Go to Post Anything released in a game hint is subject to enough misinterpretation and "nah, they'll never do that" to deflect any possibility of something being actionable. - EricH [more]
Unread 14-05-2012, 17:02
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: pic: 1538's Practice Electronics Board
Originally Posted by Alan Anderson View Post
That's an amazingly clean layout. It's almost ridiculously clean. I'd be concerned that any wiring issues would be hard to fix without ruining it.
Forgive the nitpicks, but is the cRIO insulated from the frame? And you do know that it's never been legal to replace the Spike fuses with breakers except on the one controlling the compressor, right? I'm also curious why the PDB isn't rotated 180 degrees so the power wires to the Victors and the Spikes don't cross each other, and the cRIO power can run a shorter distance, though I can see it would be a tradeoff against the battery position.
We have some adhesive rubber between the cRIO and the frame. As for the breakers, we only used the for testing on the practice bot. The battery was our biggest concern with the PDB, and finding room for 4 gauge wire was difficult even with the short run. I will post more photos when we take apart the practice bot.
Originally Posted by Akash Rastogi View Post
Conner, do you think you could get together with Kiet to put together a simple white paper about the methods/part numbers/wire choice (brand, source)/terminals/tips that he taught you this year? Do you use nylon/other plastic hardware to mount electronics? What is the best generic layout? Does having a waterjet hole pattern for electronics really force you to keep a clean layout?
Would be great to have these down on paper if you folks get the time. Thanks!
This sounds like a great idea. I will talk to Kiet about it.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 14-05-2012, 17:44
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Conner,
One of the best electrical wiring jobs I have ever seen. In addition to the nice layout, everything is very short giving the best electrical loss layout. The only thing I could think of, it the PD bridging the distance between two sides. Please remember this is one giant circuit board with a lot of copper on it. The mechanical stress it is likely to encounter might cause a break in the board. If it is not firmly attached to both sides, you should be OK.
Gold Star!!!
Thanks Al,
The PD mount area is very rigid as there is a supporting 2x1x1/8" cross member with holes for solid standoffs to mount the electronics plate to.
There is little to no wobble when trying to move the PD.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 14-05-2012, 17:47
kiettyyyy's Avatar
Originally Posted by sanddrag View Post
Actually I believe they are flush cutters, most likely of the Xuron brand, but possible Xcelite.
I'd like to know what p/n of terminals you used on the Victors, and if you had to sand them to fit.
They're Xuron brand flush cutters.
The spade terminals that we used were sourced from McMaster-Carr, PN 69145K62. These fit perfectly in the Victor terminals. We did not need to modify these connectors.
-Kiet Chau
www.team1538.com
Unread 14-05-2012, 17:52
CalTran's Avatar
CalTran CalTran is online now
Missouri S&T Senior
I was curious about that too. We've learned over the years we have vastly fewer problems when we keep the crosses strictly perpendicular rather than running them parallel and wrapped up in a bundle.
Apart from that, it looks absolutely beautiful. I approve.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 14-05-2012, 18:15
kiettyyyy's Avatar
As mentioned earlier, space constraints were very tight with this robot. We needed to have a shorter mains wire run between the PDB and the battery box area.
Regardless, we did not have any issues mounting the PDB as pictured.
-Kiet Chau
www.team1538.com
Unread 15-05-2012, 08:24
Kiet,
I was thinking that robot frame flexing while driving or being hit would allow some movement between the two sides of the robot. It is this independent movement that I was worried about.
Unread 15-05-2012, 09:12
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
What motors, ratio, and diameter were these run on?
We debated running our various conveyors on them, but were afraid of tripping the fuse with a 500 sized motor.
We ran our tower on a spike. 16:1 custom spur gear transmission with one 550 and 1.75" rollers. Our intake at the same ratio would ocassionally pop the breaker so we swapped to a victor for that one
Mentor 2415
Unread 15-05-2012, 13:06
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is online now
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Kiet,
The baseplate goes underneath the PDB. Not sure if you can see that?
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 15-05-2012, 13:08
Thanks, Trav. I would hope that would suffice.
