabyte's Avatar
AKA: Clayton
thanks
Unread 14-05-2012, 20:59
dcarr's Avatar
#HoldStrong
AKA: David Carr
The Zotac board that we used (http://www.zotacusa.com/zotac-ion-it...onitx-t-u.html) accepted a 19volt input so we just got a 12 to 19 volt power supply, very clean setup. Avoids dealing with the 24 pin atx connector to begin with
Team 3309
Team3309.org
Unread 14-05-2012, 23:01
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
Is a board like this also a viable idea? Our team was thinking about building an onboard computer, and we wanted to keep things on the cheap. There is a $400 limit after all.
Also, will there be any problems with bootup time? The last thing I want is to turn our robot on, and have the FTA giving our team weird looks every match because windoze is taking it's sweet time.
Unread 14-05-2012, 23:34
Kyler Hagler's Avatar
Kyler Hagler Kyler Hagler is offline
Jack of all trades
Kyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura about
You could always just do your image processing on your C-rio? I believe we did that and didn't have a problem but your just have to have like absolutely as much off load on the cpu on board so that the cpu can actually do it. This resorted to us using 2CAN and integrated PID loops on the Jaguars them selves.
Kyler Hagler - 3310 Alumni/Mentor
Black Hawk Robotics Team 3310
2012 Dallas West Regional Winner
2013 Dallas Regional Winner
2014 Colorado Regional Winner
2015 Hub City Regional Winner
2016 Arkansas Regional Winner
2016 Hub City Regional Winner
Http://Team3310.com
Unread 15-05-2012, 01:40
yottabyte's Avatar
AKA: Clayton
thanks for the suggestion but in I think I would go with a mini itx board to keep space down
Unread 15-05-2012, 01:46
yottabyte's Avatar
AKA: Clayton
about the role of keeping each part under $400 does this mean keeping the combined total of the cpu motherboard ssd and ram under $400 or keeping each part under the limit
Unread 15-05-2012, 02:02
dcarr's Avatar
#HoldStrong
AKA: David Carr
Our total was under $400 I recall, just the Zotac board + RAM + SSD should keep you under $400 no problem (and I'm pretty sure it would be counted each party individually anyway but I'm not completely sure).
Bootup time is very fast, under 30 seconds with an SSD, so plenty of time from when the FTAs have you power up the robot to when it's situated on the field ready to go.
IMHO you definitely want to go for a low-power, compact solution like Atom.
Team 3309
Team3309.org
Unread 15-05-2012, 02:06
yottabyte's Avatar
AKA: Clayton
what os are you running? and what's the tdp of the atom
Unread 15-05-2012, 07:22
Gdeaver Gdeaver is offline
FRC #1640
The pico itx power supply that was linked probably is not a good choice. It is not designed for voltage drops like those that can happen on a robot. The same company makes the m3 model that can take drops down to 6 volts.
Unread 15-05-2012, 11:01
yottabyte's Avatar
AKA: Clayton
Thanks!
Unread 15-05-2012, 11:03
yottabyte's Avatar
AKA: Clayton
one more thing how do you control the program owns you are running?
