Go to Post The biggest fallacy in FIRST is the belief we are just a bunch of different teams. We are ONE BIG TEAM with a lot of sub teams for the purpose of competition. - Al Skierkiewicz [more]
Unread 15-05-2012, 17:59
nydnh01 nydnh01 is offline
AKA: Naresh Hing
FRC #1601 (Quantum Samurai)
nydnh01 is an unknown quantity at this point
D-link Router Giving problems with cRIO
Today we tested our wireless after uploading the code we had at competition the router gave the driver station a watchdog not fed error. When we connected the crio directly to the computer the code executed properly. How do i fix this problem?
Unread 15-05-2012, 18:05
normpear2 normpear2 is offline
Team Programming/Electrical Co-Lead
FRC #2603 (Highland FIRST Robotics Team #2603)
normpear2 is an unknown quantity at this point
Send a message via AIM to normpear2 Send a message via MSN to normpear2 Send a message via Yahoo to normpear2
Re: D-link Router Giving problems with cRIO
Try the reset button and set the router up again, or flash the firmware and set the router up.
Firmware helped on one of out test routers that gave us that same problem.
Unread 15-05-2012, 20:53
If you're getting watchdog errors displayed on the Driver Station, it means you have at least some communication. It's possible that there's another wireless network nearby interfering with things and keeping the communication from being good enough. Do you have a way to scan for Wi-Fi signals? (Try a program called inSSIDer; it's available from many sources.) If you can find an unused block of channels on the 2.4 GHz band, try logging on to your D-Link and setting its channel manually to avoid interference.
Unread 16-05-2012, 00:25
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
After competition, our team re-imaged the router and set it up to FIRST specs, but we left the encryption open, and changed the band to 5Ghz. Even during demonstrations in college campuses with 20+ 2.4Ghz networks, we ran perfectly. You would have to check if your driverstation computer supports 5Ghz though. When you ping your router (use cmd), you should ideally have <10ms response time.
