Go to Post We are customers to FIRST. In that comes expectations. I don't want to hear another, "You should be grateful for everything FIRST does" nonsense when FIRST royally screws up. - MikeDubreuil [more]
Unread 14-05-2012, 20:31
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
pic: 6WD Sheetmetal Chassis
Unread 14-05-2012, 20:40
IanW's Avatar
IanW IanW is offline
Rookie Mentor
AKA: Ian
FRC #0997 (Spartans)
IanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond repute
Re: pic: 6WD Sheetmetal Chassis
It looks really good.
I'd say the lightening pattern is rather conservative, so if you're pressed for weight, you could probably take some more out.
Looks like you might have more rivets than you really need on the gearboxes, but better to have too many than too few I suppose.
This may be something you intentionally didn't add, but you may want to consider a bellypan for reasons ranging from enhanced rigidity to convenient location for electronics.
My only other thought was that you might want to add more overlapping/connecting material at the corners. I have modeled a couple drivetrains like this, but have never built one of them, so I will defer to someone with more experience on this aspect.
Website
Facebook
Unread 14-05-2012, 20:43
2185Bilal's Avatar
2185Bilal 2185Bilal is offline
Driver, Ld. Programmer, Electrical
AKA: Bilal Majeed
FRC #2185 (Ramazoidz)
2185Bilal will become famous soon enough
That desgin, but i think chaining only the lower 4 wheels so the bot can turn better
RAMAZOIDZ
2009 Toronto West Regional - Regional Winners
2009 Waterloo Regional - Regional Winners
Unread 14-05-2012, 20:46
I am planning on adding cross supports over and under the gearboxes for added rigidity.
Ummm. I'm not quite sure what you are saying here. I stated that I dropped the center wheel 1/8"
Unread 14-05-2012, 20:59
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Tip: If you dropped the center wheel 1/8" you will have 1/4" of rock in your chassis because it will not sit as it does in your CAD. If this is the case and you actually want 1/8" of rock I suggest either raising an outer wheel 1/8" or dropping the center only 1/16"
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 14-05-2012, 21:03
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
A few questions:
-What size rivets are they, and at what spacing?
-Why the 0.090" 5052? We looked at 5052 this year, but decided to go with 0.063" 6061 (and later decided we should have gone with 0.050" 6061). A thinner material would be lighter, and 6061 0.063" is strong enough for a FIRST robot with bumpers.
-Any details on the shifter, specifically the ratio and shaft design?
And finally, any plan to remove the transmission in vehicle if you ever have to? It looks like it would be very, very difficult to work on anything inside the transmissions as it is now. Even though it would possibly weigh slightly more, you could pocket out the space of the transmission side plate that is integrated into the frame, and put another plate over it. The transmission would then be a single assembly bolted into a hole on the frame.
Kettering Motorsports
Unread 14-05-2012, 21:16
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Seconded. We had a sticking transmission at Worlds, so we took the whole thing out and put in our spare in a few minutes. Definitely an important consideration.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 14-05-2012, 21:23
Answers are in bold.
A few questions:
3/16" at 1/2" spacing
I decided on .09" 5052 because that's what I've seen many teams use and since it was my first sheetmetal chassis I thought that would be a good starting point.
The shaft is made custom on a lathe/mill. I will try to upload a pic of the actual shaft but it is not letting me put an attachment in this post.
I am going to pocket out the flanges above the transmissions. I am also probably going to remove the rivets attaching the transmission to the chassis and replace them with bolts for easier removal.
Unread 14-05-2012, 21:37
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Over All GREAT Looking Chassis!
But I still have things that I would recommend you change to improve it
- I would change your lightening holes to Triangles rather than circles. It will help you lose more weight and can be stronger.
- I love the way you have the supports on the transmissions. But it will still torque your side plates. You will want to put some sort of cross braces of some sort. It could be just bottom braces though, just to pull in the bottom of the transmissions. TRUST ME! They will torque and your chassis WILL be warped. But Then again Bottom and Top braces will be better.
- Good job with the extended Top flanges. It will help keep your side plates in line properly.
- If I am looking at this correctly. Why are your axles live with that type of Chaining? you only need Live axles if they are passing threw plates (the wheel is on one side of the plate, and the sprocket is on the other). You will save weight if you change to Dead Axles. The only one that must be live is the middle wheel because it is direct driven.
Great job for your First Sheet-metal Chassis!
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 14-05-2012, 21:52
2185Bilal's Avatar
AKA: Bilal Majeed
Cool Re: pic: 6WD Sheetmetal Chassis
ohh im sorry, i was saying that i really like the design but i would only chain four wheels, and in the front put like omni-wheels so the turn ability is increased. Like the way the u have it now, it will turn but not as fast as it could
RAMAZOIDZ
Unread 14-05-2012, 21:56
smistthegreat's Avatar
smistthegreat smistthegreat is offline
robots is a hard job
AKA: Brian Smist
FRC #4930 (The Electric Mayhem)
smistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond repute
As has already been stated, the center wheels are dropped to ensure smooth turning. Generally, to improve turning performance, you can either drop the center wheels or add omnis at one or both ends. Doing both is not necessary.
University at Buffalo | Mechanical Engineering | Class of 2016
2014-20?? | Mentor | 4930 | The Electric Mayhem
2013 | Mentor | 229 | Division by Zero
2013 | Mentor | 4124 | Integration by Parts
2009-2012 | Student | 1507 | Warlocks
Unread 14-05-2012, 21:58
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Would you recommend the multiple powered omnis or the drop center?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 14-05-2012, 22:02
FRC #1836 (MilkenKnights)
That is not true. A drop center will act as if there is not an extra 2 wheels. In other words, it will act as if it is a 4wd with a smaller wheelbase.
Unread 14-05-2012, 22:24
The only live axles are the center shafts which are direct driven off the transmission. The outer 4 wheels are dead axles with a 22T #35 chain sprocket.
Unread 14-05-2012, 22:26
Okay I am looking at it wrong then. What are the circle on the outside wheels, that to me look like bearings?
2013-Present
2010-2013
